Old 28th October 2019, 06:39 PM   #31
Ariel thank you for the response, insights and interesting observations. As someone also fascinated with Afghan and Central Asian shashkas I must say I feel like I am 'among giants' with the perspectives given here. I admit despite years of studying these myself, I am by far still learning.
Kubur, great images!!! Really add dimension to this view into these.
On the scabbard 'drag', what I learned of these is perhaps hyperbole, but with European swords, it was fashionable in the 'hussar' trend, to wear sabers low slung and virtually dragging along as the individual walked. ...much in the manner of clinking spurs with cowboys. Naturally the hand of the sabre was probably more to the position while mounted, but the characteristic set a fashion.
There is likely a more pragmatic explanation in the scabbard structure itself, but the style in the case of these Afghan shashkas may have been simply adopting European military fashions.
Old 28th October 2019, 07:54 PM   #32
Kubur,
Both of them carry sabers in a typical saber style: edge down.
The first one has a saber likely made by the Tubchiev brothers ( from Daghestan), who learned enameling in Central Asia and brought with them niello in exchange.
The second one.... his robe is too multicolored to see the handle clearly.
My hesitations about the "pseudoshashka" are as follows:
1. The blade is very curved, not typical for those Afghani swords. Likely remounted shamshir.
2. The slit is on the wrong side. Moreover, I have never seen slits in pseudoshashkas: their curvatures are not as pronounced. Mainly, they are seen on Ottoman kilijes. I am sure you have several of those, just try to unsheath them holding the sword horizontally but with the slit being above or below. See which position is more comfortable.
3. The handle is asymmetrically placed, in a typical "pseudoshashka" style. If my suspicion about the blade coming from a shamshir is correct, the tang should have been re-worked. I would x-ray the handle to look for any signs of it.
4. I am uneasy re. contour change in the middle of the scabbard. Looks as if it was re-formed and the modified area was covered by the suspension fitting.
5. Was the leather stitched in the Ottoman style: wire "springs"? Would be nice to see a close-up pic.
Obviously, I am at a great disadvantage because of my inability to inspect the sword personally. But the owner can do it if he wishes and disabuse me of my suspicions.
As I have already said, it is a beautiful and highly unusual pseudoshashka. The former is indisputable. The latter is what makes my antennae twitch.
Old 28th October 2019, 08:12 PM   #33
mahratt
mahratt's Avatar
Ariel, calm your antennae.
This Afghan shashka, which you persistently call pseudoshashka (but it’s excusable, old people are usually very conservative), has no problems
Sorry, but I don't care much about your "suspicions." And certainly not so much that I was in a hurry to “disabuse” you.
Some of the forum participants who were visiting me in Moscow had the opportunity to carefully consider this shashka))))
And one moment. If you didn’t see something, then it only says that you didn’t see it and nothing more
Old 28th October 2019, 09:03 PM   #34
mahratt
mahratt's Avatar
Originally Posted by Kubur
Look at the scabbard of the guy in Samarkand...
Kubur, you are absolutely right. The scabbard with the element that I circled in red (if I understand correctly, the discussion was about it) has been marked in Afghanistan since the first half of the 19th century.
Color lithography is the 1840s (from the watercolors of Lieutenant Rаttrаy), the black and white image is an illustration from book Bellew: Journal Of A Political Mission To Afghanistan In 1857 (here we can see the afghan shashka) https://archive.org/details/journalo...501mbp/page/n7
Old 29th October 2019, 04:08 AM   #35
Kubur,
I enlarged the pics of Mahratt's pseudoshashka.
See. pic #6 from the top: typical Ottoman stitching and the fitting disturbed the seam mightily, to the point of tearing the wire stitches. I am more and more certain that the fitting was turned upside down to create a "shashka-like" appearance of the scabbard, and that the scabbard was originally Ottoman and not Afghani.
Have you tried to play with one of your kilijes and unsheath the sword when the slit is on top or on the bottom? Would like to get your impression.
