Old 25th April 2015, 05:37 PM   #1
Drabant1701
Drabant1701's Avatar
Default Feedback on etching atempt
I am new to etching so I am practicing on a Karud (?) dagger that I have. Its old so I figured its possible that its wootz or pattern welded. I am getting some results. Not a good one but Im getting some sort of pattern at least. some of the blade may have been hardened since it turns all black. Can you look at the pictures and comment one what you think it is (wootz? pattern welded? streaks of dirt?
Drabant1701 is offline   Reply With Quote
Old 25th April 2015, 09:45 PM   #2
Jens Nordlunde
Jens Nordlunde's Avatar
Maybe this picture will help.
Old 26th April 2015, 02:27 AM   #3
Oliver Pinchot
Good job on your first effort, Jens.
It's wootz, but the blade was overheated in spots during
the edge-hardening process. As a result, you see black
areas. Nothing to be done, so far as I know.
In my experience, the best wootz etches with ease. I hope
this will hold true for you, too.
Old 26th April 2015, 07:28 AM   #4
Drabant1701
Thanks Oliver and Jens for your help. It etches very quickly in weak ferric cloride. I etch for 5-10s then polish lightly with steel wool and then etch again and repeat. Problem is that to get a strong pattern I have to leave the brownish streaks, so I have to adjust my approach somewhat.
Old 26th April 2015, 08:51 AM   #5
Jens Nordlunde
The dagger does not belong to me, it belongs to Drabant1701.
I only made the picture a bit lighter.
Jens
Old 26th April 2015, 10:16 AM   #6
Drabant1701
Seems like a lot of the blade was overheated (marked red), i can only get a good etch higher up one the blade. I have however achived an etch that I am pleased with one the undamaged area.
