Old 1st November 2016, 11:53 AM   #1
Cerjak
Cerjak's Avatar
Default 16TH Century stiletto dagger ?
It has a cruciform blade
O.L. 29 cm ; blade L. 19 cm
Any comment on it would be welcome.
Best
Cerjak
Old 1st November 2016, 12:26 PM   #2
Isn't the blade a shortened one ? The handle, some crude replacement ? .
Old 1st November 2016, 02:57 PM   #3
mariusgmioc
mariusgmioc's Avatar
Very confusing piece. I believe only the crossguard may come from a 16 c stiletto but the rest is of much more recent artisanal production.
Definitely not typical stiletto.
Old 1st November 2016, 03:22 PM   #4
drac2k
Very interesting ; I think it may be more of a WW1 trench dagger;the blade looks to be made of a French Lebel bayonet.
Nice dagger !
Old 1st November 2016, 04:33 PM   #5
Cerjak
Cerjak's Avatar
Hi
Thank you for your answers and opinions
I should have post before some more pics and add more dimensions.
The blade width at hilt 1.5 cm /8mm so can’t be from a French Lebel bayonet who blade width is about 13 mm.The wood show real sign of age,and the guard and blade corrosion are homogenous so should be from the same period. Yes the grip is crudely made or I would say basic but again seems really old and definitively not a recent work. Also Similar blade geometry are found in 16-17TH stiletto dagger.
Let see what other members think about this small dagger..
Old 3rd November 2016, 12:13 PM   #6
Cerjak
Cerjak's Avatar
similar quillons are found in the 16th to 17th dagger
see pictures
Old 3rd November 2016, 12:58 PM   #7
see pictures
Yes but, not the blades .
Old 3rd November 2016, 05:39 PM   #8
mariusgmioc
Neither the hilts!
Old 3rd November 2016, 07:27 PM   #9
cornelistromp
cornelistromp's Avatar
it looks that this is a composite dagger, made from heterogeneous parts (not belonging together) in the second half of the 16th century, or a bit later.
The blade is a characteristic poniard dagger blade of the so called Bolognese type. North Italian. very stiff with a medial ridge on each side. see Picture
of a poniard in the MET 26.145.117
The style reminds me of the later ballock dagger construction with a steel ball/ballock guard without a pommel or pommel plate but with a small diamond shaped plate riveted at the end of the wooden grip. maybe you can post a Picture of it, Jean Luc ?
the whole thing looks coarsely constructed but was certainly usable.
in view of the blade and the guard is the origin probably north italian
best,
Jasper
Old 4th November 2016, 10:50 AM   #10
mariusgmioc
Hello Jasper,
I honestly fail to see too many similarities between the blade in question and the one in the photo you provided. The one in your example appears to be triangular with fullers on each face, while the one in the original posting is flat with two grooves/three ridges on each of the two sides.
Old 4th November 2016, 12:59 PM   #11
Cerjak
Cerjak's Avatar
best,
Jasper
Hi Jasper,
I have expected your answer about this dagger.
I felt strongly that this blade was not a recent pattern and from the same period than the quillon but I could not find similar blade geometry in my data.
I feel more comfortable with your about opinion that it is a composite and probably made during the 17TH century with 16-17th century component .
Best
Jean-Luc
Old 4th November 2016, 10:54 PM   #12
cornelistromp
Hello Jasper,
it is not triangular but a blade of Diamond section, both sides have a Long flattened ridge, running in the middle of the blade.
With this type of blades, often , at one side the ridge extends over the ricasso and at the other side the ridge stops before the ricasso, so that the thumb can be placed on a flat surface.
best,
Old 6th November 2016, 06:10 PM   #13
mariusgmioc
best,
Thank you for the clarification!
Still, quite different from the one in the original posting.
Not that I am very knowledgeable, but I haven't seen that type of blade before.
Old 6th November 2016, 08:40 PM   #14
cornelistromp
Quote Oakeshott
"that you have never seen it before means nothing unless you have seen them all, those hundreds thousands of blades"
best,
jasper
Old 6th November 2016, 08:49 PM   #15
mariusgmioc
Quote Oakeshott
best,
jasper
True indeed!
Old 13th December 2016, 09:12 AM   #16
Cerjak
Cerjak's Avatar
best,
Jasper
Hi JASPER
I found this dagger said to be Italian with same quillons and blade .
best
Jean-Luc
Old 13th December 2016, 12:08 PM   #17
Multumesc
Multumesc's Avatar
Nice dagger
Multumesc is offline   Reply With Quote
