Old 5th December 2014, 03:06 PM   #1
Kubur
Kubur's Avatar
Default Moroccan Pistols
Dear All,
I look for information and photos of Moroccan pistols.
- not the Algerian ones with Coral, but the Moroccan with bone inlays.
Thanks
Kubur
Old 7th December 2014, 03:27 AM   #2
Oliver Pinchot
The most distinctive characteristic of Moroccan pistols is the form of the butt; it is almost perpendicular to the barrel and terminates in a conical cap. When decorated, silver, brass or iron studs are used. Bone inlays are not typical but if present, may indicate a later (or tourist) example.
Old 7th December 2014, 02:25 PM   #3
Kubur
Kubur's Avatar
Thanks
I have seen these pistols in your book.
There is another kind of Moroccan pistol with a circular / discoid butt.
Not for tourist. Often associated with miquelet lock.
Some locks are purely Spanish, others are influenced by Dutch productions.
Remember that the kingdom of Spain extended up to Holland before.
I know the bone inlays models that you mentioned, they are from the first quarter of the 20th c. They did the same decoration with some koummiya as well. Please, note also that these productions were not only for tourists but also for parades and fantasia. I will post examples of these objects, already sold.
Old 9th December 2014, 04:02 PM   #4
Kubur
Kubur's Avatar
The photos, the first pistol is what you said Oliver, the others are typical Moroccan pistols, 19th c., very similar to those of the Riff and the Moukhala rifles...
Best
Old 9th December 2014, 05:47 PM   #5
Kubur
Kubur's Avatar
Sorry the pistols above are all 19th, i will upload the 20th later (bones inlays).
Old 10th December 2014, 12:19 PM   #6
Kubur
Kubur's Avatar
The later, 20th, tourist piece? that I promised...
Old 10th December 2014, 04:56 PM   #7
Oliver Pinchot
In order to discuss these seriously, Kubur, better pics are called for. It would be interesting to see additional legitimate forms of Moroccan firearm emerge, however as it stands, none of these inspire particular confidence as to age or "fireability" except the last one in your earlier post, which is not only authentic but quite early-- it retains the original form of the English and Scottish pistols on which it was based, and is certainly datable before 1800.
Authenticity is contextual; one has to take the cultures which produced them and their intended purpose into consideration. For example, as you mentioned, if pistols of this form were made as props to be worn at traditional celebrations, then they may be "authentic" accoutrements, even though they were never intended to fire... and so on. I saw a vast number of these with circular butts in Moroccan souks, as I'm sure other forum members have. Are you able to examine any of them in hand? As for the last piece you pictured, yes, it's clearly contemporary. But that doesn't necessarily legitimize the others. Remember that there have been trinkets for as long as there were travelers to buy them. And that is a very long time. The example you show with a miquelet looks like a reasonable copy of a Spanish pistol, and the one following that evokes Belgian military pistols, but again, it's hard to tell much about their age from the pics. Then there is the question of what constitutes a form, and what is just a local copy.
What defines a tourist item also hinges on perspective: If you and I buy a well made and embellished contemporary dagger from a stall in the Meknes souk while a Berber next to us buys a similar one to wear to a wedding, is it a tourist piece because we bought one, or authentic because the Berber did? Too many factors play into the question, I prefer a simpler approach: Is the object intended to be used as a weapon, and how old is it?
Old 10th December 2014, 09:47 PM   #8
Kubur
Kubur's Avatar
It is wrong, the shape is older and goes back to the Wheelock’s pistols, not only the British ones, may be more familiar to you. More seriously about authenticity, we all know that. May be you didn’t get my point: you have another model of Moroccan pistol who is clearly not the one that you published. The pair that you published is North African, probably Moroccan. The circular butts are more common in Morocco and were indeed reproduced for parades or touristic purposes. I think also that the last one of the first series is older may be 18th c. The others pistols are 19th c. Yes, I showed one miquelet who is a copy of Spanish pistol due to the old relations between the two countries, Spain and Morocco. The miquelet called also snaphaunce for North African long guns. Please, to learn, it is important to listen others and to not be so categorical or haughty. Despite my comments I agree with your last sentence of course!
Old 13th June 2015, 10:32 AM   #9
Kubur
Kubur's Avatar
Another Moroccan pistol of mine
Kubur
Old 14th June 2015, 04:35 PM   #10
rickystl
WOW! I need to catch up on a couple of intteresting gun Threads here. I'll use the opportunity, and post a new Thread of a Moroccan pistol since it is picture heavy. And add comments to this, and another Thread from Rick later today.
Thanks, Rick.
Old 14th June 2015, 04:36 PM   #11
rickystl
Just a pic....
Old 7th May 2016, 09:28 AM   #12
Kubur
Kubur's Avatar
For research I just add this link
http://www.vikingsword.com/vb/showthread.php?t=3447
The Moroccan pistol butt has the same origins than the Turkish butt ball pistol... 16-17th European models.