As a matter of fact, other Forumites may try it too: the more opinions the better. We seem to have a fun exercise.
Old 29th October 2019, 05:24 AM   #36
mahratt
mahratt's Avatar
Hi Kubur.
The desire of our friend Ariel to prove that he is always right, often plays a bad joke with him. He begins to see that which is not. And he does not want to see what is, but does not coincide with his opinion
In this case, having initially made erroneous conclusions, he saw a “wire seam” (or its "footprints") that no and never was on the scabbard of this Afghan shashka... Sorry, but on the scabbard, a seam from an ordinary thread ...
Ariel, dear friend, I remembered the Russian La Fontaine - the the author of the fables Krylov and one of his fable, where the main character lost his sharp vision with age ...
P.S. Knowing Ariel’s "youthful enthusiasm", I’m sure that he will continue to find fault with something else. So prepare more popcorn
Old 30th October 2019, 06:11 PM   #37
Thanks for responding to my query about the stitches and adding a close-up of the area. Regretfully, my expanding the previously-posted pic of the same location blurred the image.
Yes, regular, not wire seam. Afghani, not Ottoman.
Now it is seen even better that the leather is damaged, likely by the repositioning of the suspension fitting. Somebody likely wanted this one to look like a real Caucasian shashka, but the damage to the leather and the wrong position of the slit betrayed him.
Still, a very handsome example that should have been left alone. Perhaps, you might want to reposition the fitting to its original state. Should not be very difficult.
Enjoy it.
Old 22nd November 2019, 11:18 PM   #38
kwiatek
Originally Posted by CharlesS
I am delighted to see these swords getting some attention on the forum! I have been a fan of them for some time, though I realize they fall into the strange collecting category of "rare but not highly sought after". Perhaps it's because Caucasian shashkas are more "blingy" and found in greater numbers.
I have handled about 5 of these including my two shown, and they may vary in length and blade type, but are generally always heavier than the Caucasian shashka.
My two are both quite heavy even to the point of becoming somewhat cumbersome to handle. The hilt styles are the same with simple riveted-through scales. The blades are not particularly well forged. Note that forging flaws abound on the larger example even to the point of partially ruining the chiseled panels at the forte.
Those panels are reminiscent of Persian style cartouches but are actually far cruder by comparison.
Each sword has some form of arsenal mark. The larger one has it chiseled into the forte panel on one side. The smaller example has it inlaid in gold on one side with an Arabic inscription I have not had translated.
Even with some faults, these versions are certainly unique, worth appreciating, and as far as I know, this style is unique to Afghanistan.
The inscription on the blade says:
عمل فقیر حسین (۰)١٢٦
‘amal-i faqir husayn 126(0)
“Work of Poor Husayn, 126(0) (1844-45)”
kwiatek is offline   Reply With Quote
Old 22nd November 2019, 11:33 PM   #39
kwiatek
Originally Posted by mahratt
I would be very grateful if someone would help me with the translation.
In my opinion, the scabbard was made specifically for this shashka. Its handle is deeply hidden in the scabbard, which can be seen in the first photo.
Starting with the inscription nearest the throat you have
نصر من الله وفتح قريب
“Victory from God and near conquest” (part of Qur’an 61:13)
الله محمد علي حسن حسين وفاطمة
“God, Muhammad, ‘Ali, Hasan, Husayn and Fatima”
انا فتحنا لك فتحا مبينا
“Indeed we have given you a manifest victory” (Qur’an 48:1)
On the mount in the middle, you have, repeated:
يا قاضي الحاجات
ya qadi al-hajat
“O Requiter of Needs!”
Old 5th December 2019, 06:21 PM   #40
Cthulhu
Cthulhu's Avatar
Default What a drag
I can't see any evidence of drags in the circled photos Mahratt posted, leaving me a little confused on terminology. I know in some cases the term "drag" is used interchangeably with the whole chape. I've edited one of Mahratt's photos to clearly show what I call the drag, distinct from the rest of the chape.
