Old 11th December 2004, 08:51 PM   #1
Ferguson
Ferguson's Avatar
Default A Bolo (Tenegre?) and a Gunong for comment
A bolo and a gunong that I found in a local knife shop. The bolo is 26 1/2" overall with a 20 3/4" blade. Weight is 1 lb. 8 oz. It has a chisel grind. Hilt is brass and wood with a copper guard. Blade is well hardened.
The gunong is 11 1/4" long with a 7 1/8" blade. Guard and ferrules look like silver plated copper. Sheath is wood with aluminum fittings. It fits well but doesn't look original. Workmanship on the hilt is good, but the blade seems pretty soft. Probably made just for show.
Comments are welcomed.
Thanks,
Steve Ferguson
Old 12th December 2004, 02:52 PM   #2
LabanTayo
LabanTayo's Avatar
ferguson,
very nice tenegre. i like the hilt.
it looks psycho!!!!
i'll let the moro guys comment on the gunong.
LabanTayo is offline   Reply With Quote
Old 12th December 2004, 04:37 PM   #3
zelbone
zelbone's Avatar
Cool WAY COOL!!!
Nice tenegre/talibong you have there, Steve. Definately a fighting bolo. It looks pre-WWII, but I couldn't give you a more precise date. This looks like it could be from Negros since it doesn't quite fit the standard forms of Panay. The deity hilt is similar to the ones from Panay, but it also is quite different...a bit more absract. The mouth of the demon also lacks the double-set of fangs you normally would see on the demon hilts from Panay. The hilt looks like it was carved from Narra wood which is reddish in color...doesn't look like it's kamagong (Macassar Ebony) which would be more black. The scabbard also looks more Negros than Panay: the tapered toe, lack of leather at the throat, and the brass hanger. What I really like is that blade...long and slender! I just got another tenegre the other day with a long slender blade that moves like a dream. I almost didn't get it back when I showed it to Shelley !!!
The gunong looks about WWII vintage. I have a very similar one made in Tagaya, Lanao which I guess would make it Maranao. Earlier gunongs would have the luks forged into the blade. Your example (as well as my similar one) have luks that are more pointed and not as sinuous as the older forms. These were usually filed to shape rather than forged. The workmanship on the hilt is pretty typical of these gunongs and is well executed. The scabbard is definately a replacement, otherwise the metalwork on the scabbard would match the hilt. The scabbard with yours looks like the bands are made of aluminum, while the fittings on your gunong looks like its silver or nickel silver. I have the almost exact same replacement scabbard for actually the nicest gunong I have. It's funny, but the nicest gunong I have has the ugliest scabbard, while rest of my other gunongs which range from mediocre to somewhat exceptional all have nicer scabbards !
zelbone is offline   Reply With Quote
Old 12th December 2004, 05:17 PM   #4
Ferguson
Ferguson's Avatar
As always, great information guys! Thank you very much.
Steve
Old 13th December 2004, 10:50 PM   #5
Regarding your gunong, I would say that the dating is correct if not later, and the base metal is copper with a silver wash over it.
