Old 11th December 2025, 12:09 PM   #1
Pendita65
Default Latest addition
Hi fellow members,
I recently acquired this Keris with silver pendok. I think it's a Keris Gayaman Surakarta, it's missing a mendak and could use some TLC. I would like to know what this type of pendok is called as I could not find much info about it's decoration. The wilah is not that tall and 5 Luk.
So hope to gain some more info about this Keris.
Thnx for now and regards, Martin
Pendita65 is offline   Reply With Quote
Old 13th December 2025, 01:30 PM   #2
Hi Martin,
Since nobody commented until now I will give it a try. Can't say something about the pendok other that it is the nicest part of the ensemble.
And yes, the sarung looks like you said, Gayaman Surakarta style. The blade is very worn and the poorest part of the ensemble, can't say something about the handle in your pictures but seems of relatively poor quality, sorry.
I guess that the worn blade is the reason that nobody has commented until now.
Alan would be the person who could tell you something about the pendok.
Old 13th December 2025, 03:56 PM   #3
Pendita65
Hi Detlef,
i thought allready that this keris didn't sparkle to the people on here.
And beside the fact that i know that the blade is worn i didn't regret buying it, as i really like the quality of the pendok, and finding nice qualtiy pendok is also not that easy nowadays.
Regards, Martin
Old 13th December 2025, 04:40 PM   #4
Hi Martin. It is an interesting pattern on the pendok that i don't believe i have seem before. Are you sure it is silver though. Doesn't really appear so in the photos, but that might just be a bad colour balance.
Sure, the keris itself is nothing to write home about, but that doesn't mean it is not worth collecting as long as the price was right. It's pretty basic village work, but you should not regret buyingit as long as you are happy with it.
I am trying to decide if the gandik is long enough for it, but i think i would call this a dhapur in the Kebo family.
The blade sits weirdly in the hilt. I don't know if this is because the hole is poorly drilled in the hilt or if the pesi is bent. It would be nice to fix that, but if the pesi is bent i would not necessarily try to bent it back. Can we see a photo with the hilt off?
Also, a mendhak would be an easy and relatively inexpensive way to complete this ensemble and make it look a little better, especially if you can refit it all better for a proper condong leleh.
Old 13th December 2025, 09:45 PM   #5
Alan is unable to put a name on this pendok motif, overall it looks like a Banyumas pendok, but it is not really out of place matched to this wrongko. It might be silver, might be mamas, no way of knowing short of a test, but it doesn’t really matter, there is no real difference in quality or value between the two materials at this end of the scale, it will be quite light in weight. Light polish with 0000 steel wool, or maybe just a silver cloth.
I think I’d be inclined to strip the wrongko of its finish with medium grade steel wool and methylated spirits, re-polish then give it a few coats of danish oil, take the shine off the final coat with a light once over with 0000 steel wool, it will come up pretty nice.
The hilt pretty pedestrian, but its OK, I would not re-finish this,I think, hand rub with furniture oil and wipe off with a soft cloth will help remove dirt, brush the carved areas with a tooth brush.
As previously commented, the blade is not great, but that is not necessarily a negative. If we study the keris, we need to understand the entire spectrum, not just the high art. It is a keris, it is quite representative of a lower level, it has a couple of unusual elements, one of which is the gandik which is too long for normal proportions, too short for a kebo. It is, I believe, a pretty old blade, perhaps classifiable as Pajajaran, but I’d need it in hand to be a bit more sure of that. Its OK for what it is.
As David remarked, the hilt is not well fitted. Remove it, clean out the hole, there might be some old, loose binding stuck there that prevents the hilt from sitting correctly. If the pesi (tang) is a bit skewed, give it a bit of heat from a torch, just black hot, use something as an anvil, maybe part of a bench vice, & lightly tap back the pesi into a correct alignment. That tang should be quite soft anyway, heat treat never goes anywhere near the tang, & I doubt there is much evidence of heat treat left in this blade anyway. When we quench a blade, that hardness lessens the further it penetrates the blade, and I believe that maintenance over time will have removed much of the hardness from this blade.
