#31 |
The possibility that Italian blades came to Germany in this times makes absolutely sense, as vice verse. See this book from the museum in Berlin, 2 German Katzbalger, both blades north Italy…only the Bidenhänder is completely German made. So the trading around 1500 worked even without the European Union…
#32 |
Two examples of Katzbalger with Italian blades…
#33 |
Blades north Italy
#34 | |
#35 |
#36 |
The castle tower mark, with 3 or 4 points, often seen on wide Italian blades from the end of the 15th century, are all punched into the blade and without latten, as far as I know.
The mark of the sword under discussion is chisseled and finished with a latten inlay. This in combination with the orb and cross does not indicate an Italian origin.I would look more towards Solingen or else. best, jasper Last edited by cornelistromp; 8th July 2021 at 11:01 AM. |
#37 |
Also possible jasper, all which we are doing are speculating, nevertheless on a high standard. In such cases, after more than 500 years, nobody could be for sure how or who the manufacture was nore with which components they worked. Anyhow, they where for sure master of their craft, this and the historical terms made this field so fascinating for me!
#38 | |
While the use of latten, as suggested, is notably a Solingen (or Passau?) convention, I would note that this 'castle' mark (with four crenellations) is more to the example shown in the excerpt from Lenciewicz , where it is shown as from 'Italia', however in profile it seems markedly different from the discussion sword example. The particular configuration seen on this blade appears to me more of a 'trident', and with the obvious traditional connection to the 'gladiator'. The use of latten does not confine its presence to Germany, however the use of the cross and orb does seem to do so. This compounds the familiar problem of makers from one country or region, working in other areas retaining their styles, character and convention in their work despite the contrary geographic classification. For example, cuphilts of Milanese form made in regions of Lyon in France etc. The plot thickens
#39 |
For what’s it’s worth, Milan is also a Catholic Archdiocese headed by an Archbishop whose symbol is a double cross. ”The Archdiocese of Milan is the metropolitan see of the ecclesiastical province of Milan, which includes the suffragan dioceses of Bergamo, Brescia, Como, Crema, Cremona, Lodi, Mantova, Pavia, and Vigevano.” (source: Wikipedia).
I would just make the observation that the Katzbalger under discussion has a Germanic looking blade (IÂ’ve heard similar diamond cross section shaped blades described as Saxon in style). Solingen was wellknown to add other famous bladesmithÂ’s marks on their blades. The Italian swords shown so far with the trident mark all look typically Italian: flat and wide with very shallow fullers. ItÂ’s possible of course that the bladesmith was very versatile and also produced Germanic looking blades for the Germanic markets, or even traveled to Solingen to work there (?), although these guilds were pretty much closed shops so he would need special invitation. |
#40 |
#41 | |
![]() cogwheels, twig, hogsback........the name game seldom touched in the discussions on edged weapons over terms they are called by. Mann's catalog is fantastic, and one of the most valuable references I have ever bought. |
#42 | |
Well observed Victrix! and you have brought up a very salient point. The Solingen situation was indeed very controlled, and the guilds very powerful. There are references which describe limitations to the number of swords, knives blades which could be produced in regulated periods of time. While it is known that there were instances of a number of German smiths who went to Spain, France and Holland to work (not aware of to any Italian centers)....the situation does not seem to have been reciprocal. The 'influences' of Italian arms and armor does seem to have been well established as conveyed into these other arms centers, and in many cases, as for example Spain, was provincially present in Italy, their arms were well known in Spain and its dominions. Returning to the case in point, the observation that latten was not used by Italian makers or artisan engravers is intriguing, and I was unaware that this otherwise European affectation not carried into Italian centers., |
#43 |
with post #36 I didn't mean Italy specifically but generally punched blade marks are not inlaid with latten. (of course with exceptions).
This applies to both Italy and other countries such as Germany The italian examples of the Castle tower mark are all punched, the mark of the katzbalger in post 1 is "incised" and inlaid with latten. the orb and cross is (more) common on blades from solingen, eg several members of the Wundes family used these, Iohann Wundes in the second half of the 16th century. The two examples of orb and cross in this threath , attributed to someone else, I believe are the marks of Iohannes Wundes. Then the blade geometry, a ricasso and a diamond shaped cross section can be found on the most famous katzbalger in Vienna, but also on a couple katzbalgers in Dresden, probably all of german origin. @ fernando attached a tower and a rake ;-) best, Last edited by cornelistromp; 10th July 2021 at 09:21 AM. |
#44 |
So it could be that Sir James Mann was not such romantic knight; more of a fan of gardening
#45 |
the katzbalger of Ulrich von Schellenberg mentioned in post #43
#46 |
Gorgeous
#47 |
From all Landsknecht swords world wide which I know or ever saw the most beautiful Katzbalger! Typicall in form and shape for this type around 1515/20! Great pics, thanks!
#48 |
Well, understandable considering the English love of and expertise in gardening. Maybe if he he had an ovicultural background, he might have seen a sheep-comb:
#49 |
