Old 3rd December 2004, 09:35 PM   #1
Jens Nordlunde
Jens Nordlunde's Avatar
Default Double katars are marked
Did you know, that double katars are marked?
The scabbard for the inner blade, the outer blade, is made so that only if the inner blade is scabbard in one way can it be scabbard. If the inner katar is turned, it can’t be scabbard. The guide how to scabbard the inner katar lays in the design on top of the side guards, make sure that the design on top of both side guards fit, it can also be two dots – when this two ‘patterns’ fits, the two katars can be scabbard.
