Total length 36 cms. (14").
Pattern of marks on both sides has a similar tendence, although more extended on the front. On the back, near the socket, there is small symbol ... maker's mark ? As so often with these things, it can be seen by the beaten socket bottom, that it was some time used as a "modern utensile", like a chisel. It was gathered in the Country interior, in a tiny country village with a very old monastery and a medieval tower, this now used for residential tourism. This doesn't mean this piece once belonged there, but it has all the looks of being a very old item ... in my ignorance, i would dare 17th century ??? ![]() One thing that intrigues me, not being a connoisseur, is the edges of the blade, that are completely "squared". Although the socket and the general shape of this piece makes me think this is a weapon, i wouldn't be sure without a help from someone who being more within this area, or has ever seen something similar. Gentlemen, i will apreciate your coments. Fernando |
A spear or lance butt / shoe ?
#3 | |
![]() Quote:
![]() But then, being a secondary component, to be used near (and into) the ground, why the decoration ? ... Just thinking out loud ![]() |
#4 | |
![]() Quote:
How about a depth gauge for a grain bin?
I have seen these marks before on African spear butts. Cannot remember which ones but Kenyan area.
Royston |
#7 | |||
Thsnk you all, Gentlemen,
![]() Quote:
![]() Quote:
![]() Can you remember where you saw those Kenyan marks? Fernando |
METAL BUTT SPIKES NOT ONLY SERVE THE PURPOSE OF ENABELING THE SPEAR TO BE STUCK UPRIGHT IF THE GROUND IS SOFT ENOUGH, BUT MAY ALSO AID IN THE BALANCE OF A THROWN SPEAR ?. THEY COULD ALSO BE USED AS A SORT OF TOOL IN SOME INSTANCES, THE DESIGNS ON THIS ONE ARE ALL SIMPLE LINE DESIGNS USED JUST ABOUT EVERYWHERE AND ARE A VERY PRIMITAVE SORT I NOTE IT HAS A HOLE FOR ATACHMENT TO A SHAFT. THE SOCKET IS A VERY OPEN TYPE AND WITH JUST ONE NAIL TO HOLD, IT WOULD NOT MAKE A VERY GOOD WEAPON AS IT WOULD BE MORE PRONE TO COME LOSE.
NOW FOR SOME FUN I WILL PROPOSE A USE WHICH MAY NOT HAVE PREVIOUSLY BEEN THOUGHT OF. THE SQUARE FORM AND THE DESIGNS WOULD BE GOOD FOR SCRATCHING BETWEEN THE TOES OR REMOVING MUD WITHOUT BENDING DOWN A HANDY TOOL FOR THOSE WHO ARE ALWAYS BAREFOOT. ![]() |
Fernando,
I am away from home at work for the next couple of weeks, when I get back I will have a sort through the " Spear Pile " I am almost certain I still have a spear with this type of marking on it. If I can find it I will post. Royston |
Hi Fernando
![]() I also believe it is a spear butt. A spiked butt had a use for 'sticking' in the ground..... and 'if needs must' your enemy. It is unlikely this was a counterweight for a throwing spear. Throwing spears by definition are lighter (in weight) to achieve greater distance.... usually iron is 'coiled' wrapped at the butt end if weight was required. The type of spear with a spiked butt are usually the 'held' type and often used in battle like a wooden staff (quarter staff, 'Bo' the Japanese version etc) Obviously the bladed spearhead could be used to stab, but also was used to slash / cut when used in an arcing motion. The spiked butt was useful for defence from attacks from the rear or side. The Masai, when facing a lion, have been reported as holding the spear, butt stuck into the ground as the lion leaps to attack. In this way the animal's weight provides the penetrative force...the butt prevents the spear from 'sliding'. Shaka, modified the traditional spear by shortening the shaft and increasing the size of the bladed spearhead. Due to the 'regimented' tactics he employed ie lines of zulu's using shields to deflect attack and expose the assailant to a stabbing attack. (A very similar tactic used by the Romans .. ...however they used the gladius, the short stabbing sword which was well suited to this technique.) Shaka negated the spear butt because (a) having 'lines' of men in rows meant that their 'backs' were protected and (b) with the 'row' in front stabbing the enemy there was a real danger of a spear butt injurying warriors in the 'row' behind ....ouch ![]() Your example could be ceremonial, but am sure a spear butt nethertheless. Kind Regards David |
#11 | |
Thank you Barry
#12 | |
![]() Quote:
Fernando |
#13 | |
![]() Quote:
I have missed your post, which you submitted whilst i was "rehearsing" mine. You know, some times i have to go back a zillion times to "improve" my louzy english in the paragraphs i find more bizarre, so my posts take ages to be submited. Say, would you tell this piece is European or African ... which is almost the same as telling, would this be a modern or an ancient object ? Fernando |
