Old 8th April 2025, 05:53 PM   #1
GIO
GIO's Avatar
Default Keris patrem ?
Good afternoon to all friends
Recently I purchased this small beauty at an online auction. I did not realize the real size, and thought it was a patrem, but now I an not so sure and think this is in fact a miniature kris. It is a very recent manufacture and very very well made, as you can see from the enclosed pics.
Any comments ?
Thanks in advance to everybody
Old 8th April 2025, 05:56 PM   #2
GIO
GIO's Avatar
Sorry, one pic has not been attached
Old 8th April 2025, 05:57 PM   #3
GIO
GIO's Avatar
The file is considered not safe. Please apologize
Old 8th April 2025, 06:01 PM   #4
GIO
GIO's Avatar
Trying again
Old 8th April 2025, 06:04 PM   #5
GIO
GIO's Avatar
Again
Old 8th April 2025, 06:11 PM   #6
GIO
GIO's Avatar
Once more
Old 8th April 2025, 06:49 PM   #7
GIO
GIO's Avatar
e
Old 8th April 2025, 08:21 PM   #8
Hi Gio. I'm not sure why, but there is defintely a problem with the files you are attempting to upload. I note that they are PDFs. Though that is an acceptable file type for upload, perhaps you could try converting these files to JPGs and see if that works better.
Old 8th April 2025, 09:47 PM   #9
GIO
GIO's Avatar
Thanks David. I shall follow your suggestion.
I cannot understand what is wrong: what I tried to upload is a scan of an image.
Old 8th April 2025, 10:12 PM   #10
GIO
GIO's Avatar
Files in jpg
Old 8th April 2025, 10:15 PM   #11
GIO
GIO's Avatar
The blade is 14 cm (5,5 inch)
Old 13th April 2025, 04:36 PM   #12
GIO,
The problem with .pdf files is that the forum software treats these as document attachments and not as a graphic format that can be displayed. Document formats are appended to the post and need to be downloaded in order to view them. Graphic formats (.jpg, .giff, .png) will display as images.
Hope this helps.
Ian.
Old 13th April 2025, 04:45 PM   #13
GIO
GIO's Avatar
Many thanks Ian. I am not familiar at all with such - for me sophisticated - aspects.
Gio
Old 14th April 2025, 01:35 PM   #14
GIO
GIO's Avatar
Relatively low number of views, but 1868 is a good number.
Still no comments ?
Old 14th April 2025, 06:49 PM   #15
Hello Gio,
I can't answer your question but I have seen a few Balinese keris hilts of very similar size like the hilt from your keris.
Old 14th April 2025, 11:36 PM   #16
I would be very reluctant to consider this tiny object in the form of a keris as something made specifically for a woman.
My reason for this is that I do not know of any situation in Balinese society where a Balinese woman would have occasion to wear or use such an object.
Old 15th April 2025, 11:08 AM   #17
Maurice
Maurice's Avatar
And how about Javanese kerisses of this small length?
Are they more common in Java?
Kind refegards,
Maurice
Old 15th April 2025, 04:05 PM   #18
Kind refegards,
Maurice
I would say that patrem are not exactly "common" in Jawa, but they are more likely to exist there.
Old 15th April 2025, 04:20 PM   #19
Gio, i would say that you would be more likely to get comments if you could provide some better and more detailed images of the keris. The PDFs you provided are too small to be able to give much feedback and the first images you provided are a bit blurry.
From what i can see i agree that this blade is rather recent. Though dressed in Balinese form it gives me the impression of something made elsewhere, perhaps Madura. I see a reasonably well formed blade here, but i am afraid i do not see a "very, very well made" one. I could be wrong, but the blade appears to have been made without a core similar to Buntel Mayat.
I tend to agree with Alan about the lack of Balinese situations where a patrem would be worn. I could be wrong, but i also don't thing there are too many patrems being commissioned these days for cultural uses even in Jawa where they are a know part of the culture, though uncommon even there. So since this is a modern creation i am not sure we should be calling it a patrem.
It is an attractive little item though.
Old 18th April 2025, 02:22 PM   #20
GIO
GIO's Avatar
Many thanks for your answers. I myself have already excluded it as a keris patrem, I confirm the high level of craftmanship, the pamor as "buntel majat" (hence the absence of a core). My question is therefore: "what was it made for ??". Is it a form of talisman ?
Apart from any consideration I consider it a nice item and am happy to have purchased it.
Thank again for the cooperation and best regards. Gio
Old 18th April 2025, 07:05 PM   #21
Could have been made for a number of reasons. Yes, a could have been intended as a jimat (talisman), but it could just as easily be an item created purely for collectors as many modern keris are.
Old 29th May 2025, 10:21 AM   #22
Pak Daud
Gio,
I think this is 7 luk (waves) keris, but you are right, this is Kamardikan (after the independence or after) so it is considered newly minted. Pamor "Gubet".
It is definitly Balinese style, with Hilt carving as Togog? (I am not sure).
Good on dark staining as well.
In my opinion, since it is relatively small in measurement, it is NOT considered as Patrem, in which was Javanese term for the Keris obtained for female owner.
Smaller than patrem, then It may perceived as Keris "Jimatan" (Talisman) or keris "Tayuhan" (higher degree from just a talisman).
They are both have values within isoterical beliefs (such as represent of certain dieties etc).
IMHO, it was usually meant for "housing", an empty vessel, a place for dieties to be sat in. For example, in Balinese Hindu, a trader, a farmer, animal husbandries etc must corelate upon certain dieties that reflect to his job intended.
Anyway, it is good collection, fair build and clearly it's a charm.
Congrats Gio.
Pak Daud is offline   Reply With Quote
Old 30th May 2025, 03:58 AM   #23
Possibly even a charm to charm duit from the pockets of travellers into a sellers pockets.
But seriously, yes, sure it could be regarded as a charm with talismanic properties, provided it has been made as such.
I only know one person in Jawa & Bali who can make a keris using the correct mantras. Only one. And he will only make such a keris for a temple, not for an individual.
Old 30th May 2025, 05:03 PM   #24
Pak Daud
True that, to charm duit.
Old 30th May 2025, 06:55 PM   #25
GIO
GIO's Avatar
Many thanks for your comments, Pak Daud and Alan. I do not consider this item a talisman, I only consider this small "keris" a nice and uncommon manufacture which will not disfigure into my modest keris collection.
Old 23rd December 2025, 10:52 AM   #26
GIO
GIO's Avatar
It just happened to me to find a similar keris which is in the collection of the Moscow State Museum of Oriental art. It is described as a 19th cent. Sumatran manufacture, 3luk, pamor adeg, ivory java deman hilt, not original silvered copper mendak, ivory sheath with 3 brass rings. It is described as a miniature and a talisman.
Here are the measurements in cms, compared with those of my keris:
Moscow keris My keris
total length 24,6 22
keris " 21,5 20
blade " 15,6 14
hilt " 5,4 5,7
Enclosed a photo from the museum catalogue
Old 23rd December 2025, 10:57 AM   #27
GIO
GIO's Avatar
Sorry, the measures appear quite blurred. It should be like this:
24,6/22
21,5/20
15,6/14
5,4/5,7
Therefore my keris is a bit smaller
