Old 9th July 2024, 03:52 PM   #1
Esotec
Default Viking axe with christian cross? Pictures.
I recently purchased this axe head at a reputable auction. The objects had very good provenance from 1930 onwards.
Is it just me or does the item have a Christian cross in its markings?
How common is it that the markings is so well defined?
I am happy to post more pictures if desired.
Esotec is offline   Reply With Quote
Old 9th July 2024, 10:22 PM   #2
Esotec
A few more pics.
Size is ca 14cm x 9cm.
Old 10th July 2024, 03:43 AM   #3
I'm moving this over to the European section.
Old 10th July 2024, 06:39 AM   #4
Radboud
Interesting object, what's it made of? In the photo it looks like bronze, but that could just be the light.
As for the cross... it could just be a geometric pattern or a cross that isn't related to Christianity. Of course the Viking society gradually converted to Christianity during the 10th and 11th Centuries so a cross wouldn't be out of place later in the Viking Era.
Who's the auction house, we need to be careful. Some, like Timeline auctions have a reputation for peddling fakes.
Old 10th July 2024, 08:36 AM   #5
Esotec
Its made of iron.
I bought it from a well known Swedish auction house. And the provenance was very good. One of the reasons I bought it.
I can see now that the color is abit of in the pics. Maybe due to the background.
Old 10th July 2024, 11:31 AM   #6
Esotec, who told you this axe is Viking ? Was it the auction house ?
Old 11th July 2024, 08:07 AM   #7
Esotec
The auction house described the object as
"Beard axe, Viking age, ca 750-950".
Old 11th July 2024, 09:48 PM   #8
toaster5sqn
My biggest concern would be the lack of any laminations showing in the corrosion as the most common manufacturing method for Viking axes was a softer iron body with a forge welded steel edge. This appears to be a homogenous piece of steel with no forging marks.
Robert
toaster5sqn is offline   Reply With Quote
Old 12th July 2024, 01:00 AM   #9
Lee
Lee's Avatar
Very interesting! It appears that the eye is somewhat collapsed and has lost considerable material on one side. Direct-on views of the more intact side might help. It is absolutely amazing how much appears to be intact, but this is not unique, and most of the axes I have seen have suffered sufficient corrosion that similar decoration would have been lost or obscured. Any hint from the salesroom about where this was originally found? I'll look for something similar in the references I have.
Thanks to the Internet Archive for a pdf of Peter Paulsen's Axt und Kreuz (1939): https://archive.org/details/AxtundKreuz
Though present throughout, look first at decorations on the pdf pages 36 to 40 (original pages 68 - 77)
Old 12th July 2024, 03:35 PM   #10
Lee
Lee's Avatar
In answer of Esotec's original question, I stumbled upon this sequence as translated by Google on pdf page 99, original page 195:
In the Viking Age, in addition to the previously mentioned crosses, axes and hammer more into the foreground. Snorri Sturluson says the Godessaga in Hakon Chapter 17, that there was a sign in the north that was holy to Thor, hammer sign is called and has a resemblance to a cross. We find on gravestones and coins that represent Thor's hammer symbols. At the end of the 10th century a slightly modified shape of the cross can be seen: the arms of the cross have crossbars preserved (Fig. 104). This is the sign of the advancing Christianity and became the popular symbol of Christians from the Baltic Sea region to southern Russia there. O. Montelius has already proven that the equal-armed cross not only came to the north as a Christian symbol, but for a long time was previously alive as a four-spoked wheel and sun sign until the Viking Age and only then was it taken over by the Nordic Christians. In this sense have we understand these signs of the cross on the axes.
Old 12th July 2024, 04:33 PM   #11
Esotec
Wow.
Thank you. That is some interesting reading.
Unfortunately, they did not mention where the ax was found.
But I have not yet received all the provenance papers and it is very possible that something is written there.
Apparently the ax has been in Charles Buttin's possession and later purchased from Philippe Missillier (Lyon) in 2016 at Kassel Waffenbörse 2016.
The eye seems to have received a serious blow so that it folded. However, most of the material seems to remain.
It was the well-preserved details as well as the good provenance that made me buy the axe.
Old 13th July 2024, 01:22 AM   #12
Lee
Lee's Avatar
I would be pleased to have such provenance on more of my own collection, such as it is.
I wonder if the pristine areas reflect so-called glodeskall?
Glodeskall refers to a compound of iron and oxygen (Fe.O.) created when an iron object is subjected to intense heat. Glodeskall
forms a shell ( skal ) or skin around the object and, as long as it is intact, provides some protection against corrosion.
However, it often has minute cracks, which may permit corrosion to quickly attack the object behind the shell.
From Swords of the Viking Age
Old 13th July 2024, 05:29 AM   #13
C4RL
Glodeskall = "Blacksmith's scale" I wonder?
I don't see "scale" on this head.
Amazing how crisp the non corroded parts of this head are, it'd definitely be interesting to know how it was originally found, how some areas survived free of oxidation especially as it's damaged so one wouldn't expect great care to have been taken with it!
It's not easy to tell from images but it looks a very uniform iron, no evidence of "grain" or impurities.
Interesting!
C4RL is offline   Reply With Quote
Old 14th July 2024, 08:41 AM   #14
Esotec
Yes, I'm really happy with the provenance.
Took two pictures that better show the surface of the blade.
Dont think its glodeskall.
I am also surprised by the condition. Maybe the axe lay in sandy soil/sand, maybe Peat?
Old 11th August 2024, 10:54 AM   #15
Esotec
Got the papers on the provenance today.
Unfortunately, it is not mentioned where the ax was found, which is sad.
But I received a copy of receipt of sale by Philippe Misslier at the Kassel Waffenboerse 2016 where it is stated that the axe was part of Charles Buttin's collection.
Unfortunately, it is a receipt for a lump sum purchase of x number of axes and other items where all have been included in Buttin's collection and some were published in Rumilly in 1933.
My axe is thus not specifically mentioned but one of many.
How do you think it affects the value of the provenance?
Old 11th August 2024, 12:37 PM   #16
Radboud
If your axe isn’t specifically identified in the papers then it’s the same as having no provenance in my opinion.
I’d take the auction house up on that, as there is no way to prove that your item is one of the axes mentioned.
Old 12th August 2024, 06:40 AM   #17
Radboud
I've re-read your post a couple of times to try and understand the paper trail, such as it is for this item. This is what I understand it to be; is it correct?
The vendor (via the auction house) claimed to have purchased this axe head at an arms fair in 2016 from the dealer Philippe Misslier as part of a lot that was proported to come from the Charles Buttin collection.
To support the claim a receipt from Philippe has been provided. However this receipt does not specifically identify this axe head; only that x number were included in the sale.
I see two issues with this 'paper trail'.
1. There is no evidence that this axe head was purchased from Philippe Misslier in 2016 and
2. There is no evidence that this axe head was part of the Charlees Buttin collection.
All we have to go on is the unknown vendors' word...
Old 12th August 2024, 07:57 AM   #18
Hotspur
Hotspur's Avatar
Case hardening? A harder candy coated softer metal.
Cheers
GC
Old 22nd August 2024, 07:28 PM   #19
Esotec
You are correct.
I'm in contact with the auction house to see what can be done. They will contact seller and see if he has any more documentation..
If they get an expert to authenticate the axe. That maybe would make things a bit better for me.
Remember that this is an well known auction house with a reputation to think about.
