Closed Thread
Old 16th September 2023, 01:28 AM   #1
wildwolberine
wildwolberine's Avatar
Default A couple interesting knives
Sharing these two recent acquisitions. I haven’t seen anything quite like either so I’m hoping a forum member can help. I don’t believe they are especially rare or desirable but they’re both well made with nice leather sheaths.
Top: I thought this was puukko adjacent. Utilitarian wood hilt with dog-leg at end. Chisel ground blade marked “IND”. Leather sheath with loop. Blade 11 cm, OAL 26 cm
Bottom: Central Asia? Hilt comprised of multicolored clear plastic discs. Brass guard and fittings. Extensive ornamentation - floral patterns, rhinestones etc. Tubular leather scabbard like a puukko, with a retention strap. Embossed pattern. I suspect this is a tourist piece but it’s well made and functional. Blade 13 cm, OAL 23 cm
Coincidentally, these have remarkably similar sheaths.
wildwolberine is offline
Old 16th September 2023, 05:04 PM   #2
Interested Party
Interested Party's Avatar
The top one marked IND is familiar, but I just can't quite place it. Is it's choil sharpened with a chisel edge as well as its blade?
Interested Party is offline
Old 16th September 2023, 05:51 PM   #3
wildwolberine
Thanks! No, the choil isn’t sharpened.
Old 16th September 2023, 09:27 PM   #4
The IND one is Bali or close by.
A. G. Maisey is offline
Old 17th September 2023, 12:25 AM   #5
Ren Ren
Ren Ren's Avatar
This knife is typical of Uyghur knives from Xinjiang China. Due to severe restrictions on the production and sale of traditional Uyghur knives, they are becoming quite rare.
Ren Ren is offline
Old 17th September 2023, 12:28 AM   #6
Ren Ren
Ren Ren's Avatar
The leather sheath rather points in the direction of the Philippines.
Ren Ren is offline
Old 17th September 2023, 01:44 AM   #7
wildwolberine
Thanks! That’s interesting. I was able to find this knife online, the origin is Hotan, southwestern Xinjiang.
Old 17th September 2023, 01:58 AM   #8
wildwolberine
Thanks! The blade profile resembles the Balinese “mutik” utility knife. The sheath resembles other Balinese sheaths I found online. Could not find an exact match for the handle, but that certainly narrows it down.
Old 17th September 2023, 10:56 AM   #9
The blade of the one I ID as Bali is typical of most Balinese work knives --- I'm assuming it is chisel grind, if it is not, then I'm wrong.
The hilt is not typical of Bali, but I have seen a couple of Bali knives years ago with a similar hilt. Usually Bali hilts will have a central ridge along the underside.
The leatherwork is very typical of Bali.
Old 17th September 2023, 03:49 PM   #10
wildwolberine
Thanks! Yes, the blade has a chisel grind. The hilt definitely has a central ridge or keel. I think we’ve pinned this one down!
Old 8th July 2024, 02:22 AM   #11
wildwolberine
I found another one of these Balinese utility knives. Similar to the first, but this has a wood sheath
Old 11th July 2024, 02:58 PM   #12
milandro
It certainly makes me think of the many knives with text which we see in the NL.
Almost all (even when the shape is not typical from there ) are originally from Tjekeroeh
milandro is offline
Closed Thread
