Old 1st April 2005, 03:47 PM   #1
Spunjer
Spunjer's Avatar
Lightbulb Barong Classification
i've compiled this a while back, but just didn't have the time to post it. my main resources are cato's book and an old thread from the old website. the answer on that old thread was given by none other than our fellow forumite, zelbone. i emailed him a copy of this compilation, and he informed me that these are general guidelines , and not to be taken as gospel. to everyone else; you are more than welcome to chime in. as a matter of fact, i would like to encourage everyone to help out if there's anything else that's been left out. i am hoping that this will serve as referrence for future collectors and something that veteran collectors can go back from time to time. once again, please bear in mind that this is a general guideline. as we all know, we are barely scratching the surface on moro weapons, and i'm hoping that this would help out just a little. without further ado, here is my thesis on the magnificent barong...
BARONG
TYPES
*YAKAN
*TAUSUG
*SAMAL
YAKAN CHARACTERISTICS:
HILT
*CREST RISES TO A HEIGHT OF SEVERAL INCHES AND IS WITHOUT THE CURVES THAT ARE FOUND ON OTHER BARONG KAKATUAS
*THE STRAIGHT PLUME IS BEVELED AND RATHER THICK AT THE UPPERMOST POINT, CREATING A DRAMATIC REGAL EFFECT
*IDENTICAL TO PIRAS
*MOST LIKELY INCORPORATED WITH CARABAO HORN
*INSTEAD OF TYPICAL 3 IN. PUNTO (SLEEVE) YAKAN BARONG SLEEVES ARE APPROX. ONE AND A QUARTER INCHES, AGAIN SIMILAR TO PIRAS
*KAKATUA BEAKS ARE NORMALLY UNADORNED, PLAINER, MORE SUBTLE, BEAK-LIKE TERMINAL
FOR REFERRENCE, SEE CATO'S PLATE 21
TAUSUG CHARACTERISTICS:
HILT
*KAKATUA PLUME ALMOST ALWAYS EXTEND OUT AN ANGLE AWAY FROM THE POINT OF THE BLADE; USUALLY AT A 45 DEG. ANGLE WITH THE BUTT
*HEAVILY CARVED AND DECORATED IN THE STANDARD UKKIL DESIGN
*POMMEL BUTTS ARE USUALLY A 45 DEG. OR LESS IN RELATIONSHIP TO THE PLANE OF THE BLADE SIMILAR TO YAKAN GEOMETRY
*KAKATUA BEAKS ARE SOMEWHAT SIMILAR TO YAKAN'S, WHERE IT'S NORMALLY UNADORNED, PLAINER, MORE SUBTLE, BEAK-LIKE TERMINAL
FOR REFERRENCES, SEE CATO'S PLATE 19, FAR LEFT, AND PLATE 20, LEFT
SCABBARD
*DOESN'T NORMALLY TAPERS DOWN DRASTICALLY AT THE TERMINAL END
*TERMINAL END ARE USUALLY WIDER WITH A LARGER FLORALLY CARVED UKKIL DESIGN
*THE SAMPIL, OR MOUTH PART OF THE SCABBARD TENDS TO HAVE WING-LIKE APPENDAGES ON BOTH THE SPINE SIDE AND THE EDGE SIDE OF THE MOUTH (DATU CLASS TAGUB)
FOR REFERRENCES, SEE CATO'S PLATE 23 AND 24; PLATE 26, CENTER
SAMAL CHARACTERISTICS:
HILT
*KAKATUA PLUME TEND TO CURL FIRST, THEN UBRUPTLY EXTENDS OUT
*APPENDAGES (KAKATUA PLUME) ARE USUALLY SMALLER COMPARED TO THE TAUSUG'S
*SAMAL ARE QUITE FOND OF BRAIDED SILVER WIRE WHERE THE WOODEN KAKATUA MEET THE SILVER FERRULE (PUNTO)
*BUTT-END IS ALMOST ALWAYS PERPENDICULAR TO THE PLANE OF THE BLADE, GIVING THE PLUME THE TENDENCY TO CURL IN FIRST THEN EXTENDS OUT
*KAKATUA BEAK USUALLY HAVE A SMALL RECTANGULAR CARVED APPENDAGE AT THE END
*BEAK IS MORE ORNATED THAN THE TAUSUG'S (EXCEPT ON SUPERLATIVE JUNGGAYAN PIECES IN WHICH THE TAUSUGS ARE ELABORATELY CARVED AS WELL)
