Old 4th January 2007, 03:41 PM   #1
Emanuel
Emanuel's Avatar
Default Khanjar for comment
I got this khanjar for Christmas...sort of
It's 12.5" long in scabbard, with a blade measuring 7". It looks a lot like kurdish khanjars, but there are some differences in construction. For one thing, the tang is held by a but screw or bolt instead of the studs on the face of the handle. The scabbard is also very different from the nicely tooled kurdish ones. It is wooden, coverd in black leather. Oddly, it has a brass collar and brass stitching that make it look like a khukri scabbard. Hence I'm thinking it could be Indian/Nepali/Afghan work. Then again, such a simple scabbard could very well have been made by Kurds.
The blade looks like it was extensively polished at some point. There are depressions on the surface of the blade - maybe due to power sanders used to remove pitting and rust.
Any comment would be most welcome.
Emanuel
- To clarify, the black horn khanjar with the two studs is the Kurdish one
Old 4th January 2007, 03:49 PM   #2
BBJW
BBJW's Avatar
Except for the scabbard this looks much like a Balkan piece I have.
Old 4th January 2007, 04:27 PM   #3
Emanuel
Emanuel's Avatar
Looking at it, I think the scabbard is a replacement. There is a repair or alteration at the tip, perhaps indicating that a larger scabbard was cut down to fit this small blade. Its weird curvature would support this I think.
Could you post a pic of your balkan example? The ones on the Oriental-Arms website are more high-end it seems and most bear silver decorations.
Old 4th January 2007, 06:09 PM   #4
ward
that scabbord looks like it was originally for a sword shamshir tulwar etc and and just cut.
Old 4th January 2007, 07:10 PM   #5
Smile But ...
Look at the radical curve the stitching takes at the tip.
Isn't that a little too radical a curve for a shamshir blade to take ?
Old 4th January 2007, 10:42 PM   #6
BBJW
BBJW's Avatar
Default Balkan
Notice that the scabbard has a sewing thimble on the tip.
Old 5th January 2007, 02:24 AM   #7
Emanuel
Emanuel's Avatar
Thanks for the pic!
I can see the resemblance...but your scabbard has geometric motifs tooled into the leather and wood it seems, and the nib at the tip is much like my own kurdish khajar.
Now that I look at this weird scabbard, it looks like it's coated in pitch or something to make it hard...it isn't bear leather like on my khukri scabbards.
-some more comparative pics...
Emanuel
Old 5th January 2007, 02:38 AM   #8
BBJW
BBJW's Avatar
Thanks for the pic!
Emanuel
Bear leather??? I have many kukris and always thought they were yak, sheep, or goat leather. Please post one of bear leather.
bj
Old 5th January 2007, 10:11 AM   #9
spiral
Kukri scabbards were usualy buffalo or goat leather, but I have seen some leather I dont recognise as well, which probably includes yak,monkey, etc.
kukri scabbards are somtimes coated with various residues.
But perhaps bear meant bare? rather than coated?
I would like to see a kukri scabbard with brass stiching though! I havent yet seen one of those & i would like to.
Spiral
Old 5th January 2007, 02:17 PM   #10
Emanuel
Emanuel's Avatar
Red face
Hahaha
BARE it is, so sorry about that, don't know why I spelled it bear.
Hi Spiral, my comparison to khukri scabbards was only through the fact that there was stitching, no more. My other example of a khanjar does not show any kind of stitching, nor do the examples I've seen around the net, so I thought it strange.
Emanuel
Old 5th January 2007, 03:49 PM   #11
spiral
OK Manolo thanks for the clarification!
My kurdish khanjar has stiching to rear of scabbard. I assumed they all had?
How are the others made?
Spiral
Old 5th January 2007, 03:57 PM   #12
Emanuel
Emanuel's Avatar
Well the one in the pictures with the beige/brown scabbard has very tight stitching, you don't see the stitches. On the black one they are blatantly exposed and very large. Does this occur on other types of scabbards? Again, my mention of khukri scabbards is due to them being the closest thing I can think of to compare with this black khanjar scabbard.
Emanuel
Old 5th January 2007, 04:48 PM   #13
BBJW
BBJW's Avatar
I should have seen that "bear" was suposed to be "bare". It's hell getting old.
bj
Old 5th January 2007, 06:13 PM   #14
Emanuel
Yes, the wire stitching is fairly common in older pieces; it is made quite wide in your example.
Yataghan scabbard.
Old 5th January 2007, 06:23 PM   #15
Emanuel
Emanuel's Avatar
Thanks Rick, that looks just like mine, the stitching looks almost like coils/springs. So we have a similar Ottoman example then...that could put my khanjar somewhere within Ottoman territory, so Balkans sounds plausible. The dagger could also be Turkish.
Emanuel
