Technical question - how large should be the sabre's curvature for us to consider it a shamshir ? I am trying to arrange my material on sabres, and come to some funny conclusions.
All books I have follow Pletneva in measuring the curvature in cm (how far away the blade from the line that connects the hilt and the blade's end). Can someone say if 15cm for a meter or so blade would qualify for a shamshir ? |
Ok, here is the picture. Would it qualify to be called persian shamshir or not ?
Nah, most likely not. Sorry to bother. |
Well, literally, shamshir means sword in Persian, so how does a curvature classify whats to be called a shamshir and whats not??
I meant shamshir as in collector's slang shamshir, i.e. highly curved persian sabre. I do not share the sentiment that we need to use names consistent with local persian attributions.
If it is Persian and it is not a shamshir and definitely not a kilij, what other kind of sabre can it be? Are there other types/names? I had thought the name applied to persian sabres with a relatively thin curved blade...thinner than a tulwar for example. There are some tulwar with extreme curvature as well no? Emanuel |
Once again, getting into colloquial terms, especially 'collectors terms' causes certain problems in trying to classify weapons. For example the well worn term 'scimitar' used consistantly in Victorian romanticism has virtually no place in describing any particular weapon, and the term evolved actually from loose transliteration of the term 'shamshir'. I agree that trying to determine which sabre is a shamshir and which is a tulwar or kilij can be maddening.
It seems to me that a shamshir blade is of wide range of curvature from quite shallow to fully parabolic, and I have seen deeply Parabolic Persian blades mounted with the typical Ottoman hilt seen on kilij. I cannot decide whether this should be called an Ottoman shamshir or Persian kilij! It seems most likely to call it a shamshir in Ottoman mounts. The Indian tulwars are also frustrating. While typically mounted in what collectors term 'Indo-Persian' hilt, there are examples that seem to come from regions in Sind, that carry a solid steel Persian type 'shamshir' hilt. Would this be a tulwar or a shamshir? Since the hilt carries distinctive 'tulwar' elements (the langets and the characteristic quillon terminals) it seems it should be classified tulwar with Persian form hilt. It seems with many hybrid forms it is virtually impossible to escape more detailed wording in classifying them.Often even when new research has revealed a term to be incorrectly used (such as in the case of jemadhar vs. katar) it is difficult to unseat terms that have become imbedded in the long established vocabulary used in discussion (i.e. collectors terms). Best regards, Jim |
Then tell me, what is this?
Is it a tullwar or is it a shamshir? Learned members of the forum
Well in kukri we also run across this western need for single word pigion holing & naming labels,
But as always a rose by any other name would smell as sweet, As long as we have the ability to use a sentace rather than one word to describe a weapon or tool I think thats the option I generaly prefer. So many of them are highly individual & would escape round any exact catergerisations we imagined the label should match & Photos always help for clarity of discusian to of course! Thats a nice heavily curved shamshir or perhaps more killj type blade with a lovely & ornate tulwar grip & typical Indian riccaso you have there Jens. Spiral |
Hello again,
How about the broad characteristics of the blade? A long ricasso area and wide blade exemplifies the tulwar, while the yelman is a kilij feature. Does the classical Persian shamshir have either of these? Did Persians commonly use wide blades with yelmans? I understand these cannot be generalized to all pieces, but do they at least apply to the majority? Regards, Emanuel |
My understanding is that "shamshir" is a generic word for Persian long curved swords, just like "kilij" is a generic Turkish name for a "sword".
Mughal curved swords were mostly called Tulwar. A straight Mughal sword with the Indo-Persian handle was still a Tulwar, and the same blade with a Basket handle was "khanda". If the blade was of Persian origin (see Fiegel) it was a shamshir. A shamshir-type sword was called "Klych" (kilij) in Russia, and the same was true among the Bedouins. A shamshir was called Ajemi Kilij ("Persian Kilij") in Turkey and Yelman-ed sword was called by Persians " Shamshir Torki" ( "Turkish Shamshir"). Each country gave these swords different names, but the pattern was the same. "What's in a name? That which we call a rose By any other word would smell as sweet." "Romeo and Juliet" (II, ii, 1-2) Shamshirs were of different curvature. Even modestly curved blades were shamshirs. Abbas-period shamshirs were highly curved more often than the earlier samples. |
