Old 8th September 2009, 09:51 PM   #1
Martin Lubojacky
Default Boxer Rebellion Sword - request for advice
May be common sword, nevertheless not my specialization and I would appreciate your help - answers to the folloving questions:
Why they used to be completely (incl. handle, metal fittings) black coloured ? Is it original colour or it was colured additionaly (see detail - also scratch was coloured). Shouldn´t this black "enamel" be removed during restoring ? If yes - completely or from certain parts only ?
The blade is very, very heavy and thick (not ballanced) and my opinion is the "fencing" with one hand would be rather cumbersome. Is this sword for two/"one and half" hands (the handle is relatively long) ?
Martin
Old 8th September 2009, 10:02 PM   #2
Martin I cannot see any enamel on this, perhaps because of the light. I would be surprised to see real molten glass enamel on a sword like this. It looks genuine to me, file marks on the handle but originally it would be covered in ray or shark skin.
Old 8th September 2009, 10:17 PM   #3
fearn
Hi Martin,
As Tim noted, the handle should be covered with something like cloth or leather.
As for the weight and balance, it's not designed for European-style fencing, but for circular slashes, and I'm pretty sure it's a single-handed blade. That said, it could also simply be badly balanced. That did happen, especially during war-time.
F
Old 8th September 2009, 11:21 PM   #4
Atlantia
Atlantia's Avatar
Hi Martin,
I have a very similar one if you would like to compare? Also very heavy and still retaining some black 'paint' although sadly no scabbard.
Let me know how the size/weight compares.
Gene
http://www.vikingsword.com/vb/showth...hlight=chinese
Old 9th September 2009, 12:27 AM   #5
here's a good series of photos on how to re-wrap the grip.
it's in chinese, but the photos say it all....
Linky
Old 10th September 2009, 01:48 PM   #6
Martin Lubojacky
Thank you all for answers and good references/links.
Gene, dimensions are:
total length (in sheath): 95 cm
without sheath: 92 cm
weight without sheath: 1. 3 kgs
blade:
lenght: 75 cm
width: 4. 3 cm
thickness: 0. 6 cm (up tp 20 cm from the tip)
smooth surface, buth with signs of fighting
Old 10th September 2009, 11:00 PM   #7
Atlantia
Atlantia's Avatar
Thats interesting, thanks for posting the stats on your mate
I always find these comparisons very interesting.
Heres how mine measures up!
total length (sword): 91 cm
weight (sword): 1. 475 kgs
blade length: 75 cm
width: 4.3 cm
Spine thickness: 0. 6 cm (gradually thinning from half-way point)
P.S
Whats your guard like? Mines loose as hell
Old 10th September 2009, 11:17 PM   #8
Atlantia
Atlantia's Avatar
Its an interesting contrast.
I really should take the ghastly string off the handle and start the restoration
Old 10th September 2009, 11:19 PM   #9
Atlantia
Atlantia's Avatar
Linky
Cheers Kronck
Old 11th September 2009, 11:06 AM   #10
Martin Lubojacky
The guard wabbles a little
Old 11th September 2009, 12:38 PM   #11
Atlantia
Atlantia's Avatar
I notice the hole in the handle of your sword is right where I thought the tang would be thinning down to enter the pommel.
So I guess the tang is wide right up to near the end?
Are you going to repolish the blade?
Old 27th September 2009, 09:31 PM   #12
Martin Lubojacky
Sorry for late reply, Gene.
"I notice the hole in the handle of your sword is right where I thought the tang would be thinning down to enter the pommel.
So I guess the tang is wide right up to near the end?"
-- I am of the same idea, we will see when I overhaul it.
"Are you going to repolish the blade?"
--I would like to do it and also to etch the blade (for the case...). And to re-wrap the handle. (But everything later, not now).
Martin
