Old 27th June 2015, 08:18 PM   #1
Roland_M
Roland_M's Avatar
Default Silver Pedang
This Pedang measures 71 cm without the sheath, 58cms out and carries a fine pamor blade that is 54cm long. It was in a very bad, heavily rusted condition as I bought it, not far away from a hopeless case.
After many hours of polishing and a final etching it is almost like a resurrection.
The well carved hilt is of horn construction and also shows circular piercings to both sides. The rest of the hilt is covered with sheet silver with floral decorations.
The scabbard is covered with silver with two suspension rings, one of the rings is lost. Both the upper and lower fittings are finished with a copper ring to the edges.
The blade is of a fine and absolutely flawless forged pamor construction with two fullers. It carries a very sharp edge and a non sharp hollow shaped back edge to the tip.
I think, it is from Lombok and quite old.
Special thanks to Detlef for his expert comment.
I hope the pictures are good enough and would every happy to read some opinions and to see other examples of this very fine and aesthetic type of sword.
Best wishes, Roland
