Old 21st June 2008, 08:36 PM   #1
Atlantia
Atlantia's Avatar
Default Pair of arsenal Tulwars. Inscription help needed
Had these for a while, they are as you can see plain but functional. They have abnormally broad blades which are well tempered and sxtremely sharp. Double edged for the first 12 inches or so, a little crude but lovely springy steel. Bronze hilts.
Both have a similar punched inscriptions on the blades, I wondered if anyone could shed any light on them for me?
Thanks
Gene
Old 21st June 2008, 08:46 PM   #2
Lew
Lew's Avatar
Looks to be Bikiner Armoury markings.
Lew
Old 21st June 2008, 08:49 PM   #3
Atlantia
Atlantia's Avatar
Lew
Ummm, Bikiner Armoury?
Old 21st June 2008, 09:20 PM   #4
Bikaner armory used punch marks like these to inventory blades .
Some of the tulwars' symbols are matches to Bikaner markings .
This does not mean that the blades originated there .
Old 22nd June 2008, 02:22 AM   #5
ward
bronze/brass hilts plain pounded out blades= late peasent swords. these were made quick and dirty.real but no quality
Old 22nd June 2008, 03:07 AM   #6
I agree with Lew and Rick, the distinct dotted script is a Bikaner armoury characteristic, and this seems to have been a monumental establishment with the number of weapons associated with it. This is in Rajasthan, where these weapons are still produced. The appearance of identical weapons would suggest commercial products, but it seems unusual to have such detail as armoury marks applied.
It is worthy of note that in the latter 19th century, well into the 20th, the native cavalry regiments for the British Raj, had varying preferred swords selected by the officers. While many took previous British regulation patterns, many chose thier traditional tulwars. I had a pair of steel hilt tulwars that were incredibly pedestrian, munitions grade and stamped MOLE in the blade. These were apparantly of early 20th century and likely intended to be included in armoury stores for such issue. The lack of regimental marks suggests this issue was never reached, and I wonder if this may be the case with these.
Perhaps wishful thinking, but thought I would add this anyway. The traces of dark pitting in the blades suggest there is some age, and bronze can also be polished out. The blade profiles show the stepped back for the last third of the blade near to the point, a feature that would not seem to be used on commercial products for civilians.
In the military regulations there were apparantly indications on the length of tulwar blades for the native regiments, I believe 31" and 33" , one for Madras and the other Bengal, cannot recall specifics though.
Old 22nd June 2008, 04:39 AM   #7
On the second pic one can see "footprints" of another langet under the current ones.
My guess these blades were remounted ; AFAIK, brass hilts indicate more recent origin.
Old 22nd June 2008, 06:06 AM   #8
there was previous discussions here as to the commonality of tulwar blades being rehilted, as well as the possibility of some suspicious local army leadership having the hilts and blades stored separately which would delay any local spur of the moment mutiny but allow reasonably quick reassembly in case of a real need by his armies.
Old 22nd June 2008, 02:27 PM   #9
We have seen similar tulwar hilts with square moplah, as if intended for a wrench type tool to remove threaded pommel. In many cases the moplah is pierced to insert a small tool to unthread.
Old 22nd June 2008, 03:44 PM   #10
Jens Nordlunde
Jens Nordlunde's Avatar
The picture of the dot markings are not good enough to decide if they are Bikaner markings, but I doubt if they are. The Bikaner dot markings are mostly shorter, so only better picture can tell.
Old 23rd June 2008, 12:30 AM   #11
maybe the dots mean something else
Old 23rd June 2008, 11:00 AM   #12
Atlantia
Atlantia's Avatar
Long as they don't say 'Made in Hong Kong 1998' ! lol
I'll take some better pictures later, thanks all.
Old 23rd June 2008, 12:31 PM   #13
Jens Nordlunde
On the second picture I can see the number 522 on the upper tulwar and 35? on the lower one, so it could be armoury marks.
