Old 2nd February 2026, 09:10 PM   #1
Default Jambiya question
Dear members,
I have a simple question for the experts. I've handled a lot of edged weapons, but with very rare exceptions, I've always avoided Yemeni jambiyas, firstly because I'm not familiar with them, and secondly because I've noticed that some have hollow blades, meaning the blade consists of two pressed sheets of iron soldered together. I simply wanted to know if this is common, especially in older pieces. The blades usually have a pronounced central ridge; does this also occur in forged blades?
Some information on the subject is given here: http://www.vikingsword.com/vb/showth...hlight=jambiya
Old 3rd February 2026, 10:49 AM   #2
Glad you brought this up.
I have the same Jambiya somewhat ridiculed in the link. The blade on mine has a slight difference in curve. Nice steel with fine edges, 5mm thick at the forte of a much less prominant midrib. Horn handle. Clearly coming from the same workshop where the decorated metal on the scabbard has been hammered into the same matrix , which I imagine has been carved into a fine hardword like boxwood , used for fine wood engraving. Possibly metal dies too. Has been shown before and said to be Indian made. I could see a slight nod to Kashmir on the handle plates. However being from the same workshop and a distinctive style surely there must be sombody that can give better information. You really could use this blade to hurt people. A question, are all forms of these from "Arabia" to use a catch all phrase known?
Old 3rd February 2026, 07:06 PM   #3
I thought that the older blades were solid and later ones were made of 2 sheets of pressed steel..........
Old 3rd February 2026, 10:05 PM   #4
Hi Jose,
Are all new or recent ones of this construction?
Are the shown examples old or new?
Old 4th February 2026, 07:15 PM   #5
kahnjar1
kahnjar1's Avatar
I can not give much more to this thread, however Steven Gracie in his book JAMBIYA makes a small mention of the "spot welded" blades, without any concise comment as to their wide spread use.
Another consideration here could be that the knife itself is not primarialy intended as a weapon, as most seem to be worn as adornment/status statement, and the blade itself not regarded as the primary function.....just a thought!
Stu.
Old 4th February 2026, 08:58 PM   #6
Yes, of course! So far I know the jambiya is mainly a status symbol/part of the dress. But as a collector of blades, such a sheet blade is not very satisfying.
At least not for me!
Old 4th February 2026, 09:29 PM   #7
Pertinax
Pertinax's Avatar
Hi Jose,
Hi Detlef!
These are Khanjars from Oman, not Yemeni Jambiya, circa the second half of the 20th century. Take a look:
http://www.vikingsword.com/vb/showthread.php?t=22016
khalid.4545@gmail.com
https://encyclocraftsapr.com/khanjar-dagger/
According to my information, blades made from two sheets of pressed steel were made for tourists.
Sincerely,
Yuri
Old 4th February 2026, 09:44 PM   #8
Pertinax
Pertinax's Avatar
Yemeni militias.
Do they wear jambias for aesthetic reasons?
Old 6th February 2026, 12:53 AM   #9
I'm going agree with this. My information also says the same.
Old 22nd February 2026, 08:12 PM   #10
ausjulius
Stu.
No what it is so that many blades are not made in I doa or Pakistan and are not forged. They are a single 2.5 or 3mm sheet. Of steel. Then a rip of steel is welded on either side of the blade. Then a rod is welded as the tang. Likes like a jigsaw puzzle. Then the edge is heated up and quenched to make it a little hard and .. ta-daaaa
