I just picked this knife up and to me it looks S.E. Asian, maybe Cambodian or Vietnamese. It has a heavy, sharp 11" blade(the cutting edge is on the inner side), with a crude wooden scabbard.
Last edited by drac2k; 18th January 2024 at 09:10 PM. Reason: correct punctuation |
To me this looks like a shafra - the utility knife that goes in the back of the scabbard of Omani khanjars. If you search the forum for shafra you will be able to see some examples.
Not S E Asian but as Teodor says is Omani or that region. A bit big I think for a Shafra but there is a larger version (which I think yours is) which is worn in the belt or sash. The exact name of the larger one escapes me but I am sure someone here will know.
Stu Have done a bit more digging. This knife is called Al Kusha....refer http://www.vikingsword.com/vb/showth...ighlight=kusha The shafra blade is (generally) straight rather than curved. Stu Last edited by kahnjar1; 19th January 2024 at 01:55 AM. Reason: More info |
Thanks, guys, you sent me down the right path and the Viking archives were a great source of information; based on the size of the knife, I agree that it is an Al Khusa.
Its a khusa, correct! but more towards Yemen and Southern Saudi. Though this type is well documented slightly north. Nice example.
Thanks