I'll note that at least in the random sampling of European saber photos I looked at, the larger side of the drag always leads, thus providing equal or greater protection to the front side of the chape that's clunking into the ground as you walk. Looking at Mahratt's shasqa sheath, the larger side of the drag is on the concave side, meaning the concave side is downward, matching the orientation of the other mounts. The chape hasn't been removed and reversed, as the carved side and plain side on it match the face and back side (stitched side) of the leather.
All that aside, these are lovely shasqas people have. I really like the shasqa's clean lines and simplicity. I'll have to dig mine out of storage and provide a photo, but it's not in the league of the ones shown here, not by a long shot.
Cthulhu is offline   Reply With Quote
Old 6th December 2019, 12:58 AM   #41
Well, if one looks carefully at your delineation of the drag, it is the convex side that seems to be wider, suggesting that the sword was worn “ saber- wise”, not “shashka-wise”. That would prove that the slit on the throat originally was on the upper side, and that the seller intentionally reversed the direction of the suspension fitting to give a false impression that this pseudo shashka was worn like a Caucasian shashka.
The only problem with the drag is that we have no idea whether the sword was worn low ( touching the ground) or not. My guess not: dragging was fashionable among European cavalry officers, just to impress their dancing partners. Afghanis did not care about such niceties:-)
Old 6th December 2019, 02:59 AM   #42
Cthulhu
Cthulhu's Avatar
My apologies, my post was pretty ambiguous. Instead of "larger" I should have said "longer." The longer side of the drag is in the direction of travel, that is, on the underside, on every European saber where I've looked. I'm assuming this was for the functional reasons I've mentioned, and even if the sword wasn't to be dragged around it would be done in the same way. Of course there's no way to know how a non-European maker would orient the drag. However if we assume these things were done capriciously, we stop being able to say much of anything about anything.
Old 6th December 2019, 03:30 AM   #43
Kubur
Kubur's Avatar
Your translations are amazing, thank you, for the Tunisian daggers too.
Question: are you sure that it is Poor and not Husayn the sufi?
Old 6th December 2019, 03:31 AM   #44
Kubur
Kubur's Avatar
This guy should have been seriously shi'a...
Persian??
Old 6th December 2019, 12:36 PM   #45
CharlesS
CharlesS's Avatar
Thanks so much kwiatek!
Old 6th December 2019, 09:15 PM   #46
kwiatek
Thank you Kubur and CharlesS for posting your pieces. It‘s great to see new things and to learn!
I think faqir here means “poor” rather than “dervish”, though you’re right that it could have that meaning. It’s quite common for artisans to sign things with a self-deprecating adjective such as “poor” or “humble” or to call themselves “servant” or “slave”.
And yes definitely Shi’i!
Old 7th December 2019, 02:35 AM   #47
Yes, Shia.
My guess , this pseudo-shashka was not made in Afghanistan by the local Shia, Hazara or Quizilbash. Afghani-made weapons are usually simple and pretty crude.
I would guess it came from Iran, where there are significant diasporas of both tribes.
Shia Muslims were persecuted in Afghanistan and emigrated in droves. Just to mention wholesale slaughter and displacement of Hazaras by Abdurrahman in the early 1890s: it is claimed that fully half of their population were killed by government forces.
In Iran they settled in Khorasan, a famed arms- manufacturing province. That might explain the sophistication of that sword.
Old 7th January 2024, 12:19 AM   #48
Sakalord364
Originally Posted by ariel View Post
Yes, Shia.
Just to add a bit, yes the blade is Persian, however the scabbard fittings and Handle is clearly Afghan. This was a trade blade that a local sword cutler used to create an Afghan style Shashka.
In the late 19th century many of these cutlers were Bukharans who settled in Kabul- their main clientele at this point would have been Afghan Army officers who wanted a fancy private purchase sword as opposed to their bland government issued piece.
