Old 15th May 2006, 07:11 PM   #17
Henk
Henk's Avatar
Tim,
If you continue to use lemon juice you can soak the blade in the juice and scrub the blade with the lemon a few times a day. Works excellent with keris to get them clean before the etching with warangan. I don't do it myself but I've seen how it is done.
A. G. Maisey,
At school where I work we use to say, you never can ask a silly question because questions are not silly, you only can get a silly answer.
Pamor is the contrast between the iron and the nickle after etching with the warangang. The black iron and the white lines of the nickle. The lines you see on the blade made by forging is not the pamor. As I wrote above, I saw how a keris was etched with warangan. When I looked at the blade I saw the lines of forging on the white blade, just the metal color as Tim's tombak. According to these lines I thought the pamor would be of an adeg type. I told that to the guy who did the etching and he replied "just watch and get surprised" When the warangan was brought up, the pamor raised and the iron colored black. Result: pamor beras wutah with those fanciful spots and circlelike lines. I couldn't discover a single adeg pamor line on the blade.
