Old 20th May 2008, 07:03 AM   #1
Default 2nd Caucasian Kindjal for comment
Found some time today to photograph the other Kindjal I have here.
Ex Butterfield and Butterfield
I welcome any comments including Jeff's if he is not gun shy now.
There is a collectors sticker on the rear of the piece stating it to be from Tiflis or Erevan, with a silver hilt and scabbard with bold Niello decoration, reverse of hilt and scabbard with neillo florals and faint remains of a signature, circa 1860.
I don't consider the craftsmanship...there's that word again..of the blade to be as good as the previous Kindjal but the rest of the piece does show superior craftsmanship. In a martial application though, this piece is not as quick from the scabbard or through the air or as comfortable in the hand? Is there a reason for this, is it purely a status/display piece?
There is an issue I wish to fix too, there is a collectors sicker that is over 10 years old and is stuck pretty good on the reverse. If I remove it, it will come away in pieces and I will need to use chemicals to clean the remainder off, will this effect the Neillo application?
regards
Gav
Gavin Nugent is offline