Sakalord364 is offline   Reply With Quote
Old 7th January 2024, 11:32 AM   #49
Turkoman.khan
Turkoman.khan's Avatar
Hello, Sakalord
I don’t think this is the work of Bukhara masters who worked in Kabul. Usually masters from Bukhara used their own techniques for decorating weapons. I recently read the article "Arms decoration features in Khanates of Central Asia":
https://www.academia.edu/105977932/A...Y_20TH_CENTURY
The technique of decorating this shashka is completely different from the techniques used by Bukhara masters.
But I completely agree with your opinion that many Afghan Army officers wanted a fancy private purchase sword.
Turkoman.khan is offline   Reply With Quote
Old 15th January 2024, 06:52 AM   #50
Default Shaska......Afghan or Uzbek?
This was a great discussion, and fascinating topics. Over 20 years ago, I was able to get this shashka, which in the auction in London was described as from Uzbekistan.
In subsequent research and discussion with Torben Flindt, it was inconclusive whether this was indeed Uzbek, or actually Afghan. It was he who said wisely, 'weapons have NO geographic boundaries'.
This example has the same distinctive long fluted chape on the scabbard seen on many paluoars, so that of course leans to Afghan.
I hope possible the members here might add their insights, and what about this example might lean to either Uzbekistan or Afghanistan. I would presume this is late 19th c?
Any comments on the calyx extending at back of grip ferrule as per Khyber knives etc.?
Old 16th January 2024, 02:57 AM   #51
Hi Jim,
I'm reminded of this thread on classification of shashkas.
Old 16th January 2024, 05:35 AM   #52
Turkoman.khan
Hello Jim
Excellent shashka. Congratulations. I think this is a fine example of a shashka from late 19th century Afghanistan.
Old 16th January 2024, 06:05 AM   #53
Originally Posted by Turkoman.khan View Post
Hello Jim
Turkoman, THANK YOU so much for the kind words! I was so enthralled with this in the London auction I saw it in that I flew to London to attend it (never did that before!) . I think the scabbard was the most intriguing as it looked like many Ive seen on paluoars. I agree, and as it seems the consensus to be, this is Afghan.
Ian, thank you for the link to that very exhilerating thread !!!
That was a boldly placed topic you posted, and wonderful to see those days when discussions prevailed. While flare ups of contention happened, the outstanding and elucidating material shared truly advanced I think the general understanding of these sword groups.
It would seem, as I think as suggested, the term shashka is probably not 'by the numbers', properly applied here despite the obvious similarities, but it is hard to think of it otherwise, as in character it seems to call out, 'shashka'.
When recalling "The Great Game", the profound influences of Russia in Afghanistan in the 19th century cannot be discounted.
Old 16th January 2024, 11:57 AM   #54
Mercenary
"The Great Game"
I think that Central Asian shashkas are just “cousins” of Caucasian (and later Russian) ones, and not a direct borrowing. They often resemble Khyber knives in design.
The common ancestor of all types of shashkas I think were the knives of the mountain robbers of Eastern Iraq of the 15-16 centuries.
Mercenary is offline   Reply With Quote
Old 16th January 2024, 01:02 PM   #55
Turkoman.khan
Wow, Mercenary.
Very cool and interesting. Thanks for the info.
Old 16th January 2024, 02:13 PM   #56
Mercenary
Wow, Mercenary.
Thank you. But I was wrong. Southern Iran, Shiraz, not Eastern Iraq. I'm sorry.
I know a lot, but I remember little of it ))
Old 16th January 2024, 06:45 PM   #57
VERY well put mercenary!!!! A COUSIN!! exactly, and that is probably one of the most effectively accurate terms describing the development of many weapon forms.
Not to worry on the slip on the mountain robber knives, from reading your posts over these years, you probably have forgotten more than many of us have ever known on these esoteric topics!
