Old 27th October 2008, 09:20 PM   #1
CharlesS
CharlesS's Avatar
Default Another Unusual Moro Kriss....any ideas??
Here is yet another Moro kriss variant. I have seen several brass pommel krisses, but not a fully cast brass hilt like this. The seam in the casting seems to be covered with yet another piece of highly detailed work to the bottom of the pommel.
Also note the high detailed and somewhat unusual belalai gajah and jenggot gajah(Indonesian terms for those parts), or lower guard. The 'elephant trunk' has not been shortened or broken, and appears higher and more notched than typical....if, indeed, that is the 'trunk'.
Any ideas regarding origins are welcomed. I have no reason to think this is anything other than Moro, but from where, more specifically?
Old 27th October 2008, 10:25 PM   #2
Spunjer
Spunjer's Avatar
most likely, maguindanao, charles, with the handle casted by a neighboring t'boli smith..
Old 27th October 2008, 10:41 PM   #3
CharlesS
CharlesS's Avatar
I wondered if there might be T'boli involvement....seems like every time a piece of brass orginates from the Philippines the T'boli or Bagobo become an option.
Old 28th October 2008, 12:13 AM   #4
apolaki
what are those two silvery stripes on each end of the bottom of the sword's base called?
apolaki is offline   Reply With Quote
Old 28th October 2008, 01:40 AM   #5
Spunjer
Spunjer's Avatar
check out this bagobo sword (sorry, pics slightly out of focus):
middle
the reason i said t'boli is because of their proximity to the maguindanao. but then again could be a Bagobo handiwork
apolaki, are you referring to the metal straps? if it is, depending on the tribe, it's either baka-baka, or asang-asang
Old 28th October 2008, 01:55 AM   #6
CharlesS
CharlesS's Avatar
Great pic/example Spunjer. Thanks.
I'm a little surprised now that we haven't seen other similar kriss examples.
Old 28th October 2008, 03:35 AM   #7
Tboli are renowned for their brass work and are experts at casting solid brass hilts.
Old 28th October 2008, 04:32 AM   #8
To take Ron's explanation a step further , these straps are used to secure the blade to the hilt. They are not merely decorative.
Old 28th October 2008, 02:16 PM   #9
Smile Straps
Also referred to as 'stirrups' by some .
