Closed Thread
Old 21st February 2016, 04:15 PM   #121
estcrh
estcrh's Avatar
Originally Posted by Emanuel
I hope our forum smiths do chime in on this. If you polish and etch an old wootz cake/ingot you see the pattern. No forging required.
Emanuel, I have never seen an old wootz cake so I could not respond to this but what happens once you start forging this old wootz cake, you can not make a blade from a polished and etched unforged wootz cake/ingot, it needs to be forged. Are you suggesting that anyone can forge a watered steel blade from it or did it take specialized knowledge in order to do this?
estcrh is offline
Old 21st February 2016, 04:56 PM   #122
mahratt
mahratt's Avatar
Yes, it is. And, too, there is about this in the articles of the 1840s.
mahratt is offline
Old 21st February 2016, 05:04 PM   #123
estcrh
estcrh's Avatar
Microstructure of Steels and Cast Irons, Madeleine Durand-Charre, 2013
estcrh is offline
Old 21st February 2016, 05:15 PM   #124
Excellent, and thank you guys again for responses to my questions. This discussion has truly developed dimensionally by the various and most salient angles you have all brought up.
While the original query tendered in this thread by Mahratt seemed to be rather straightforward and answerable in a similar response, it seemed to defy such an answer.
While it became almost frustratingly clear that a direct answer to the exact or defined disappearance of old wootz making skills was not exactly placeable to such a defined time, especially universal to all wootz locations, it has been fascinating to see all these angles and facets to the problem.
Mahratt, I must thank you for bringing up this most interesting topic, and for me, for prompting me to finally approach a subject I have admittedly long avoided. I also appreciate that you continue to reiterate the interactions between you and others posting as to the salient points you are discussing. Most helpful to keep the thread topic on course.
Ariel, I really liked the factor you brought up as plausibly being associated in this situation, that of life span and generation diminishing of skills in accord with that of demand. While the pro and con of this theory were of course addressed , it is fascinating to see critical thinking and well presented responses placed........this is true historical detection, and all of you guys carry it through perfectly!
Emanuel and Estrcrh, again thank you guys for your patient and most intriguing explanations and descriptions on the actual wootz making processes.......I think I really am starting to understand this stuff!
Estcrh, you continue to amaze me at your incredible abilities at locating all these articles and material and posting the segments here, thank you!
Outstanding work everyone!
Jim McDougall is offline
Old 21st February 2016, 06:23 PM   #125
The issue of inherent ingot patterns and the final blade patterns was discussed extensively on a Russian forum with professional bladesmiths, including the "dean" of Rusiian blademakers, Mr. Leonid Arkhangelsky. According to them, there is no doubt that the inherent structure is important, but only a true master is capable of creating complicated patterns seen on Persian and later Indian blades.
Only Persians with their secret tricks of forging were able to create rich and complicated patterns like Taban or Khorasan.. Indian masters were using a different technique: their hallmark was the "salt-and-pepper" pattern in which dendrites were crushed into small spheroidal segments. After ~17th century there was an inflow of Persian masters into India, and the patterns of Indian blades switched to the complicated Persian examples. Syrian pattern is well-known as Shams: low-contrast, short, almost straight lines.
They all used the same Indian ingots, but the final results were different.
Why?
As bladesmiths told me it all likely depended on the technique of forging: turning the billet in a predetermined way to create twisted patterns of dendrites, keeping the pounding in the same position/direction for the Shams, or beating the hell out of it to obtain the Indian "crystalline" wootz. And on top of it, heating the billet to a certain color between forgings was also crucial.
Even on the same blade one can see different patterns: even the best Taban blades always have almost "shams-y" pattern close to the edge, the result of more vigorous pounding in one direction.
And that is what happens now: metallurgists can make beautiful wootz ingots with a pattern indistinguishable from the old Indian ones, but the bladesmiths do not have secret "protocols of forging" that were worked out over multiple generations by Persian masters.
Anosov figured out how to make wootz ingots, but his blades had coarse and simple pattern: he did not know how to forge his material.
And that is the real secret of wootz.
ariel is offline
Old 21st February 2016, 08:45 PM   #126
Emanuel
Emanuel's Avatar
No Eric, of course I am not suggesting that.
My apologies as I am no smith and all I write is based on what I've learned from others. What I have been saying again and again is that the fine watery pattern seen on wootz metal is a result of the initial smelting process. Yes the pattern can be modified mechanically through forging of the cake/ingot/billet into a bar or blade, or whatever at a later stage. The point is that if the smelting process was successful, the basic pattern will be there in the cake as soon as you remove it from the crucible. Temperature control and correct charging of the crucible seem to be the critical factors to getting a good quality steel with a pattern.
