i will show you also an other intresting sword from me. it is an pahari sword ore sometime also as an cobra sword known.
intresting for me was that it is mounted with an khanda basket hilt. as usual these sword was mounted with an pouluar hilt. an similar sword you can see in the book from g.n. pant. indian arms an armour vol.2 plate CXIV. there was such an sword with an khanda hilt descr. as an 16.th.ct. sword from utar pradesh. in hindu arms and ritual you can also see such an pahari sword but only with an pouluar hilt from the end of the 18.th. ct. i think these sword was made as an realy fighting weapon. the blade is stought, with an strong point.the lenght over all is 93cm, the blade is 76cm, wide before the bulged 5cm and the diameter from teh bulged is 10cm. i know not much over the history from these word. i donīt also know how old is it. i think it isnīt from the 19.th ct. the most pahari swords iīve seen before was from these time, but i think the mounted hilt is older and i think it is in the original condition. the glue between the hilt and the blade shows very old an original. what think you over these sword? i hope someone can tell me more!! |
more pictures...
i forgot to tell , i canīt found any pattern from watered steel at the blade. i think it is "only" steel. i proof it if it is wotz ore also if it is welded damscus steel. |
Isn't it called Pahari? Very nice, just a pity that it was so overcleaned. I suspect there were lavish decorations on the "hood" part of the "cobra", but these were wiped out.
Always a tough decision whether to remove the rust and patina to a "high gloss" or not.... |
hi ariel
yes i have cleaned it, so i have also removed the old " patina" under these patination was also small rustparts. you can see the pittings at the blade. at one small part from the blade are these rustpittings very deep. i hope it is stoped now. the next reason was, i hoped that these sword like all older weapons from india was made from watered steel and i would like see these pattern at the surface. there was not any decoration at the bulbus before the cleaning. i know the newer cobra swords was rich overlaid with gold koftgari but i think these swords are not made for fighting. i think these swords was only made for representation. |
Stefan has raised an interesting question: were all old (lets say pre-19th century) Indian swords forged from Wootz (I add from me: pattern welded) or were some of them forged from plain steel? Maybe a steel imported from Europe (well, we all know of European blades in Indian swords)?
Now I recall these swords Stefan, from discussions last January...you have got an incredible grouping of very important Indian swords there!!! These two interesting examples with the so called 'cobra' blades, one with Hindu basket hilt and the other with Deccani hilt with Afghan paluoar type pommel, are truly anomalies, as discussed in both Elgood and Pant.
Actually the discs at the blade root are not nagan representations, but symbolize the chakra or mandala. As Elgood discusses (p.240) the association with Vishnu in the Sangam age established this symbolism as that of the right to rule, and as an element of these weapons, most likely as you note, ceremonial or court weapons. It is noted further that the Sanskrit word for swords incorporating the chakra is 'ardhachakrakrpana' and as such these are symbols of the chakravartia, or universal king. The term 'pahaari' is actually a linguistic term, in Hindi, Urdu and Punjabi, referring to the language of the 'mountain people' covering regions from Nepal in the east, to Himachal Pradesh in the west, and one of the regions suggested as possibly that of provenance of these distinct swords. I believe this may be the source for the pahari term referring to these (which is certainly much easier to use in description than that other one!! ![]() Elgood ("Hindu Arms & Ritual", 2004, p.121) notes that in the Vijayanagara state, at its zenith in the 16th century, the Adil Shahi kings saw themselves as Chakravartins, which may of course signify the tradition behind these very symbolic weapons. It is noted also that Pathan nawabs established a subordinate state to Hyderabad in Kurnool (situated in Andhra Pradesh). The two chakra bladed examples in your collection seem to be of 19th century, though Elgood discusses 17th century example from Bijapur, and notes these are typically catalogued as 19th century in museum references. The blades are both similar in the Vijayanagaran style , with the hilts of course different, one with what appears an 18th century khanda example, the Deccani hilt one (strikingly similar to the one in Elgood, 11.17, p.121) of latter 18th century? The use of wootz in Indian blades in the 19th century virtually ended, especially with Indian government forbidding production of wootz in 1866 in the Western Ghats. It is unclear whether certain centers may have continued, such as Sirohi (in Rajasthan) where heavy watered steel blades of Persian form were made. As far as the blades in India, the Oriental style watered steel blades though heavy, were often disfavored as they were susceptible to fracture in combat, while the layer weld form was much stronger. Many of the finer old blades, particularly Mughal examples, were of course of beautiful watered steel, while there were certainly regularly forged blades later. The Indian sword blade was highly favored, especially in Arabia, where in Hadhramaut and Yemen a good sword was termed 'muhanned' referring to 'Indian sword'. The Indian blade was regarded next to the Persian, and termed al Hindi ( used in Arabian poetry as a simile for brightness, Elgood, "Arms and Armour of Arabia", p.14). It would seem unlikely that watered steel blades would be considered 'bright', suggesting high polish. I am aware of many tulwars and some Arabian sa'if with Indian blades of extremely high polish, and dating from 18th and into 19th c. which are of course forged, not of watered steel. I hope this information will be of some help, and though redundant somewhat to research you have already done, I wanted to add it here for future reference. Thank you again for sharing these beautiful examples here! All very best regards, Jim |
hi jim.
