Old 4th March 2023, 08:58 AM   #1
milandro
Default Bolo for commentary
I have recently acquired this Bolo , or at least I suppose it is. I don't know if it can be called a Luzon weapon.
This weapon has been brought to the Netherlands in 1949 from a Dutch soldier, the father of the seller, acquired it while serving in Indonesia during the independence war.
I don't know how this travelled from the Philippines to Indonesia but this is the record I have. I have bought another two blades from him one from Yogyakarta and the other one from Madura and as far as I know, he was stationed on Java.
The Item looks a bit older in real than it looks in the pictures, the blade has a very think spine, 8mm and the blade measures 36,5cm from tip to ferrule. The blade is very nicely and ornately chiseled.
The sheath is very well made albeit very light and going through the many pictures of bolos that I have watched I didn't find any like this. It was certainly specifically made for this blade .
I would like people to comment on which tribe may have been this made by and if this would fall under the Luzon weaponry or not.
Old 4th March 2023, 09:23 AM   #2
A nice and very dangerous looking weapon.
I can't offer much more than that weaving on the scabbard is very Borneo like even though the blade looks very northern Philippines like... the pommel too has a Borneo flavour... detail of the blade decorations may reveal more?
Nice looker and very practical.
Old 4th March 2023, 09:29 AM   #3
milandro
cheers, it may certainly have been going through Borneo-Sarawak and then reaching some other Islands.
I though it was an interesting piece, the scabbard shows a very ornate weave which is what made me think that this couldn't have been the middle of the road soldier souvenir which we often see.
The closest blades that I found ( but not the same) were certain Malay Parang Bolos but they were missing this type of scabbard and the chiselled blade , also the hilt, while similar was rather different
Old 4th March 2023, 10:52 PM   #4
Post Definitely not Filipino
Hello André,
A pic of the full scabbard from both sides might be good. One would possibly need to get a real close look into it to check whether this really was made for this sword or is a later marriage with just a really nice fit.
From the pics, the scabbard is more recent Borneo - it certainly seems post-war. The carving is quite rough and the rattan braiding is typical for many Dayak groups and seen on even later examples.
The sword is from the central Sumatran highlands: possibly Mandailing (the area got devastated during the Padri turmoil and received lots of Minang influence during the 19th century; the later pieces originate from one of the main Sumatran blade manufacturing sites). Hilt and general style of this piece also seem to be post-WW2. Not a common type but some of these do crop up, especially in the Netherlands. (Not all of these have a cross guard. An older example is published in Steel and Magic: #13)
Old 4th March 2023, 11:24 PM   #5
Hi milandro,
Handsome looking item. I agree with kai, this is central Sumatran in origin and post-WWII in manufacture. Two questions, an observation, and another question.
Is the edge chisel-ground or V-ground, and is part of the back edge sharpened?
The down-turned quillion on the guard appears to reflect a Chinese influence. Kai, do we know whether Chinese settlers or merchants ventured as far inland as the central highlands of Sumatra?
Old 4th March 2023, 11:29 PM   #6
One of the guardless sub types from Sumatra, the others that utilize this guard are not on this PC, will see if I can find some examples.
A personally feel this entire piece of yours is a WWII + period weapon from Murat Sabah... guard a personal thing... the same elegant guard style can be seen on some of the rarer Sumatra Silat weapons and also in Vietnam... but they are typically attached to the pommel too, although examples can be found with the floating guard.
https://www.thestar.com.my/lifestyle...machete-making
Old 5th March 2023, 02:17 AM   #7
Post
Hello Gavin,
As evidenced by the sewar-like bolster, this is yet another family of blades from the same area. The blades do come in different shapes and also the hilts vary quite a bit!
Please explain (I don't see anything similar in the link you added). BTW, Sabah or Sarawak?
The swords we're discussing here are not from Borneo. Also note that the scabbard seems way too long for the blade.
Visual references would be good, Gav.
Yes, both guard variants can be found with this type of blade.
Here's a knife-size version from the same period as the one André showed (pic courtesy of Maurits).
Old 5th March 2023, 02:45 AM   #8
Post
Hello Ian,
All examples I saw have symmetrical bevels (V grind). The back edge has a steep bevel that doesn't lend itself to sharpening, especially with the longer blades.
I can't recall any historic references. There has been enough and longstanding influence in the area for ideas to spread, anyway.
I'd assume that the trade to the coastal ports on both sides of Sumatra was done by the Minang though. At least the pre-colonial production seems to be by local artisans IMHO.
Old 5th March 2023, 03:07 AM   #9
Hi Kai,
A nice comparative example in all aspects, thank you.
