|  15th December 2024, 09:57 AM | #1 |
| Member Join Date: Aug 2007 Location: Germany, Dortmund
				 |  Restoration of a Sulawesi alameng
			Hello dear members, I won a rusted Sulawesi sword (alameng) for low money by a German auction house. It was described as mandau!  I've decided to let you see my restoration, first step has been to give some linseed oil to the nice horn hilt. The blade was/is badly rusted, the first step will be to de-rust it, one side I have nearly finished. When the blade is rust free I will work further at the blade to let it look nice again but it will take time so this thread will continue. The alameng is 60 cm long, the blade is 44 cm and 8 mm thick at the spine behind the handle and quite heavy with 621 gram. The blade is ground slightly hollow on both sides and has a "V" shaped cutting edge. Last edited by Sajen; 15th December 2024 at 06:08 PM. |
|  15th December 2024, 10:01 AM | #2 |
				 |  the handle
			Pics from the handle.
|  15th December 2024, 11:31 AM | #3 |
| Member Join Date: Sep 2005 Location: Singapore
			Excellent - great to see restoration process. Interesting piece, I have not seen thst style of hilt. What was your method for removing rust from the first side?
|  15th December 2024, 12:56 PM | #4 |
| Member Join Date: Feb 2023 Location: Amsterdam
			Hi Detlef,  looks good the de-rusting, the linseed oil you used was it boiled or cold pressed oil? And did you soak the handle or used a rag to apply the oil? I am curious if you used a wire wheel for derusting or only waterproof sandpaper? Nice Alameng btw. Regards, Martin |
|  15th December 2024, 03:21 PM | #5 |
			Hi Jeff and Martin, Thank you both! For the cleaning of the blade I used a rust rubber gum and at places where it was hard and encrusted rust I used a stone. No power tools involved!  I have used cold pressed linseed oil for years for wood, horn and other natural materials. Attached are two pictures from "Senjata Pusaka Bugis" of a very similar sword. Regards, Detlef |
|  15th December 2024, 04:31 PM | #6 | |
| Member Join Date: Dec 2004
				 |   Quote:
 Thanks for sharing your restoration methods. For us that don’t know, could you please tell us what a “rust rubber gum” is? I like to other rust removal items other than sand paper. | |
|  15th December 2024, 04:52 PM | #7 | |
				 |   Quote:
  Attached is a pic of such a rust rubber gum, I buy them on Amazon. They work well by surface rust and a little bit deeper rust. Regards, Detlef | |
|  16th December 2024, 12:35 AM | #8 |
|  16th December 2024, 06:05 AM | #9 | |
| Member Join Date: Jan 2007 Location: The Netherlands
				 |   Quote:
 (That's what I usually use) | |
|  16th December 2024, 12:50 PM | #10 |
|  16th December 2024, 02:24 PM | #11 |
			Am I just not patient enough with 0000 (or 000) wool? I find it almost never removes anything but the most superficial rust, but I'm not sure if I give it enough time. Am I supposed to keep going even if I feel like I have not made noticeable progress after a few minutes? Also, I'm curious on the type of stone and method you (Detlef) use for deep rust pockets. If soft enough I will use a metal pick but often find rust crusts to be extremely hard and need abrasive anf/or repeated acid washes (vinegar) to remove.
|  16th December 2024, 02:30 PM | #12 | |
				 |   Quote:
|  26th December 2024, 11:20 AM | #13 |
			It's cleaned now, here are some pictures. The last two pics show it together with two other similar Sulawesi swords from my collection.
|  26th December 2024, 12:59 PM | #14 |
			That's a cool Celebes grouping you've got their Detlef!   |
|  26th December 2024, 01:40 PM | #15 |
			Thanks Maurice!   The "new" one is a very massive chopper with heavy lamination. I've rubbed the blade with lemon juice but it needs a stronger etchant to show it better. Here a pic without flash to get an impression. Best regards, Detlef |
|  26th December 2024, 01:53 PM | #16 | |
				 |   Quote:
 Regards, Maurice | |
|  9th February 2025, 01:22 PM | #17 |
			Another short alameng entered the collection with another handle form. One side of the blade is cleaned from surface rust, when the other side is also cleaned I will post a new group picture. The blade was badly bent but I was able to straighten it again perfectly. 48 cm long with a blade from 38 cm. |
|  9th February 2025, 10:03 PM | #18 |
			Nice swords Detlef your collection keeps growing piece by piece "chapeau"
|  9th February 2025, 10:30 PM | #19 |
			Would you consider this the same style? 51cm blade with thick 8mm spine at base.
|  9th February 2025, 10:58 PM | #20 |
			Thank you Martin!   Often I find them by accident!   |
|  9th February 2025, 11:04 PM | #21 |
|  10th February 2025, 01:41 AM | #22 |
			For sure Toraja. Here it is next to a dua lalan and you can see the close match in style. Also the other alamang with more classic hilt shape has Toraja style.
|  10th February 2025, 09:08 AM | #23 |
|  10th February 2025, 09:11 AM | #24 |
			Here a new group picture, also a close up from the handles. Three blades show a talismanic pamor at the base.
|  10th February 2025, 11:46 AM | #25 |
|  10th February 2025, 11:47 AM | #26 |
|  10th February 2025, 01:35 PM | #27 |
|  10th February 2025, 03:21 PM | #28 |
			Another example. Big one, 70cm OAL w/51cm blade & 7mm spine.
|  10th February 2025, 06:38 PM | #29 |
			Very nice alameng Jeff!    |
