Old 22nd May 2005, 09:07 PM   #1
Default Very Old Moro Kris
This is an old one that has seen better days, but it is interesting for several reasons.
First, it has been modified by another culture, probably a Spanish colonist. The hilt is a typical Spanish style, and originally had small brass ferrules at either end, but the top one is missing. The hilt has only a partial tang construction (unlike many similar Spanish-style hilts, such as commonly seen in the more northern areas of the Philippines). At some point, the hilt has been painted gold, but much has worn off.
Second, the top half of the gangya is missing, and obviously there is no asang asang.
Third the blade is clearly of an old form, at least early 19th C. or older. It is covered with a dark patina, especially on the gangya, and the file work on the gangya has been removed and/or worn away with time. Evidence of lamination can still be seen along the blade and numerous deep edge nicks speak to heavy use at some time.
Lastly, there is a very interesting inscription on the gangya. The chiseled numbers are old and have been on the blade for some time because there is evidence of corrosion of some of the numbers which blends into neighboring pitting on the blade. As you can see from the pictures, the numbers 13...2 are legible while the third figure could be a 5, 8, or 9. This is probably not a credible date -- the arrival of Europeans in the southern Philippines post dates the 14th C. -- but it raises some questions as to what the inscription means on this old kris.
Comments, ideas
Ian.
Very Old Moro Kris with Spanish Style Hilt
