Old 11th September 2009, 08:28 PM   #1
Atlantia
Atlantia's Avatar
Default FeCl affects on non ferrous metals
Just wondered, anyone got this stuff on brass or silver? Does it eat into them or affect them?
Old 11th September 2009, 08:32 PM   #2
It blackens Silver, it seems to polish back up okay .
Old 11th September 2009, 09:33 PM   #3
Atlantia
Atlantia's Avatar
Ah, thanks.
I take it that it will do bad things to brass, isn't it used to disolve/etch brass sheets?
Old 11th September 2009, 09:54 PM   #4
Rich
Rich's Avatar
Yes, it is used to etch copper (brass is mostly copper) in printed circuit boards.
I wouldn't recommend using FeCl3 on brass.
Rich
Old 12th September 2009, 02:20 AM   #5
Rich
Neither would I, I have heard of stories when people have used it on Chinese Jian with the seven star inlay, it has eaten the inlay away. From memory, Josh or Rick some time back recommended that clear nail polish be applied to any any inlay before using it.
Gav
Old 12th September 2009, 07:03 PM   #6
Atlantia
Atlantia's Avatar
Gav
OMG! That would be a bit of an 'oops' moment!
Old 12th September 2009, 08:24 PM   #7
This also depends on the strength of the acid. If dlluted say by half, then the damage is controlled. I have etched by half strength before and less, and it has not eaten into the brass or silver. Mind you, it was not on long at all.
Old 13th September 2009, 04:12 AM   #8
Sounds like a good way to age brass things artificially.
Old 13th September 2009, 10:24 PM   #9
G. McCormack
G. McCormack's Avatar
Dont forget, it will dissolve things into its own solution. So if you have an etchant tank of FeCl you use for blades, then use it for a copper article, don't be surprised when the next blade you etch comes out lightly plated in copper.
Old 13th September 2009, 11:54 PM   #10
And for that reason you use other acids to age brass......
Old 23rd September 2009, 01:41 AM   #11
ThePepperSkull
Is this an effective way to keep areas you don't want etched in their unetched state? Would taping off the areas be a better option or would the etchant just eat away at the tape?
Old 23rd September 2009, 01:48 AM   #12
ward
Ferricc will go thru the tape. Any nail polish will work or wax
Old 23rd September 2009, 02:55 AM   #13
The acid does not react to the acrylic in the nail polish or the wax.
Old 23rd September 2009, 03:54 AM   #14
Wax would seem to be the traditional resist medium .
Easy clean up .
Old 23rd September 2009, 04:01 AM   #15
Default Wax
Wax was the traditional method seem on most European weapons when acid etched scrolls etc were applied to the blades, also a good medium to work with.
Gav
