Old 1st August 2011, 11:46 AM   #1
spiral
Default Yemeni? Silver Cartridge belt or Bandolier
Hi Chaps,
I wonder if anyone here has insights into date & origin of this cartridge belt?
I am guessing Yemen but not realy my field, Any photos of such in use? I think its probably coin silver but havent tested it.
Theres variation on the lower end internal diameters of each tube, anything from 11mm to 14 mm.
I love how its been worn enough to have a slink where it fitted over someones hips.
spiral
Old 1st August 2011, 04:20 PM   #2
rickystl
Hello Spiral. What a terriffic item!!! Never seen one like it. I own an old beat-up leather one - Turkish I think? Where did you ever find it?
It doesn't look like it, but could it be Egyptian? The reason I ask: You mention the inside diameter being between 11MM and 14MM. From the late 1860's through the late 1880's there was a cartridge identified as a 11MM (.43) Egyptian, used by the Egyptian Government - and others I'm sure. (There was also a 11MM Spanish cartridge). It was a bottle neck cartridge with an 11MM bullet to about 14MM at the base of the case. Hmmmm, maybe your belt was made for that cartridge? Just a thought. If you have access or know an old cartridge collector you could try different samples and see if one fits best. This would give you an approximate time frame your belt was in use. Just an idea. In any case, a great find!!! If you ever decide to part with it........... Rick.
Old 1st August 2011, 07:46 PM   #3
kahnjar1
kahnjar1's Avatar
WOW!!! ENVY ENVY
Old 2nd August 2011, 09:55 AM   #4
spiral
Cheers Rick! It does look like the .43 Egyption would proberly fit then, With a base diameter of 14mm but would guess other old blackpowder & early smokeless cartrigides would as well? As you say I need to see a cartridge collector.
Thanks Kahnjar! Do you think Yemini seems right or could it be something else?
Spiral
Old 2nd August 2011, 10:18 AM   #5
Atlantia
Atlantia's Avatar
Hi Jonathan.
Interesting thing, don't remember seeing one like it before.
Drag it along to one of the military fairs near us and you might be able to find someone with de-ac cartridges for WW1/2 rifles to try in it?
Would .303's fit?
http://en.wikipedia.org/wiki/.303_British
Old 2nd August 2011, 01:32 PM   #6
Michael Blalock
Michael Blalock's Avatar
It does not look Yemeni or middle eastern to me. It could be from the golden triangle.
Michael Blalock is offline   Reply With Quote
Old 2nd August 2011, 07:19 PM   #7
kahnjar1
kahnjar1's Avatar
Spiral
I realy have no idea as to origin and have not seen anything like it before (sadly!) As to what would fit, there is a book (similar sort of thing to Gun Digest) called Cartridges of the World. This shows dimensions of all?? known cartridges split into Military, Sporting etc. I feel sure that you will be able to find someone local to you who has a copy you could borrow. I have a copy here but it would be quite a long job to sort out what would fit your belt, though if you would give me base and top diam and also cartridge length I will see if I can find anything that would fit. It could also be made to hold powder dispensers for muzzle loaders rather than complete cartridges.
Regards Stuart
Old 3rd August 2011, 12:12 AM   #8
spiral
Cheers Gene took it up to a friend today who dropped a deactivated .303 into it for me, it just caught on the rim {so diameter or the fat part of tube must be about 13.5 } but I dont think thats what it was made for.
In a bandolier the base of cartridge would need to be able to be grasped I think. So someting bigger than a .303 it seems.
Thanks Stuart, theres enough variation in the sizes or how deep the rounds should sit that without someone dropping exactly the right round into it I think it would be hard to be sure. Interesting though that it could also hold powder dispensers! Thank you much though.
Great input Michael! I am a more than a little surprised though! I thought the small soldered balls & fretwork in this style were certanly classical Arab tribal or possibly even Yemeni or beduin work silver work? But as I said not realy my field, gos to show a little knowledge can be a dangerous thing!
