#31 |
Hi Ariel,
Thanks for reply. I basic terms I was aware of the fact that the surface of the blade must be etched to reveal the grain structure however, the main thrust of my question was in relation to how the blade should be prepared for etching, and what chemicals or agents should be used to etch the metal. Gordon |
#32 | |
- Clean the blade with soap and water and dry it out, then clean it again with alcohol to remove any residue of dirt, wax, oil or whatever may have been applied to it in the past; - Dilute wine vinegar in warm water in 1:4 ratio of vinegar to water; - Use the mild acid to dip the blade into and leave for half an hour, then check for a pattern, or, if the blade is too long and you do not have an appropriate size container, rub in the acid and see if a pattern starts to appear. There are other acids, which would probably produce better results, but vinegar is easy to obtain and not really dangerous (no toxic fumes and if you get it on yourself, you won't be harmed), which is why I have opted for it. Sincerely, Teodor |
#33 |
Difficult question, some people etch with vinegar like Teodor describe, others use only Ferrichlorid but there are various other etching agents. Most of the time collectors swear by their technic as only good one.
I think that different steel react better with one or the other. And it depend on the wished result. I personally etch as well with vinegar similar as described in up but heat the etchant and blade, the reaction is faster and deeper. Of course you get better results when the blade is fine polished and free from rust so far possible. Regards, Detlef |
#34 | |
Hi Gordon, a cheap and simple way to test a blade is to hold it under hot running water (must be hot enough, to burn your hand). If it is mechanical damascus, one can recognize the structure clearly after a few seconds. Roland |
#35 | |
Thanks very much, that's good information, and as you say quite safe. Not possible to use a container, so I'll opt for applying the solution by hand. I appreciate your assistance. Gordon |
#36 | |
Many thanks to you also, and I do understand what you say as regards the temperature of the object and etchant; I'll opt for vinegar and see what appears if anything?? Regards, Gordon |
#37 | |
Very interesting and helpful; it seems a combination of heating the blade with hot water and applying the vinegar solution will produce the desired result if there's anything to be seen. Thanks for this additional information. Regards, Gordon |
#38 | |
2)Why dilute the acid? It is only 5 or 7% to begin with? Is this to increase the working time? IF you are doing the brush on method, would you leave it undiluted? |
#39 | |
to clean use first acetone and secondly renaissance wax. My experence: it does work excellently on my yataghans, bichaqs and few Indonesian cold weapons I do have. |
#40 |
I am impressed! This is one of two amazing swords from Aceh that I have seen!
The first sword I saw had the original old English mark under languet . |
