Old 16th January 2011, 08:02 PM   #1
Montino Bourbon
Montino Bourbon's Avatar
Default swap meet dha
bought this at a local swap meet along with the rencong that I showed a little earlier this week.
Where's it from? Should I polish the silver? Is this type of blade ever worth etching to see if it has an inserted edge? Am I verging on blasphemy?
thank you in advance for your input; this site is not only a wonderful source of knowledge, but fun as well.
Old 16th January 2011, 08:03 PM   #2
Montino Bourbon
Oh no! I posted it on the wrong forum! What do I do?
Old 16th January 2011, 08:17 PM   #3
I'll fix it Montino...
Old 16th January 2011, 08:26 PM   #4
Montino Bourbon
Thank you, David...
Old 18th January 2011, 11:41 PM   #5
Nathaniel
Nathaniel's Avatar
Bump!
Hello Montino Bourbon
I would say it's a matter of personal preference whether to polish up the silver fittings & blade.
Where is it from? Probably Northern Thailand/ Burma.
An etching may or may not bring out an insert edge, but would most likely show a good monosteel temper line.
Nice find
Nathaniel
Old 19th January 2011, 12:27 AM   #6
Nathaniel
Nathaniel's Avatar
Similar debate in another section...
http://www.vikingsword.com/vb/showthread.php?t=13168
Old 19th January 2011, 03:41 AM   #7
Montino Bourbon
Yes, I was following that one too; a very interesting discussion. I'm just wondering whether the silver on this is “patinated” and should be left that way (it's definitely “patinated”) or “dirty”.
How would it be treated in its place of origin? Does anybody know how a person from that area would keep something like this?
To polish or not to polish, that is the question!
Old 19th January 2011, 09:02 PM   #8
Henk
Henk's Avatar
I don't agree the debate in the other section is similar. While other weapons are not touched because of the patina, the keris is cleaned, partly because of esoteric reasons, but also because it is custom to do so with a keris.
i know that this explanation is very plain, and could be reason for critics but read the link and you will understand.
For this dha i think it would be polished in the place of origin. Removing the dirt and the black oxidation of the silver. Silver is ment to be shiny, with exception for Djogya silver. I have a small dha hilt and scabbard silver. I received it polished and shiny, not black and dirty.
My two cents, for what it is worth .....
Old 19th January 2011, 09:21 PM   #9
Lew
Lew's Avatar
You can always polish silver but leave brass alone
Old 21st January 2011, 06:01 PM   #10
Andrew
Andrew's Avatar
I would polish it--the appearance of the oxidation makes me think this is likely low-quality silver and it would be significantly improved with a polish. It's just not very nice-looking patina, and if it were still in its original culture, the owner would keep it clean and polished.
I do not, however, advocate for a blanket policy of polishing the silver on all my dha/daab, etc. Those with very high-quality silver often develop a gorgeous, lustrous patina that is almost blue. I keep those as-is.