at first many thanks for you very intresting long comment. it is the reason that i post some of my swords in the forum. i will learn as much as possible over my swords, than these swords are alo a part of my live( since i was a little dirty boy i build swords from wood and later also from steel and later i bougth very proud my first own ...) and so i will know all from theire history. it is very intresting what you write as the use from watered steel by the forging from swordblades in india. many things are new for me. i donīt know until now that the produce from wootz steel in india was prohibited 1866. i think it was the tru reason was the english gouverment. so could gb.exported theire iron to india. i have also an khanda in my collection as i bought it it was offered as an 18.th.ct. khanda with an watered steel blade. the polish from the surface wasnīt good, so i canīt see so much. i thought i can see a little bit fom the wootz pattern in the steel. later when i polissh the blade at home and proof what a kind of steel it is i canīt find damascus steel. i try last week again to etch it( i thught i could make a mistake by the first etching) i used a thin nitrid acid (3%) but the end was the same a gray colour without any pattern. i think it is an 18.th. ct. rajasthan khanda, the blade is good, thin and very flexible with sharp edges and neveerless stought. so was my question what a kind of steel was used to forg it. it is an foreign steel ore make the indian ironproducer also such an kind of steel in theire furnace. you give me a lot of answers. again, thak you!! |
That's one of the most unique ricassos I've ever seen on a sword. I really like it.
I wonder if it's just for aesthetics or if it has a functional purpose? I'm leaning toward aesthetics, as it already has a hilt. |
#9 | |
Hi Qeequeg, Welcome to the mysterious world of ethnographic weapons!! and very well observed. You are exactly right, these often dramatic features on many weapons serve as symbolic devices often representing traditional or religious ideology, particularly many of the unusually shaped weapons in India. As I noted in my typically brief last post (if one didn't get lost trying to wade through it!) I noted that these were ceremonially intended, probably for court fashion or symbolic bearing type use. Stefan, I'm glad you found this information useful, as I learned a lot from it as well while compiling it. I'm sure there are likely misconceptions, and as always I look forward to the comments of others more familiar with these aspects of the weapons on India, and the metallurgy of these swords. Thank you for sharing the wonderful story on the beginnings of your interest in swords, and it is quite clear you've come a very long way my friend! I'm not sure on the steel used, and as I mentioned, my comprehension of metallurgy is admittedly very limited, but I think you may have a point on the restrictions on forging wootz and emphasis on import of British steel. All very best regards, Jim |
It is true that the production of wootz was prohibited by the English in the Deccan due to deforresting they said. As it has been commented, the true reason was, most likely, that the English wanted to sell their blades without too much competition.
In the early days the Muslim merchants, exporting the crusibles to the Middle East had people checking the crusibles before they were shipped, to make sure it was crusibles. In India however, blades were made if mono steel, pattern welded and of wootz steel. It all depender of, how much money the buyer could afford to spend on the blade as he would also need a hilt as well - decorated if possible. |
Thank you very much Jim and Jens for the most interesting information
