Old 4th September 2005, 11:30 PM   #1
Exclamation Electrolytic rust removal - please add your experiences!
I snipped this question from a thread (on another topic):
Originally Posted by RobT
Could you describe the process of electrolytic rust removal or direct me to a source of information for same? I would really like to try out the method.
Hi Rob,
It's really not complicated and you can adapt this method to your specific needs. A practicable introduction for home use can be found at http://www.htpaa.org.au/article-electro.php and you can google for loads of additional info.
I've found it not necessary to be too finicky with the degreasing step (just wash with soap) - you can always go for a second electrolysis if there happen to be persisting rust spots (discard the electrolysis solution after use if there's oil floating at the surface). As of now I have used this method only for fairly easy cleaning jobs and it worked out fine. So, not much else to add from yours truly.
However, I have acquired a few blades which really need preservation yet I have postponed finishing them due to complications like metal inlays (silver as well as brass) or problematic disassembly. Thus, I'd love to hear others' experiences, especially in more difficult cases!