The forging process is a separate thing altogether. Temperature control is again key to maintain small grain in the material. Large grain will make it brittle. The process for forging a wootz vs. non-wootz billet will be similar but the range of temperature a wootz billet will take is smaller since the pattern breaks down at higher temperatures. A bladesmith that does not know these temperature constraints will ruin the fine wootz pattern no matter what he does.
Here is a nice summary of the process from Greg Obach, who is also on this forum.
http://users.unitz.ca/gthomas/myweb4...n_of_wootz.htm
Emanuel is offline
Old 21st February 2016, 10:54 PM   #127
mahratt
mahratt's Avatar
It is a common misconception. There is information that the blades of wootz steel Anosov, very appreciated in the Orient (at local residents).
mahratt is offline
Old 22nd February 2016, 02:17 AM   #128
It sounds to me like Pavel Anosov (1796-1851) was primarily involved in research on the technology of crucible steel creating bulat/wootz while he was working at Zlatoust. The apparently highly regarded swords that were created using his findings in creating bulat were not only regarded as examples of 'fine art' but superior in their combat performance vs. those with steel from Solingen, Toledo and London .
From what I read he found four ways of producing the bulat steel, including direct reduction from ore; decarburization of cast iron with iron oxide; melting cast steel into mold and reacting iron and carbon in crucible.
As, again, I am not a metallurgist I would note only that these do not seem to include 'forging'.
Yet the bulat steel blades used with his processes seem profoundly highly regarded, and as 'art', so I miss the point on any deficiency regarding his not knowing how to forge the steel. Apparantly he made some blades himself for some of the more prominent researchers also engaged in wootz studies, and those were also highly regarded.
Also it seems that the noted detractions in his research material were apparently deliberate as he was guarding the secrets of his discoveries, which were indeed 'lost' again for a time after his death.
It certainly sounds like his blades, and research were highly regarded, and again most interesting to learn more about the bulat history. I had heard of it before but was not sure of connections in the wootz matters.
Old 22nd February 2016, 03:09 AM   #129
Jim,
Anosov shoud be honored for his re-discovery of the process of obtaining raw wootz material and his insight that it should be forged at low temperatures. However, he simply did not have access to the old "recipe" of forging complex patterns ( akin to Taban/Khorasan). In his defence, only one of the contemporary wootz smiths is capable of doing it, and doing it with long blades.
There is a lot of information on Anosov's blades in the new book by Kirill Rivkin. He also characterizes them as pretty simple .
AFAIK, his blades were never produced for mass use or export; he made only a few examples. I am unaware of his blades being used as fighting implements anywhere in the world.
He published his report in 1841, but was transferred as a governor to Tomsk in 1847, where he could not continue his work.
After his departure production of bulat in Zlatoust has stopped: his instructions about the process were deliberately brief and incomplete. A couple of workers in Zlatoust who actually did the job, produced a small number of blades, and then it was just like in India and Iran: skill transfer stopped and the secret was lost again.
As an example of Anosov's bulat ( wootz) work, here is his famous hunting knife that he presented to British geologist Murchison who visited Zlatoust.
It was sold at Sothebys (?) for something like 50,000 GBP ( I might be wrong here, but the sum was obscenely high)
Another one is his shashka: look at the pattern, pretty coarse and simple.
It is bulat, no doubt, but in the best possible case it is Sham.
ariel is offline
Old 22nd February 2016, 08:54 AM   #130
mahratt
mahratt's Avatar
Anosov received high quality wootz in a factory scale. Bulat (wootz) producted, blades - forged. Here is their description: "The tracery wootz are small, dark background - Taban"; "Large tracery wootz - Kara-Khorasan"; "Explicit patterns and large - Kara-Taban". Wootz steel production at the Zlatoust arms factory was massive. No wonder that Paul Petrovich Anosov in 1841 in preparation for printing his essay "On the Bulat" abandoned old Asian names, and introduced a new - "Russian Bulat (wootz)".
In Zlatoust weapon factory owned wootz steel forging technology, were able to properly temper the metal. Finished blades has a surprisingly high resistance and elasticity.
In 1839, its wootz weapons exhibited in St. Petersburg. Russian Bulat (wootz) gets great reviews at the third Moscow manufactory exhibition in 1843. Blades of Anosov Bulat (wootz) we tried to buy in collection of rich collectors of weapons of the 19th century.
