Old 26th March 2026, 01:49 PM   #1
werecow
werecow's Avatar
Question Bedoein sword?
Picked up this very worn sword for the price of a pizza and a half.
It has the typical triple fullered blade you see on Moroccan nimcha and lots of other swords from around the world and horn grip scales. The shape of the grip looks a lot like those of Bedouin swords, but it's missing some of the decorative elements that are typical for the group, so I'm not quite sure. Do you think this is an accurate identification?
For reference, here's the type of sword I'm thinking of:
Old 26th March 2026, 03:20 PM   #2
Hi Nathan,
I am far away from being an expert on these swords but I think that you are correct with your attribution! You will have a lot of work with cleaning the blade!
Old 26th March 2026, 04:29 PM   #3
Bob A
Nice find, but as the interminable cleaning process grinds on, you may wish you'd opted for the pizza.
Old 26th March 2026, 05:52 PM   #4
I likes em as they are! rough,
This seems, by the hilt style, to be Bedouin alright, and of forms in Sinai Peninsula, but of course hard to be exact.
Old 26th March 2026, 09:53 PM   #5
Yup, bedu. Also Sinai area, as Jim mentioned.
Mine for comparison: Mine is missing the silver band on the pommel end of the horn grip.
Old 26th March 2026, 10:35 PM   #6
Pertinax
Pertinax's Avatar
[QUOTE=werecow;302787]Picked up this very worn sword for the price of a pizza and a half.
Congratulations, a very interesting subject. And the chores of cleaning always bring pleasure.
Old 26th March 2026, 11:07 PM   #7
TVV
TVV's Avatar
Congratulations from me as well, these swords are not all that easy to find in my experience. I used to dread cleaning heavily corroded blades like this when I was trying to do it by hand, but since I discovered chelation agents, which do the work quickly and easily and only attack the iron oxide molecules, without harming the blade underneath, it is no longer a problem.
Old 26th March 2026, 11:41 PM   #8
RobT
RobT's Avatar
Default What Product Do You Use
TVV,
I use a US made chelation product called Evapo-Rust. I totally immerse the blade in the solution for 24 to 48 hours in tanks I have specially made. It works quite well for red rust but isn’t very good on black rust. Do you use a different product that works well on black rust?
Sincerely,
RobT
Old 26th March 2026, 11:53 PM   #9
werecow
werecow's Avatar
Thanks all! Nice to have that confirmed. I already soaked the very dried out grip in neatsfoot oil for a day but a large chunk has started to peel off, as you can see in the pictures. Not sure what I should do there. Just leave it be, or...?
As for the blade, I will give it an initial light cleaning to get rid of active rust and will save the rest of the work for when I can sit outside.
This one didn't drain the wallet too much so I still have enough for another pizza.
Hi Nathan,
I'm Jelle, but hi Detlef!
Old 27th March 2026, 12:04 AM   #10
TVV
TVV's Avatar
TVV,
Sincerely,
RobT
I use EvapoRust as well, and a tank made out of PVC pipe. The EvapoRust is usually fully spent and black after 48 hours, and while not prohibitively expensive, may not be the most cost effective solution. There are YouTube videos with formulas for homemade chelation agents with really cheap ingredients (even EvapoRust is 90%+ water, after all), but I am yet to test them.
Old 27th March 2026, 12:12 AM   #11
werecow
werecow's Avatar
Yeah, I've actually been meaning to try out this one:
https://www.youtube.com/watch?v=WhzNttK_-ko
https://www.youtube.com/watch?v=dCltNiN_LGc
Might be a good candidate for it.
Old 27th March 2026, 12:26 AM   #12
TVV
TVV's Avatar
I tried the jelly but did not like the results. Soaking in a liquid solution works better. You may want to try this one:
https://www.youtube.com/watch?v=fVYZ...qPtn56&index=1
Old 27th March 2026, 06:08 AM   #13
Sorry Jelle! I was in the wrong fairytale!
Old 27th March 2026, 12:42 PM   #14
werecow
werecow's Avatar
Ah, I've come across that before as well I think. I will give it another look, thanks!
No worries. I go to a lot of expat social events and it sometimes takes months to learn people's names. At one point I was talking to one nice guy on and off for 6 months and I kept hoping he would introduce himself to another guest because it was too awkward to ask at that point.
His name is Dave, btw. I learned that maybe a week or two before he moved to another country. I probably could have guessed at random since this meetup was maybe 20% daves.
Old 27th March 2026, 01:55 PM   #15
werecow
werecow's Avatar
One more question. I want to stabilize this bit of horn that is sloughing off on the grip so that it doesn't get worse. I was thinking of just putting a few drops of glue in there to fill up that crack. Is that an acceptable repair? And if so, what glue is best for antique horn?
Old 27th March 2026, 07:45 PM   #16
Pertinax
Pertinax's Avatar
To remove rust, I use 3% iodine monochloride (ICl), which removes all rust down to the bare metal.
It's available at pet pharmacies.
The vapors it releases are harmless and can be reused. Apply with a brush, and wear gloves when using.
Old 27th March 2026, 11:49 PM   #17
I would use a two-component adhesive and a zip tie to hold it in place until it's dried.
Old 28th March 2026, 01:56 PM   #18
werecow
werecow's Avatar
Alright, that seems sensible enough, thanks!
Also, let's cross-link to a couple of other threads for future navigability:
Bedouin? Saber
Bedouin Sabre
And a few examples from elsewhere:
ARAB BEDOUIN SWORD SHASHKA CA.1900
Good Bedouin Sword from the Sinai Peninsula - 9767
Acquisition of late 19th to early 20th century sword
Old 28th March 2026, 09:43 PM   #19
kahnjar1
kahnjar1's Avatar
Easy rust removal....suitable piece of PVC tube and White Vinegar. Just leave blade in the vinegar as long as it takes. You will see almost immediate progress. A very cheap and safe method.
Stu
Old 1st April 2026, 01:13 AM   #20
RobT
RobT's Avatar
Default Dry Clamp First & Use A Clamp To Glue
wildwolberine,
Before you do the glue up, dry clamp it first. Make sure you use wood pads (known as cauls) to protect the hilt from the hard steel jaws of the clamp. If the part of the hilt that is separating can be drawn back down fully, you are ready to glue up. When you apply the glue (all crafts 2 part epoxy is my favorite), use as little as possible to make sure that no glue will squeeze out to become visible when the clamp is applied. I would recommend using a clamp rather than a zip tie because the clamp can provide far greater pressure. I would probably opt for one of my Jorgensens but even a c-clamp will do.
Sincerely,
RobT
Old 9th April 2026, 07:25 PM   #21
chregu
chregu's Avatar
Hello everyone
It's been a very long time since I posted.
In my opinion, the weapon pictured is a "Leppa Sarda".
http://www.vikingsword.com/vb/showthread.php?t=27626
Old 10th April 2026, 12:11 PM   #22
werecow
werecow's Avatar
Interesting alternate hypothesis! But it does not have the pinky rest that most of the Leppa Sarda shown in that thread seem to have. Are there any specific features that make you think this is one of those, as opposed to their Bedoein sword cousins?
