4th August 2020, 01:24 PM | #31 | |
p.s. - Never get an Ouzo hangover. |
4th August 2020, 04:16 PM | #32 | |
4th August 2020, 04:50 PM | #33 |
So what do you say Vitrix ? Do you think it is not such a good idea to use Ballistol to remove (unstick) the wooden grip ? I assume that is the tang that has increased its volume due to rust and not the grip that has shrunk; its exterior has its original volume, under the wire wrapping ...
4th August 2020, 09:31 PM | #34 | |
5th August 2020, 06:20 AM | #35 | |
Thanks for the tip on walnut oil, will try it as you advise. Heretofore I have only used it for cooking (certain dishes from Turkey and Caucasus require it). |
5th August 2020, 03:13 PM | #36 | |
