Hi all - I would welcome opinions regarding this intriguing little gun I recently purchased from this ad: https://www.gunsinternational.com/gu...n_id=103305447
The tri-barrels are approximately 12.6mm caliber; the buttstock barrels approximately 7.5mm. Overall length 81 cm, weight 3.964kg. |
Lovely. The tri barrles look like they had pan covers. Are there any on the butt barrels? Which I assume were touch fired.
Most interesting and unusual weapon. Just an observation.....the rammer appears to have a brass cartridge end to it with a LIVE primer showing!!
![]() Stu |
It looks more like a brass bushing peened onto a steel rod, after all you don't want your ramrod striking sparks off the barrel do you.
That’s what it seems. There are retaining pipes for a second (missing) ramrod. The ramrod present fits the tribarrels, but isn’t long enough. At a guess the second ramrod would screw into the first, and also have a head small enough for the rear barrels. At least that’s how I’d have done it.
How old do you think this matchlock is?
I would welcome speculation.
The best period 16th century comparisons I found in this thread: http://www.vikingsword.com/vb/showth...necht+arquebus Last edited by Lead Snowstorm; 13th December 2025 at 04:39 AM. |
#9 | |
#10 | |
Fortunately the seller is a member here and perhaps can provide some further clarification. |
