Old 5th March 2022, 04:18 PM   #1
RobT
RobT's Avatar
Default Indonesian? Short Sword for Comment
Hi All,
Given the look of the Damascus and the blade profile, I believe that the blade is Indonesian but to me, the hilt looks more Philippine (and more recent). The mostly single edge blade measures about 16.5" (about 42cm) long with the last 6.5" (16.5cm) double edged. The hilt ferrule is steel and oddly shaped. Even under magnification, I can't find a seam so I imagine that it was originally a pipe that was forged to shape. The sheath is ill fitting and probably not original to the blade. The cavity inside the sheath is cut to fit a very straight, double edged blade. While the sheath itself looks Indonesian, the two remaining steel bands have joins that that I have seen Philippine sheaths.
Sincerely,
RobT
