Indian matchlock musket or Torador
Early 19 th century,Rajasthan ,North west India.Ivory and silver inlays 190 cms long Longest gun in my collection |
NIIIICE!! Very nice piece Rajesh. Some cleaning needed but that is to be expected.
\Stu |
THANKS STU.,APPRECIATE YOUR COMMENTS,WISH I LIVED IN CHRISTCHURCH WOULD HAVE TAKEN SOME TIPS ON CLEANING,BIT SCARED SOMETIMES TO TOUCH OLD PARTS AS THEY CAN BE EASILY DAMAGED.ITS A VERY LARGE GUNA ND QUIET HEAVY NO WONDER THEY WERE CALLED ALSO AS FORT GUNS,REGARDS RAJESH
#4 | |
I note that the trigger bar is obviously bent on your Torador. Needs to be straightened so that the trigger is inside the slot underneath, and more importantly so that it does not accidently get broken off. Stu |
HI STU,GOOD OBSERVATION,AM BIT SCEPTICAL ON ALTERING OR TOUCHING THINGS COZ A SACRED I MAY DAMAGE THE PARTS,BUT I GUESS I NEED TO START BEING MORE ADVENTURIOUS AND GET THEM RESTORED ,CHEERS
#6 | |
Hello, try to use Steel Wool from Grade 00 (fine) to 0000 (superfine) and german oil "Ballistol" (penetrating oil). Steel Wool is not expensive and causes no scratches. Together with "Ballistol" (everytime after polishing with steel wool) and a lot of time, maybe you can see a damask pattern on the Barrel. Kind regards Roland |
#7 | |
Stu |
#8 | |
#9 | |
#10 | |
Stu |
#11 | |
REGARDS |
Hi Bandook. That is a really decorative looking Torador. And should clean up nice. My cleaning methods are similar to Stu's. Work's fine.
By the way all, I actually have a spare trigger and spring assembly for a Torador. I bought it online figuring one day I or someone else might need it. Might be the only "spare" around ? LOL Rick.
#13 | |
Hi Rajesh. Yes, I do have one Torador in my collection. It's in good condition as-is. But I've decided to make a shooter, so I will be taking the barrel off this weekend and sending it to my gunsmith. It will require the plugged end of the breech being drilled out, with the breech being threaded and a new threaded plug installed. Also, burnishing the bore clean and a new pan cover made. This will also allow the gunsmith and myself to see how the breech end of the barrel is designed. We will take pictures during the process, and I will post here as progress is made. Wish me luck!! LOL.
The photos posted by Stu of his Torador was most helpful in this regard.I have a third bedroom at home - which is no longer a bedroom LOL - that stores my collection. At present, it's a cluttered mess. All 4 walls are full, with multiple gun and sword racks, a long table, etc. I'll post pics once it's cleaned up and I order a couple more gun racks. As for display on the walls, I use different sizes of simple "L" hooks, covered with plastic tubing, masking tape, or brown colored electrical tape, depending on what I'm displaying. The rest of the long guns and pistols are mounted in vertical display stands, since there are too many to all display on the walls. I get the wood gun/sword racks from a place in Texas. They will custom make just about anything you want, at very reasonable prices. I can PM you with their information if you like. Rick.
Here's a couple of pics of my Torador...
linseed oil collects dust and never dries. It will weep if in a hot environment. beeswax with a little bit of olive oil applied hot is a better choice and more traditional.
#17 | |
#18 | |
YES ONCE YOU HAVE ORGANISED YOUR ROOM,DO POST PICTURES,WOULD LOVE TO HAVE A LOOK KIND REGARDS RAJESH |
#19 |
Please pardon me opening up an old thread, but just a comment on Linseed oil;
To preserve and feed wood, raw linseed is best, especially if cut with turpentine, as this helps it penetrate. If after giving the stock all it can take, it is rubbed hard dry with a cloth, no surface build -up will occur, and no stickiness. After this initial "feeding", the stock can have a little oil applied Very sparingly, just a few drops, and rubbed out with the hand until it feels hot due to friction. Put it to one side for a while, then polish hard again with a cloth. This can be done at any time to refresh the finish and will do no harm. The problem with linseed, is if too much is applied and this can create a thick gummy layer as Ward describes, Especially if boiled linseed is used. With linseed, it is good to remember that the oil that is rubbed Off is what counts! Thanks for your time, Richard. |
#20 |
THANKS RICHARD FOR YOUR INFORMATION,REGARDS RAJESH
WOULD YOU HAVE ANYTORADORS IN YOUR COLLECTION,PLEASE PUT THEM UP FO US TO VIEW,CHEERS |
#21 |
Rajesh,
I do have one, (In need of repair) and a couple of barrels, but they are still in the UK at present. Still, I do have some photos, so may start a thread as time permits! Richard. |
#22 |
THATS GREAT RICHARD,HOPE IT REACHES YOU SAFELY,GOODLUCK,REGARDS
