Hello gentlemen,
I am already longer a member here and follow nearly every day the discussions posted here. I am collecting since 1992 keris when I have had my first trip to Indonesia, Java. Infected with the keris-fever my collection grow up every year. Until now I never found the time to record here something because I am to busy by my work and also bought a old house some years ago. Please apologise my not perfect english. Here my question: 2001 I bought on Bali two small Sumatra keris. A similar example I found in the book "The Invincible Krises 2" on page 142/3, not from the blade but from the sheath, I think that it is the same material. Mrs. Ghiringhelli write that she wasn't able to identify the kind of bone. I thought that it is whale bone but never have been sure. I think that it is a Minangkabau keris, handle from elephant ivory in Jawa Demam style, the pommel of the sheath also. §-luk blade very fine executed. When i get the keris the blade have had very thick corrosion. The sheat is set together from four parts and have a glossy old patination. The blade fits perfect inside the sheath and I believe that all parts original. The keris is 31,5 cm long inside the sheat and the blade alone 20 cm without peksi. Every comment and information are welcome. Special about the origin, sheath material and dapur. Thank's in advance, Detlef [/IMG][IMG][/IMG][IMG][/IMG] |
Sorry, want to write 3-luk blade!
Yes as I have heard this material is whale bone.
I have a hilt of the same material. Hope someone with more knowledge can confirm |
First of all, welcome Sajen.
I am not really speaking from any actual knowledge , but it dies seem to have the right porous quality that would be right for whale bone.
Hello Erik, thanks for your reply. I don't have to much experience with this material, I also have a handle from Bali whereof I think it's from whalebone but this one is not so heavy like this sheat so I'm a little bit confused. And I think also that Mrs. Ghiringhelli will know about this material.
Regards, Detlef |
Thank you David. Yes, the porous let me think it's from whale bone but the heaviness let me doubt about.
Here a closeup from the tip of the sheat, maybe it help to identify the material.
I'm not so shure the nice sarong comes from whale bone. From bone shure! But from whale...
The very nice hit from pics seems to me ivory. I put here two hits (from whale bone or from elephant bone i don't know... ....maybe some expert could help me to know better.
Hello Marcokeris, yes the hilt is from elephant ivory.
For me it's also very difficult to differentiate between bone materials. |
Hi Sajen,
That's a nice minangkabau keris you have there. The blade is Minangkabau, Luk 3, similar to mine (( link )). Minangkabau fretworks (greneng) is smaller and delicate looking than most. The fittings, as you've mentioned are Minang, as well. |
Hello Detlef,
I'd guess that the tip of the sheath also is ivory? An experienced seller stated deer antler for a similar Minang Kabau scabbard (and hilt). I've seen references to bones of whales and (Asian) elephant being used, too (BTW, both subject to CITES as are some deers). Of course, old water buffaloes (as default bone source in the region) aren't small animals either. Moreover, bone pieces can have quite different denseness depending on which bones and, especially, which part of it is being utilized. There seems to be a lot of guesswork when it comes to identifying the source of materials being used for ethnographic pieces; e. g. many horn hilts referred to as rhino seem to be actually buffalo. I'm not sure wether there are forensic reference collections which would allow identifying the origin by non-destructively examining the structure of the materials encountered with antique pieces. Some, like rhino horn and elephant ivory, are more likely to be identified positively than bone though. I think it would be great if we could try to verify the source of a wide array of materials traditionally being utilized: Modern approaches like DNA sequencing will also have the added benefit to possibly narrow down the origin to a local population rather than to a species or genus only and, thus, being much more informative on the history of an ethnographic piece. While taking the necessary (small) sample damages a piece to some extend, this can often been done where it's not readily visible. Anyone interested to join the fun by making pieces from his/her collection available for study? Regards, Kai |
Hello Alam, thank you for your reply, I've seen your keris in a other thread before. The blade looks indeed very similar.
Hello Kai, yes the pommel from the sheat is from ivory. I don't know how much material it will need to identify it by DNA analysis but I think it's possible to take out some substance from the inside of the warangka. But I don't know where it's feasible to get a analysis and for which amount.
#13 | |||
Hello Detlef,
I hope to get this project started later this year; the first trials will be done with lesser pieces from my collection. However, it would be nice to know who considers making pieces available for planning purposes. Anyone? Please contact me via email preferably. Regards, Kai |
Hi Sajen,
welcome to forum. As i can see from your pics.. i think it may be ivory. can you post biger pic of only the hilt? i see stucture that may resemble elefant ivory structure.. crosed lines.. i doubt it is whale bone or other bone.. but im no expert. regards Michel |
#15 | |
#16 | |
Scabbard is whalebone. Ukiran and buntut are ivory.
#18 |
Hello Michel, yes the hilt is from elephant-ivory for sure. Also the buntut is from this material.
Hello Marcokeris, I be in doubt that the warangka is from deer horn. It's 11,5 cm long and where the gandar go inside 5,5 cm high. I've never seen a large deer horn like this especial when you consider the some material have to be carved away. Regards, Detlef |
#19 |
Hello Henk, do you have experience how heavy whalebone is? I am not, but the sheat is very heavy. Like I note in up my first guess also have been that it is whalebone. And it puzzled that Mrs. Ghiringhelli don't know about this material.
Regards, Detlef |
#20 |
#21 |
Pak Detlef,
Can not help to confirm but there are some nice info about whale bone here: http://www.flyingturtle.org/askdrg/askdrgalapagos3.html and interesting quote from the page below: While whale bones are real bones, they are apparantly a little "spongier" and less stiff than most land animal bones. One of our sources says whale bones are full of oil and very smelly while they are "drying". For that sheath size, I think cow/buffalo bone is also possible (?), but I'm not sure either, but sure it is more readily available. I remember to hold 'tourist' keris sheath made of bone, not sure if it is made of whale bone or other material but it is bone for sure (I tend to believe cow/buffalo), similar to yours but undyed so it is lighter in color. It is heavy and smells like bone But I don't know if we can find large enough material from cow/buffalo for the sampir. |
#22 |
Detlef,
I thought to recognize some of the whalebone structure on your pictures. Whalebone is not much more heavier than cow or buffalo bone. As tunggulametung wrote, the structure of whalebone is more spongier. Maybe you can make a clear picture from the inside of the wrongko. Maybe the unpolished part of the material could tell us more. Whalebone seems to be not an unusual material for kerissheaths. I'm not familiar with your Mrs. Ghiringhelli and don't know why she doesn't know about this material. |
#23 |
Hello Henk, I will try to photograph the inside from the warangka. Mrs. G. is the author from the book "The Invincible Krises 2". Look in up from this threat, in her book is a keris with similar sheat.
Regards, Detlef |
#24 | |
I have a hilt of similair material as this sheath and it is posted above. It is clearly different from any other bone hilt I have in my collection. Both structure and coulour are quite different from the regular bone hilts I have seen so far. The person with whom I traded it mentioned it that it is whalebone. So without any in depth knowledge I still go for whalebone untill a better option comes along....
Regards, Erik Quote:
#25 |
Hello Henk, difficult to photograph the inside, this the best what's possible for me.
#26 |
And a third one.
#27 |
But enough for me. Well done!! Whalebone!!!
#28 |
I'm with Henk, Whalebone!!
Agreed! |
#29 |
Hello Henk, brekele and all others, thank you. Great help.
#30 |
Brekele, nice keris you show there, is it a Sumbawa keris?