Excellent reviews can be heard on all sides. For example, in 1851 at an exhibition in London exhibited Anosov wootz blades.
It is known that personally Anosov was made more than two dozen blades sabre and a plurality of blades knife of the Russian damask steel with excellent designs and Khorasan Kara-Taban. The fate of most of them is still unknown. Previously, a fairly complete collection was kept in the Hermitage, but now there is only one sword (Kara-taban) - Grand Duke Mikhail Pavlovich.
Once in 1847, Pavel Petrovich Anosov leaves the production plant in Zlatoust damask steel is sharply reduced. An indispensable assistant in smelting wootz Anosov was a master, Nikolai Shvetsov. After retiring Anosov he continued to producted wootz, but he was secretive man, and passed the secret of its manufacture only the eldest of his four sons (also, incidentally, worked as a blacksmith in Zlatoust), Pavel Shvetsov.
In the 1850s, damask steel Zlatoust has made only by special order. This is attributed to the fact that at that time started a broad campaign for casting artillery barrels, to which all industrial reserves of the country were thrown.
mahratt is offline
Old 22nd February 2016, 12:15 PM   #131
I would love to see a documented Anosov's blade with Taban or Khorasan pattern. In the absence of such, quotations from popular magazines carry very little value.
Not for nothing he presented his creations as "Russian bulat" instead of specific names. All of them that I know were of a simple Sham structure.
ariel is offline
Old 22nd February 2016, 02:21 PM   #132
Emanuel
Emanuel's Avatar
Verhoeven always merits a re-read
http://www.tms.org/pubs/journals/JOM...even-9809.html
Emanuel is offline
Old 22nd February 2016, 05:23 PM   #133
Ariel, I must thank you for the detailed and well explained perspective on the obviously very complex circumstances of wootz and the many variations of its product blades.
Mahratt, I also thank you for the interesting perspective that you present on Anasov as well.
As someone who has studied weapons as long as I have, it is really a great pleasure to finally have a grasp of this complicated subject matter in at least much better degree.
What I truly appreciate is the inherent knowledge of the history and scientifically oriented substance on these subjects displayed by you guys as well as Estcrh, Emanuel and Kronckew.......I admire that very much.
While most of this data seems historically stable, there do seem to be some differences in the perceived nature of the blades in the type of patterns produced etc especially as concerns the profoundly important work of Mr. Anasov.
While these differences seem to be inconclusively determined, especially as these are mostly no longer available, or as it seems, several had been with further examination pending, these factors of course would be subject to varying views depending on the reviewer.
What is most beneficial to myself and other readers as these things are discussed, is the well thought out and presented views as seen here, which give us excellent perspective and supportive evidence for all sides.
It does seem almost metaphoric as these discussions are in essence being forged much as the blades, and being crafted in sort of the same way.
Fascinating!
Old 22nd February 2016, 09:14 PM   #134
mahratt
mahratt's Avatar
I do not support reading popular magazines and books published today. I prefer to read historical sources. So I read Anosov and what he wrote about his work. I think there is no doubt in the words Anosova?
I understand that many in the forum do not speak Russian, so I give the translation, the selected phrase:
1) etching on the plate (wootz) were large curls (tracery), "Kara-Khorasan". Another experiment was repeated with a simple iron. The same result was obtained. Resulting in a small plate wootz was also a "Kara-Khorasan".
2) Get the "Taban" (think about it, "Kara-Taban") with medium curls (tracery) and a dark background.
mahratt is offline
Old 22nd February 2016, 09:31 PM   #135
Jens Nordlunde
Jens Nordlunde's Avatar
mahratt,
I am wondering why you use space on Vikingsword with Russian texts, whom only a handful of the members can read - maybe. If you want to quote thise texts, you should translate them to English - which is the language on this forum - or leave them out.
Jens Nordlunde is offline
Old 22nd February 2016, 09:45 PM   #136
mahratt
mahratt's Avatar
mahratt,
Jens, forgive me. I do not blame that Anosov wrote in Russian and not English. I posted here page Anosova authentic work, that there was no doubt that I give precise citations (rather than data from popular magazines).
At the same time, I specifically gave at the beginning of the translation. Once again, I apologize
mahratt is offline
Old 22nd February 2016, 09:47 PM   #137
I have shown pictures of 2 Anosov's blades: both are Sham.