When you are confident that you can bring the hilt into alignment with the blade, use knitting wool as your material to bind the hilt, & get hold of a mendak, which should not be difficult. I’d be quite prepared to give you one that would do the job, but the postage would cost vastly more than the mendak would be worth, so that’s not an option, maybe somebody who lives closer to you might be able to assist.
Tidied up a bit, this keris has the possibility to present quite nicely.
Old 14th December 2025, 12:04 AM   #6
Martin, I understand you very well! I buy keris sometimes for parts only, wrongko, pendok, handle and mendak. And when the pendok is indeed from silver and the price was right, you did well!
Old 15th December 2025, 05:39 PM   #7
Pendita65
Dear Mr. Maisey,
thank you your reflection on the Keris, and yes in the photograph the pendok is a bit coloured by the light, but i think it is similar to Djokja Silverware. I will make better pictures later. I have some good mendak laying in a box that is still unpacked and waiting for me on the attic.
I will lightly clean the wrongko, and polish it again. I know from experience the wood turns a bit more darker and makes it more vivid in colour.
Regards, Martin
Old 15th December 2025, 05:41 PM   #8
Pendita65
Thanks Detlef, and yes i also buy them for the materials sometimes to restore the other ones in need of some tlc.
Regards, Martin
Old 15th December 2025, 08:03 PM   #9
Yes Martin, the embossing could have been done in Jogjakarta, or at least by somebody working according to the principles of the Jogjakarta school, but the motifs & overall presentation is indicative of Banyumas, and the profile of this bunton pendok is acceptable for a Solo wrongko as well as a Banyumas wrongko.
The material used can only be determined by test.
Old 15th December 2025, 08:47 PM   #10
..& overall presentation is indicative of Banyumas, and the profile of this bunton pendok is acceptable for a Solo wrongko as well as a Banyumas wrongko.
Hello Alan,
Is there a significant difference between Solo and Banyumas wrongko?
Old 16th December 2025, 02:30 AM   #11
I guess the answer to that question is:- "significant to whom?"
At the present time, & for a long time in the immediate past it seems that the Surakarta style of wrongko, both gayam & ladrang, has dominated Javanese style. These Surakarta styles have become almost the Javanese generic style, and very often I find it difficult to know if I am looking at a true Surakarta wrongko, or a broadly Solo wrongko, or a generic wrongko that reflects elements of one of the dozen or so legitimate Surakarta gayaman forms or dozen or so ladrangan forms.
Banyumas never had the same level of authority that Surakarta & Jogjakarta had, it was established some time in the 1500's, and later its bupatis (regents) were appointed by Surakarta, so in many ways it did come under Surakarta influence, but it had its own language & sub-culture. Coming under Surakarta influence, it naturally followed Surakarta in dress styles, & this includes keris dress styles.
For me, the biggest single differentiating factor between Surakarta keris dress & Banyumas keris dress is the pendok, which usually has a curved top that rises above the joint between gandar and gambar (if that joint is present), the pendok motif is usually broken into panels as we can see in the keris under discussion. There are differences in the planar hilt style also, it is broadly the same as Solo styles, but usually has kruwingan work in panels that rise to the bun-bunan.
I have been told, but have not personally seen sufficient number of examples to confirm, that the Banyumas gambar is "like Solo, but not as refined", so it seems it is always a pretty subjective judgement & perhaps can only be relied upon from somebody with lengthy experience of both Solo & Banyumas wrongkos.
So --- I'd say that the difference between Surakarta wrongko & Banyumas wrongko would be quite significant to somebody in the Surakarta hierarchy who was a stickler for correct form, but for people with no real understanding of what was correct form, & what was not, any differences might be not significant at all.
Old 16th December 2025, 10:47 AM   #12
Thank you Alan for the detailed response. You write what I thought of myself.
Old 18th December 2025, 05:42 AM   #13
Pendita65
Thank your Mr. Maisey, for this very interesting explanation about the Banyumas. Is this topic also written down in any books about the Keris?
Regards, Martin
Old 18th December 2025, 12:08 PM   #14
Not to my knowledge, Martin.
Tags
keris, pendok