Ive handled much pre. ww2 silver work years ago mostly from Burma but some Thai, {Siam then of course..} & cant see any connection?
The lack of an obvious plant or animal symbolism in such hand made piece strikes me as very Muslim? {Although perhaps the symbols on the buckle might represent some creature in a very base form.}
Something of a mystery so far it seems! mmmmmmmm Interesting!
Spiral
Old 3rd August 2011, 08:50 PM   #9
spiral
Ok this is getting interesting a fellow forumite emailed me this photo today..
Clearly Very similar piece & workmanship. Cartridges look like heavy calibre late 19th century pieces to me.
Apparently from the Sheikh Faisal Bin Quasim museam in Quater. Where its displayed as a c.1910 Yemeni piece in solid silver according to my friends recollection.
So Arab manufacture seems extremly likely? Perhaps Yemini even? depending on the Quater museams research or provenance?
What makes it look non Arab to your eyes Michael? Could it be from a particular ethnic group or culture perhaps?
Spiral
Last edited by spiral; 3rd August 2011 at 11:39 PM. Reason: slip up in copy & paste that read appalingly.
Old 3rd August 2011, 09:06 PM   #10
Atlantia
Atlantia's Avatar
Very interesting Jonathan.
I gotta say that the cartridges in the pic look like Martini Henry.
But I think Rick's .43 sounds like a front runner.
The calibre of the cartridge will also help in dating. I'd guess that the date of 1910 is going to be pretty close (or slightly before) if the cartridge is right in the new picture. It looks like it's 'chambered' for pre copper-jacket amunition.
Also of course, if it's bigger than .303, then thats a hell of a slug!
Here's a picture from wiki:
http://en.wikipedia.org/wiki/Martini-Henry
With a few carts to compare with the .303 on the end, perhaps it'll give more of an idea of what you're looking for?
The description is:
(From Left to Right): A .577 Snider cartridge, a Zulu War-era rolled brass foil .577/450 Martini-Henry Cartridge, a later drawn brass .577/450 Martini-Henry cartridge, and a .303 British Mk VII SAA Ball cartridge.
Old 3rd August 2011, 11:03 PM   #11
spiral
Thanks Gene, the heavy calibre Brit cartridges look to fat at the cartridge base to be plausible I think, so agree .43 Egyptian seems most likely so far, although I understand from my .303 friend there were similar sized Turkish & Mauser rounds, {If I took that in correctly.} which I havent looked into yet. {He didnt have any to hand, sadley.}
I reckon the calibre is round the .43 to .45 range though.
mmmmmmmm
Think were getting nearer....
Spiral
Old 4th August 2011, 01:51 AM   #12
Michael Blalock
The chiseled pattern in the silver does not look Yemeni to me but who knows, it could be. I will look around and see if I can find some decoration that matches this pattern. It's an interesting item.
Old 4th August 2011, 09:15 AM   #13
A.alnakkas
A.alnakkas's Avatar
Nice belt, I think its yemeni. The chiseling looks identical to one of my yemenite jews made jambiya. Here are the pictures:
Old 4th August 2011, 10:14 AM   #14
spiral
Thanks Michael, all help appreciated.
Excelent Alnakkas! Wow! Thank you ! That realy clinches it as Yemenite Jewish silverwork I think!
Is there an inscription date on your Jambiya by any chance? It looks a lovely & unusuasl piece to my eye.
Spiral
Old 4th August 2011, 11:20 AM   #15
A.alnakkas
A.alnakkas's Avatar
Hey Spiral,
The inscription on the stamp doesnt show clearly, its too dirty and I fear cleaning it as it may damage the inscription.
Check my other yemenite knife (said to be jewish work. Well the maker name fits aswell):
http://www.vikingsword.com/vb/showth...ght=Abdullatif
So imo, your belt is yemeni and early 20th century maybe late 19th
Abdullatif
Old 5th August 2011, 12:00 AM   #16
spiral
Thank you for the link & your thoughs Abdullatif. They have helped as lot.
Jonathan
AKA spiral
