Old 4th April 2026, 09:21 PM   #1
45Auto
Default Possible Afghani matchlock
Hello everyone, I recently acquired this item. I cleaned the bore and found an old mud-wasp nest as well as some cobwebs. It's about .64 caliber.
Given the shape of the buttstock I'm wondering if it would be considered an Afghani style? Further, it has an interesting double compartment on the right side near the breach.
Information would be appreciated.
Thanks in advance.
45Auto is offline   Reply With Quote
Old 8th April 2026, 07:24 PM   #2
Klop
not my field of expertise but I lean towards India. And I believe the brass compartment is where the (burning) matchcord is fed through in a loop.
can you share a picture of the front end of the barrel? There seems to be some metal block on the side?
kind regards,
Eric.
Klop is offline   Reply With Quote
Old 8th April 2026, 08:50 PM   #3
David R
David R's Avatar
I would hazard a guess on Baluch, and the brass fitting is for the match. The plain tube is a snuffer to put it out, the pierced part to keep a live coal safe and live.
Old 9th April 2026, 02:48 AM   #4
kahnjar1
kahnjar1's Avatar
Not sure about the Baluch ref (see photo below of Baluch taken in 1879 according to caption. They have Sindi style muskets). I also lean towards India for the subject weapon, rather than Afghanistan, but quite correct regarding the brass tubes.
Stu
Old 10th April 2026, 04:13 AM   #5
Oliver Pinchot
This is a mid-19th century Indian military matchlock. Note the lug for a bayonet. Some of these were made with a sprung pan cover which retracts when the trigger is pulled and then snaps back in place once it is released.
Old 10th April 2026, 11:14 AM   #6
David R
David R's Avatar
I missed seeing the lug, you have a good eye there. Could be a bit earlier then, mid century caplocks were more common.
Old 10th April 2026, 04:02 PM   #7
Oliver Pinchot
Hi Dave, that logic follows in Western Europe, however in India and other parts of Asia, the matchlock never went out of use. Certain Himalayan groups still hunted with them into the 1960s.
Old 11th April 2026, 07:10 PM   #8
David R
David R's Avatar
Military context here, hunters etc not really in to bayonets.
Old 11th April 2026, 08:27 PM   #9
Oliver Pinchot
Sorry, that doesn't come into it. The point is that the matchlock ignition system remained in use into the twentieth century. What they were shooting at doesn't bear on it. And I'm pretty sure Himalayan hunters took more than an occasional shot at Chinese soldiers, in any case.
Old 12th April 2026, 02:54 AM   #10
45Auto
Hello all, thanks for the information.
The pan cover is manually opened and closed.
Very observant about the bayonet mounting hardware. That's what attracted me to this matchlock. The square mounting rings (one missing) were only located on the right side of the muzzle.
Old 13th April 2026, 01:55 PM   #11
David R
David R's Avatar
And a quick search leads to... http://www.vikingsword.com/vb/showthread.php?t=21080
and
https://worldbayonets.com/Bayonet_Id...a/India_2.html
Old 19th May 2026, 03:51 AM   #12
wildwolberine
wildwolberine's Avatar
Default Recommending YouTube channel
I’m not a collector & I don’t have much to add to this thread but I find these examples of local adaptation/innovation very interesting! I would like to recommend YouTuber & researcher @SebxArmedCafe9579. Doing great work analyzing & documenting uncommon central and east/Southeast Asian muzzleloading firearms. I noticed there is also a forum (Asiatic Muzzleloading and Armaments Research Network (AMARN)).
wildwolberine is offline   Reply With Quote