Any PICTURES of documented Anosov's blades with Taban or Khorasan?
Nothing less than that will suffice.
ariel is offline
Old 22nd February 2016, 10:06 PM   #138
mahratt
mahratt's Avatar
I showed pages of authentic books Anosov of wootz (1841). I hope no one will argue that Anosov - written with no errors? (He understood the wootz) At the same time, I did not say that did not Anosov damask blades of Wootz steel such as "Sham". There were more than other blades. But did Anosov and "Kara-Khorasan" and "Taban".
On one blade of the "Kara-Khorasan" had 10-20 blades from "Sham". Can someone show 10 blades Anosova? I think the analogy is clear? Blades Anosov save too little. But Hermitage has blade Anosov of wootz steel "Kara Khorasan". Anyone can go to St. Petersburg and look at this blade.
mahratt is offline
Old 22nd February 2016, 10:32 PM   #139
The excellent entries continue, and Mahratt thank you for adding the translated captions to the Russian sources you provide.
However, you and Ariel are digressing from the theme of the thread.
As I have stated I am enjoying learning more about wootz, but while I think we have properly saluted Pavel Anosov for his outstanding contributions to bulat, I believe we can leave behind the business about which type of blades were produced by him.
Perhaps you and Ariel might find a way to return to the wootz topic beyond the Anosov fixation ?
Thanks again for the great entries outside this digression, and I think the conflicting views as I noted, give good perspective which might be pursued outside this discussion.
Old 22nd February 2016, 10:45 PM   #140
The REAL modern wootz!
I give you examples of bulat blades by a Georgian master Zaqro Nonikashvili.
Last edited by Jim McDougall; 23rd February 2016 at 12:02 AM. Reason: confrontational wording
ariel is offline
Old 22nd February 2016, 10:47 PM   #141
Emanuel
Emanuel's Avatar
Here is an excerpt from Ann Feuerbach's "Damascus Steel and Crucible Steel in Central Asia" American Society of Arms Collectors Bulletin 82.
The microstructure indicated that this was a high-carbon steel which was slowly cooled. Electron probe micro- analysis indicated that it contained small amounts of other elements, including manganese. This is significant because one of the most famous Damascus patterns is called Kara Khorasan (black Khorasan). In order to form this pattern, the original bulat needed to be high-carbon steel with specific impurities that was slowly cooled.
p.38
After many experiments with different plants and other carbon-containing substances, he [Anosov] concluded that the form of the carbon was unimportant but the amount of carbon in the steel was crucial...He concluded that steel should be pure in order to produce a pattern. This we now know to be true up to a certain point, but we also know that trace elements are necessary (Verhoeven et al., 1998, pp. 58-64), but these need to be present in an amount which Anosov was not able to detect. He studied the effect of titanium, manganese, silicon, chromium, silver, gold, aluminum
and platinum. While performing these studies of alloys, he independently concluded that silicon effects the formation of graphite, that chromium increases the hardness and improves the finish and discovered the effects of other alloying elements....Anosov also discussed the characteristics of the shrinking phenomenon and the necessity of slow cooling for crystal growth as well as the necessity of repeated forging at low temperatures and the different methods of producing different patterns. Textual, archaeological, ethnographic and modern replication evidence shows that these methods can produce steel with a Damascus pattern. Anosov succeeded in producing Damascus steel swords with the characteristic pattern and properties, including swords that could cut silk in the air and bend to a 90 angle and spring back with no apparent structural damage...Anosov only lived long enough to publish an abridged version of his research. This paper, "On the Bulat", was published in the Russian Gorny Journal in 1841 and was translated into French and German in 1843
p.40
So the ore would have been important to the extent that it included trace amounts of manganese, silicon, phosphorus and other elements. These trace elements facilitated the creation of the dark bands seen in Kara Khorasan pattern. Greg Obach experimented with steels with trace quantities of these elements. See his results and decide if it's Khorasan or not
Simplistically then, we're discussing a base dendritic pattern in a high-carbon steel that is the result of the metal smelting process, through more or less slow cooling of a crucible charge heated to mostly liquid phase.
This is followed by a mechanical deformation of this pattern through the forging process, either by fullering, or grinding/cutting grooves into the blade. The grooves are flattened, resulting in the
Mohamed's Ladder pattern. The same fullering process would be used on a homogeneous plain steel blade, you just don't get any pattern.
