Old 10th April 2016, 04:27 PM   #1
Question To repair is okay.
Just adding this link to show that even the best collections need repair or even restoration {I have a project coming up} at times to save what may be left of an object. Tell you what, Kate can come round my place and repair my spears, anytime .
http://australianmuseum.net.au/pacif...ns-on-the-move
Old 10th April 2016, 08:54 PM   #2
More.
http://australianmuseum.net.au/image...fiber-clothing
Old 13th April 2016, 01:28 AM   #3
Bob A
I'd be interested in the "archivally stable acrylic resin adhesive". I assume that, as in most modern archival preparations, it is reversible without damage.
Old 13th April 2016, 06:46 PM   #4
I might try some of these products.
http://www.conservation-resources.co...index&cPath=17
Old 13th April 2016, 08:55 PM   #5
Bob A
Thank you for the link.
Old 13th April 2016, 08:56 PM   #6
kahnjar1
kahnjar1's Avatar
Hi Tim,
I have used a couple of these in the past with good success. The many versions of Araldite shown in this list I suspect are not so readily available thru hardware outlets but the "handyman" version is. It comes in two versions here in NZ....a quick set (20min) and a 24hr version. From my experience, the quick dry is not as good or as strong as the 24hr, which will even hold broken gunstocks which are well impregnated with old oil! It will of course glue almost anything else as well.
PVA is of course the mainstay for wood, and also useful for resticking such things as leather and other fabrics which has come away from scabbards etc.
I have also used in the past a product called Selleys Knead It. Its a Polymer putty system which cures absolutely rock hard and can be filed and shaped to suit what you want. I suppose one could call it a "plastic steel". Available from larger DIY stores.
Stu
Old 13th April 2016, 09:14 PM   #7
Kubur
Kubur's Avatar
Me too i need an injection
Old 14th April 2016, 01:14 PM   #8
Ultimately what ever you use it has to be done with great care as to how it may appear after the restoration.
Old 14th April 2016, 08:50 PM   #9
kahnjar1
kahnjar1's Avatar
Absolutely!
Old 14th April 2016, 11:49 PM   #10
stekemest
stekemest's Avatar
It's hard not to make any jokes with "Kate" and "spear".
Hope that was not too sexist.
stekemest is offline   Reply With Quote