#14 | |
![]() Quote:
Hi Fernando, firstly..... your English is excellent ....but please dont ask me to reply in Portugese ![]() I am not certain as to the origins...or date. Instinct suggests African but....there is a nagging doubt which I cannot 'put my finger on'. Looking at the pictures I noticed, what appears to be a rusted rivet or 'nail' ....it follows the 'centre line' position of the 'open' fixing hole. If this is the case, I personally have not seen a 'double fixing' on an African spearhead or butt ![]() Regards David PS The other hole looks to be 'punched' rather than drilled. if this is the case it would have probably been done during forging, further suggesting either 'primatively' made (meaning without more technical (industrial) tools such as a drill bit) or 'good' age .... Last edited by katana; 9th May 2008 at 01:16 AM. |
Well David,
My english was learnt in the streets; it's only mediocre because i keep checking it in the dictionary ... or in the web ![]() It's amazing how different eyes can see distinct things ![]() I don't think that's a nail mark at all; there's no countermark on the other side. What i see there is some kind of punch, like a maker's mark or symbol of some kind. That´s precisely the first sympthom that made me think this thing is European ![]() ... Plus the the iron structure, namely the socket; wouldn't African stuff be thinner ? Fernando |
#16 | |
![]() Quote:
Hi Fernando, I have an old African spear which has 'heavy' socketted butt and spearhead.....so the 'thickness' doesn't mean it can't be African. You have to bear in mind that the butt aids the balance of the spear, even if it is not a 'throwing' type ( 'hand held' spears tend to have heavy 'heads' ) A balanced spear makes it much easier to use in combat (for the same reasons as a nicely 'balanced' sword would) Could you post a 'close-up' picture of the 'rivet marking' ? Regards David |
The markings on the this spear thing seems North African to me? The Xs with the line through them often symbolize a stylized crocodile which are used by the tribes who live along the Nile in the Sudan and Egypt.
Lew Last edited by LOUIEBLADES; 9th May 2008 at 10:13 PM. |
#18 |
This is the best i can get with my tired digital camera
![]() Two shots from the mark side and one from the opposite side. This afternoon i visited someone much more enlightened than me in these things. He is pritty much convinced this piece is a locally made rustic haft weapon (pike) head ... not a butt, nor an African item ![]() On the other hand, he doesn't think this mark in the pictures is something intentional. |
#19 |
I am still intrigued with that misterious sort of mark. Althought this guy i met doesn't beleive it was made intentionally, i find it dificult to be an accidental flaw. But what do i know ?
No further coments, Gentlemen ? I would love to hear more about its tendence to be European or African, after all that has been said, as also your opinions about it being (or not) a pike (or sort of) head. Thans a lot. |
#20 |
Sorry...was away and just stumbled onto this thread. This is a Spanish colonial lance head with classic criss-cross markings and stars in the pre-Mexico styling. These markings are exactly like those found on several of my colonial cutlass (see Pirate weapons thread). I've seen several of these over the years and initially thought they might have been more South American in nature. Guachos used a primative lance with heads like this one. I know I saw one somewhere recently. Let me look around...
#21 |
Well, not the good one I saw several months ago with similar decorations, but still, an example...
www.antiqueswords.com/bq943.htm |
#22 |
Thanks a lot Mark,
I will surely follow your track on Spanish colonial stuff, as i will be much obliged you come back with any further material. The picture in the link is a start ... though my example looks a bit different ... cruder ... and older ? Could you at any time post (me) pictures of those cutlasses with the mentioned criss cross and star markings ? fernandoviana@netcabo.pt Thanks again Fernando |
#23 |
Hello Fernando,
Sorry to take awhile getting back to this thread. I am extremely computer-challenged when it comes to posting pics. RSword/Rick has helped me in the past, but alas, he has moved away ![]() |
#24 |
OK, FINALLY found one of these. Well, Jim McDougal was right on again about these cutlass being Brazilian...this is a nice one! Anyway, I digress...
