Old 17th June 2024, 03:02 AM   #1
wildwolberine
wildwolberine's Avatar
Default Help with a couple old metallic arrow points
I purchased these two arrow points together. I believe the leaf shaped steel point is Cordilleran Peoples/Igorot, from Luzon. There’s some fine carving on the shaft behind the plant fiber bindings.
The other, barbed point is a mystery. It’s made from non-magnetic metal, perhaps brass? It’s quite thick and heavy.
I wonder if they were collected together in the Philippines, or if the barbed tip was collected in South America or elsewhere?
The shaft on this point is cane or a cane-like material. I feel the twine binding covered with a waxy substance is common in South American arrows.
wildwolberine is offline   Reply With Quote