I guess the original Ladder pattern was simply the by-product of the drawing out process of the cake to a bar that could become a blade. A fuller may have been used at first to move the metal, while later grooves might have been cut into the bar on purpose to expose deeper layers and accentuate the patterns.
As far as I'm concerned then, Anosov understood the first step, producing the high-carbon crucible steel with visible pattern. He may not have known which trace elemental amounts were most effective at producing the darker contrast bands due to the technical limitations of his age.
Whether or not Anosov replicated the precise mechanical deformation in the second step is irrelevant to me. Modern smiths now understand both steps pretty well. Does the "secret" of whether you should strike the blade 40 times this way as opposed to 50 times the other way really matter?
Emanuel is offline
Old 22nd February 2016, 10:56 PM   #142
Very well said Emanuel!!! Thank you!!!
Old 22nd February 2016, 11:04 PM   #143
mahratt
mahratt's Avatar
Thank you, Emanuel!!!
mahratt is offline
Old 23rd February 2016, 12:46 AM   #144
estcrh
estcrh's Avatar
Here is a link to an excellent article which explains Zaqro Nonikashvili's "Georgian crucible steel technique".
http://ceroart.revues.org/2557?lang=en
estcrh is offline
Old 23rd February 2016, 12:55 AM   #145
Emanuel
Emanuel's Avatar
Mind you, my comment is specifically about the kirk narduban, not the kara khorasan.
Thank you Ariel and Eric! Magnificent stuff!
Emanuel is offline
Old 23rd February 2016, 01:18 AM   #146
Indeed, magnificent!
Just to think that the guy managed to reproduce the most difficult wootz patterns without having any theoretical ( written) or practical ( apprenticeship) help.
This is a work of a true genius. He is a Mozart of wootz.
ariel is offline
Old 23rd February 2016, 12:06 PM   #147
Ibrahiim al Balooshi
Ibrahiim al Balooshi's Avatar
Salaams All, There is compelling evidence from all quarters in this very excellent thread for reasoned thoughts on the decline of Wootz including the invasion of central Asia thus the drop in demand..and the demographic detail illustrated graphically on the suspected demise of participants...I believe all of them. I suggest one was the trigger (drop in demand) and the other caused the specialty to vanish.(see paragraph 3 below)
On the demise of Wootz in particular I would point to the traditional aspect in craftsmanship of taking the children into a apprenticeship routine from a very young age and passing them out at about 16 years old as fully trained artesans. This means that the graph illustrated above is not so much floored but enhanced since the apprentice age factor or the point in the graph between perhaps 5 and 10 years old (at the point the Wootz making stops) breaks the traditional passing down of the technique... and destroys the apprenticeship concept. Thus as Ariel points out ..."It Withers".
How quickly can a passed down tradition vanish?... Take the Omani Weaving specialization which all but vanished and except for the intervention my one single individual it would have sunk without trace. The same could be said about silver-making in Oman when the leader of the country had to intervene by having at least one son of the silver-maker learn the apprenticeship... It is therefor very easy to lose these traditional methods very quickly since the apprentice window is very narrow and in particular when they are not written down. It would appear that Wootz blade manufacture fell under similar constraints. Without the demand and then without the apprenticeships the art was lost.
In support of the very quickly lost art of Wootz manufacturing please see http://www.tms.org/pubs/journals/jom...even-9809.html
( also noted at #132 by Emanuel)
Quote."The smiths that produced the high-quality blades would most likely have kept the process for making these blades a closely guarded secret to be passed on only to their apprentices".Unquote.
Ibrahiim al Balooshi.
Ibrahiim al Balooshi is offline
Old 23rd February 2016, 01:04 PM   #148
ALEX
ALEX's Avatar
Ariel,
I do not believe the top 2 images shown in above Post#140 are modern production. The lower image is more like it. I think the 2 above are closeups of genuine antique blades added for marketing purposes, as to show what wootz/bulat looks like, casually adding Zaqro Nonikashvili name into association.
ALEX is offline
Old 23rd February 2016, 01:45 PM   #149
ALEX
ALEX's Avatar
Originally Posted by ALEX
Ariel,
... just to be clear on who's who.
ALEX is offline
Old 23rd February 2016, 01:54 PM   #150
ALEX
ALEX's Avatar
here's closeup of a modern Indian-made Kard that can be picked up for under $200, and not the best by far. There are wootz(?) ingots with better "structure" readily available for less than $100. I do not understand what is the big deal with Russian geniuses creating unimaginable bulat masterpieces? Are they any different or am I missing something?
ALEX is offline
Closed Thread