FOR REFERRENCES, SEE CATO'S PLATE 19, FAR RIGHT; PLATE 20, RIGHT
SCABBARD
*TERMINAL END OF THE SCABBARD TAPERS DOWN WITH THE SHAPE OF THE BLADE AND THEN ENDS WITH A SMALL CARVED TERMINAL PROJECTION
*AS FOR THE SAMPIL, USUALLY HAVE ONE ROUNDED SHOULDER ON THE SPINE SIDE OF THE SCABBARD AND A WING-LIKE APPENDAGE ON THE EDGE SIDE
*BOTH SIDES ARE CARVED WITH UKKIL DESIGN
FOR REFERRENCE, SEE CATO'S PLATE 20, RIGHT
BARONG CLASS
*FIRST CLASS / DATU / CEREMONIAL
*MIDDLE CLASS / COMMONER
*LOW CLASS / FIGHTING
FIRST CLASS / DATU / CEREMONIAL CLASS CHARACTERISTICS:
HILT/POMMEL
*KNOWN AS JUNGGAYAN DUE TO THE EXTENDED CREST AND BILL ON THE KAKATUA POMMEL
*JUNGGAYAN POMMELS RANGE FROM FIVE AND A HALF TO EIGHT INCHES IN LENGTH
*KAKATUA PLUME ASCENDS IN A GRADUAL CURVE UNTIL IT REACHES THE TERMINUS, WHERE IT CURLS UPWARDS
*MOST HAVE ONE OR MORE THIN, CARABAO HORN SPACERS AT THE JUNCTION OF THE HILT AND THE POMMEL
*FOR PUNTO, NORMALLY INCORPORATES ONE FULL SLEEVE
*CYLINDRICAL PANELS (PUNTO) ON THE UPPER HILT, JUST ABOVE THE FERRULE, USUALLY COVERED WITH SMALL, SEMI CIRCULAR OR DIAGONAL UKKIL DESIGNS, AND WERE EXECUTED IN BRASS, SILVER, AND RARELY, GOLD
*INTERSPERSED WITH THE PANEL ARE BANDS OF PLAITED SILVER WIRE
CROWN MATERIALS:
1) KAMAGONG WOOD = USUALLY INLAID WITH GEOMETRICALLY SHAPED PIECES OF BONE
OR IVORY THAT WERE FITTED ON THE SIDES OF THE POMMEL AREA AND/OR THE BUTT OF THE
WEAPON. THIS TYPE ARE POPULAR WITH THE MOROS FROM *THE SOUTHERN MOST ISLANDS OF
THE SULU ARCHIPELAGO*
2) SILVER = IN REALITY ARE IN SHEET FORM OVERLAID UPON A PRE CARVED WOODEN
CORE
3) CARABAO HORN = OCCASIONALLY USED AND NORMALLY MATED WITH BUNTI
4) IVORY = VERY POPULAR WITH ARISTOCRATS AND SULTANS
FOR REFERRENCE, SEE CATO'S PLATE 17, AND PLATE 19, MIDDLE, MOST LIKELY FAR
LEFT AND FAR RIGHT; PLATE 20, 22, 23, 24, AND 25
MIDDLE CLASS / COMMONER CHARACTERISTICS:
HILT/POMMEL
*MORE ELABORATE THAN THE VERY SIMPLE DESIGNS FOUND ON FIGHTING BARONG
*FREQUENTLY TOPPED WITH INTRICATELY-CARVED RENDERINGS OF THE KAKATUA'S PLUMMAGE AND BEAK
*PUNTOS ARE DECORATED SIMPLY, WITH LINE THAT CIRCUMSCRIBE THE FERRULE AT THE TOP AND BOTTOM
*MORE OFTEN THAN NOT, RATHER THAN ONE FULL SLEEVE, IT INCORPORATES THREE OR FOUR SILVER BANDS THAT ALTERNATE WITH BANDS OF BRAIDED JUTE
FOR REFERRENCES, SEE CATO'S PLATE 18, RIGHT; PLATE 19, SECOND FROM FAR RIGHT; PLATE 27, LEFT
LOW CLASS / FIGHTING CHARACTERISTICS:
HILT/POMMEL
*PUNTOS GENERALLY CONSIST OF A NARROW RING, LESS THAN AN INCH WIDE (OF SILVER, BRASS, OR CARABAO HORN) AT THE BOTTOM OF THE POMMEL
*PLACED ABOVE THE ABBREVIATED PUNTO IS A CLUSTER OF WOVEN JUTE BAND CALLED LANGDAY
*FOR POMMEL DESIGNS, COMBAT BARONGS ARE DISTINGUISHED BY SHORT PROTRUSIONS WHICH ARE LITTLE MORE THAN MERE SUGGESTIONS OF THE CREST AND THE BEAK OF THE KAKATUA MOTIF
*NOT OFTEN SEEN ARE POMMELS STYLED AFTER A HORSE'S HOOF WHICH ARE CYLINDRICAL IN APPEARANCE, WITH A DOWN-TURNED END
FOR REFERRENCES, SEE CATO'S PLATE 19, SECOND FROM LEFT; PLATE 27, RIGHT