Check out this link- www.jfsantiquearms.com/edged_weapons/60.html# From here, look under "more Views" and select View 3. Note the criss-cross patterning and star-like marking with dots. Last edited by M ELEY; 24th May 2008 at 05:08 AM. Reason: mis-spelling |
#25 |
Hi Mark,
I just noted the thread, and just wanted to thank you for the kind words. I was delighted when I found the Brazilian attribution which I found in another source. It was a relief for me as well to finally find the answer to these mysterious swords after all of our pondering on them ! ![]() Nice work at noting the connection on Fernando's most interesting (as always!) acquisition. All the best, Jim |
#26 |
Interestingly Brazil's historical connections with Portugal , might explain why a Brazillian piece ended up there .....or ...if not from Brazil, could indicate that, indeed, this is very old and shows the influences that pre-date the materialised on Brazillian 'pieces'. ![]() However, as already stated 'lined designs used as decoration are found in many cultures, countries and 'time periods' and may be difficult to ID. Fernando, as I said before I have a doubt this is African but, historically Portugal and Brazil were involved in the 'slave trade' and it is quite possible that your item was influenced or made by an African culture. My main 'doubt' that this is African is the fact that the 'point' is offset from the socket. All African ones I have seen have the 'point' centrally placed. A Mystery ![]() Regards David |
#27 |
As a very wise arms writer once told me, "..weapons do not know geographic boundaries".
While it may be difficult to assign a geographic attribution to this piece, the influences noted profoundly stand, and the slave trade definitely carried these far and wide via the vast routes that commerce followed. A mystery indeed David, and for all of us weapons Indiana Joneses ....the games afoot!!! (Holmes ![]() |
#28 |
Thank you Mark, both for the link and for keeping to your promise.
Thank you Indiana, i mean Jim ![]() ![]() ![]() Thank you David. If i well understand you, i don't think the point was originaly off centered; this must have happened when somebody decided that this object would make a good chisel ![]() About the provenance, i must confess that, at this stage, i have no more certainties than when i started querying on this piece, despite some respectfull opinnions posted by you Gents. However my inclination goes to both Mark's and this local guy's opinnion that it is a sort of lance or pike head. Following that reasoning, i tend to think this is not African or Afro influenced, but of (very old) European trace. Putting Africa out of question and, considering it has been picked somewhere in the interior, it would then be Portuguese or, in second place, Spanish rather than from further European countries. However naturaly i can only agree that, till some stronger evidence shows up, the game's afoot. |
#29 |
It is true that we may never know for sure, nor did I intend to poo-poo
![]() 1) The generalized shape matches that of European, American and Span Colonial in that it resembles a boarding pike-type shape, square-shaped in cross section. 2) It was apparently secured to the haft with a nail/pin or other securing device, so common on Euro/Amer/Span Colonial pikes, spontoons, lances, etc. 3) The designs on it very closely match those found on Colonial Spanish/S American swords and espada. 4) It's primitive composition and crudeness, with all the evidence above, points to "backwoods" Spanish Colonial work. If one ever looks at the iron-work from the Southwest, Mexico, the Pampas, you will see what I'm talking about. Quality ranges from very fine work (Mexican spurs and espada come to mind) to the very primitive (the put-together sword I pictured under the Pirate thread with the brazed guard is an example). In any case, I like it! Too bad someone bent it as they did. Last edited by M ELEY; 26th May 2008 at 07:18 AM. Reason: mis-spelling |
#30 |
www.classicalfencing.com/mcweaponslance.php
A quarter way down page, pic of 4 lances with one being Span 18th cent (you will see the resenblence) http://www.collectableweapons.com/Li...info.php?id=65 Shows primitive/crudeness of some pieces http://www.trocadero.com/faganarms/i...tore.html#item Note hole in base. Description says decorative notches/barbs, but unfortunately pic doesn't show this. |
