Old 26th January 2025, 07:47 AM   #1
Sakalord364
Default Did officers also tie swordknots to suspension rings?
I saw this photo of an officer a while back, the photo is grainy but what I have seen he attached the swordknot to the suspension ring instead of the hilt? Have you seen this attachment method before, or did this guy simply violate regulations?
Sakalord364 is offline   Reply With Quote
Old 26th January 2025, 09:14 AM   #2
Radboud
Photo isn’t really clear enough to be certain.
Sword knots are typically fairly long; the end of the one in the photo is pretty much hanging where I’d expect if it wasn’t wrapped around the hilt.
In a practical (and traditional) sense there’s no reason to wrap it around the suspension rings, because it’s purpose is to be a lanyard securing the weapon to the users’ wrist.
Old 26th January 2025, 09:52 AM   #3
It does look like the belt suspension straps are under his jacket - I concur that the sword knot strap is hanging from the sword hilt, many have a dark strap with the metallic tassel at the end, so the strap part doesn't show in the somewhat fuzzy photo. I enhanced/sharpened the relevant area, not enough contrast, but I get the distinct impression of the strap continuing upwards behind the suspension ring toward the sword's upper guard and beyond - the only hilt part I could make out.
Old 11th February 2025, 08:36 PM   #4
Sakalord364
Thanks for the help, apparently these are Afghan officers from the 1950s, this is another example where the knot is clearly visible
