Old 28th September 2023, 02:35 PM   #9
Originally Posted by werecow View Post
Not sure... The peen has the same patina as the blade so it may have been an old frankensword. But it does not seem to have been sharpened, so perhaps it was just cobbled together by a previous collector.
I mainly bought it because initially that photo was oriented vertically, and as I was looking at a closeup on my PC it just felt like I kept scrolling down along the blade forever. Basically it looks twice as long as it should be. Obviously it's no bigger than most other cavalry swords but the comparison with the small hilt makes the blade look huge.
I did realize this was pretty much a standard cavalry blade mid 19thc and resembles those on the M1840 US sabers (many blades were Solingen made). Whatever the case, this 'assembly' (like the psuedo espada ancha I posted) could not have been made for actual use. The M1840 was termed by the men 'the old wristbreaker' because of the long, heavy blade which required unique dexterity to handle properly, and typically there was insufficient training to achieve that.
With that in consideration, these brass briquet hilts barely functioned with any notable effect even with the short hanger blades they normally carried, so trying to handle one of these formidable cavalry blades to any effect would be terribly balanced.
In that light, it seems that these 'creative' anomalies, if legitimately assembled as composite in period, were most likely intended as accoutrements for wear in remote frontier regions, and not for actual combative use. The notion of 'wearing a sword' is a traditional gesture in many situations, much in the manner of those worn in Masonic regalia etc.
It is in this area that I have suggested this possibility with the 'rapier' in discussion. On that note, referring back to the 'frankensword', the M1840 blades were seldom sharpened as they were not typically used, even though 'worn' during the Civil War. In reading through medical histories of that period, it was noted there were hardly ever any wounds from sword cuts, and the only wounds associated with swords were blunt force trauma.
On the length of rapier blades issue, as Fernando has well noted, the blades of both Portuguese and Spanish rapiers often reached almost ridiculous lengths, to the point that royal intervention even tried to regulate the length of them. The one mentioned (132cm or over 51 inches) would have been virtually impossible to wield successfully in the French or Italian schools of fencing, and would have been more aligned with the mysterious Spanish 'destreza' style, which Im sure was equally practiced throughout the Iberian peninsula.
By the beginning of the 18th century, the 'destreza' method, known in the literature as 'the Spanish fight' had waned in the Peninsula, where the move to shorter (thus 'faster') blades and transitional rapiers (and small swords) became popular. However, in the colonies, the destreza continued much as the traditional affection for the cup hilt rapier remained steadfast well through the 18th even into early 19th c....thus my suggestion for this sword as a possibility. The style of the images resembles engraved motif on numerous edged weapons that are Mexican in origin.
