Old 3rd January 2018, 03:25 PM   #10
Alan's post quoted from the other thread: http://www.vikingsword.com/vb/showpo...9&postcount=42
These comments are relative to the blade only of the second keris.
In my opinion this is not a Banten blade.
Typically the Banten wilah has a boto adeg blumbangan, the blumbangan of this keris is square.
There are two possibilities:- Mataram or Pajajaran
Condition and garap of the blade implies Mataram, but the dress is contrary to this.
It is very difficult to consider Pajajaran as possible because I have never seen a blade accepted as Pajajaran in such fine condition as this one:- I have no basis for comparison. However, the slightly concave gandhik is not a feature usually found in a Mataram blade, and a ron dha of this style is not typically associated with Mataram. So, although difficult, my inclination is to give this blade as Pajajaran.
In any case, it is old, it is fine, it is a very desireable.
Dresden 2886 has a Mataram blumbangan, square but not particulary large; the body cross section is the typical Tuban rotan, it does not have a ron dha that is classifiable, ie, it does have a ron dha but that ron dha cannot be aligned to an accepted form, however, I note that there is a possibility of corrosive damage to the greneng of 2886, which has impacted the ron dha; 2886 lacks kruwingan. However, the pawakan is similar to the pawakan of the keris under discussion.
Kai, I can see no similarity at all between Dresden 2899 and the keris under discussion. Dresden 2899 even uses a metuk instead of mendak and is of totally different dhapur and garap. Can you please tell me what the similarities are? Thanks.