The Mandailing origins look spot on for the type overall and with this one Michael presents with a guard http://www.vikingsword.com/vb/showthread.php?t=5089
The image within the link is a modern generalization showing the use of metal guards in more modern Borneo production. ( And yes, Sarawak, "mental fart")
It would be nice to see the reverse of each blade... does the example you show have a chiseled edge blade?
I am not clear if Milandro is confirming his is a chisel edge blade? Seems alluded to rather than confirmed? Milandro?
Whilst I do now see these as ethnically the same visually, please bear with me please....I am not familiar with chiselled edge blades in Sumatra, that aspect seems more Northern Philippines/Borneo by nature as far as manufacture goes historically???
Gav
PS, I missed the post directly above whilst posting myself....
Old 5th March 2023, 08:33 AM   #10
milandro
Thank you all for all the learned comments , I have much to learn about many things.
Let's start from the end, this is not a chisel edge blade (methinks) it is V edge blade , it isn't sharp now and I think it was never sharpened. The upper front edge is not sharpened too (and looks slightly different from the knife shown here which is otherwise the twin brother of my blade)
The scabbard is indeed longer than it need be, and could be a clever adaptation to fit the blade what makes me think this was made for this blade is the fact that the downward pointing part of the guard (the quilon I believe) fits nicely in a receptacle on top. Could be by chance but it is a very clever thing.
The pictures are from the seller and ( I don't know why) the system here uploads them and makes them less sharp than they are), my observation is that both the engraving en the braiding are finer in real that they are on pictures , also the blade looks considerably older from close by than it looks on the pictures ( probably due to refection).
I am not inferring that this isn't a post war weapon, I am rather convinced that it was acquired (1949) when the blade was new, but it is very probably (I believe the seller who was selling some weapons from his deceased father) a soldier's souvenir, as the majority of Indonesian blades we see in the NL, acquired at the time of the independence war.
Last edited by milandro; 5th March 2023 at 09:29 AM. Reason: spelling due to automatic correction
Old 5th March 2023, 09:27 AM   #11
Most helpful images and further data.
It is clearly as Kai notes.
Looking at the scabbard in full detail, it is certainly a mandau sheath and not intended for this knife.
Congrats, it is a good thing and of the period you note.
Old 5th March 2023, 10:04 AM   #12
milandro
Hello André,
Thanks Kai! your information gave me the possibility to search Mandailing Swords and I found another thread with almost identical swords (albeit even finer in quality than mine) no scabbard there.
Searching further using this term I came across the term Piso Sanalenggam which looks different in terms of hilt and doesn't show engravings on the blade but the shape of the blade looks the same.
http://www.vikingsword.com/vb/showthread.php?t=6928
Old 6th March 2023, 10:44 PM   #13
Hello André,
Nice old to vintage so called Mandailing klewang found its way in your collection and will look much nicer after a little bit of TLC.
Not much to add to what Kai already has said, scabbard doesn't belong to the sword and the blade shape resembles the piso sanalenggam you have pointed out seemingly already. No great surprise that the blade shape is similar since the Mandailing belong to the Batak ethnos.
Old 7th March 2023, 08:13 AM   #14
milandro
Thank you Detlef , I am very happy about this blade.
What would you suggest to do and how in terms of TLC?
Old 7th March 2023, 09:37 AM   #15
Hello André,
The handle I would polish with linseed oil, the wood looks very dry. The oil preserves the wood also for cracking. The wood will get a little bit darker but will look much better. The metal, blade, ferrule and guard I would rub with steel wool to remove the initial rust.
To conserve all you can add with a soft cloth antique wax.
Old 7th March 2023, 09:40 AM   #16
PS: The scabbard is something for the spare part box, it doesn't belong to the sword.
Old 7th March 2023, 09:50 AM   #17
milandro
thank you for your advise I will certainly take it to heart. 🙏🏼
I am curious to see what an appropriate scabbard would be, not that I think there is any chance that I ever come across one but just out of curiosity.
Another thing is the D guard. It has, on the D guard which is not fixed to the hilt, a mark where, quite obviously would have been a hole to put a screw or a nail to fix the blade in place, nobody did go through with that and the guard was never fixed to the hilt. I have been debating, with myself, whether this would be a good idea or not it really adds nothing to the way you can grip the sword , note that in this thread this similar sword has that screw, also that sword too has no scabbard (at least not one shown in the pictures)
Old 7th March 2023, 10:39 AM   #18
The described TLC receives all what comes to my collection. Oil to all natural materials gives them back the "oily wetness" (I don't know to describe it better) they have lost in time. And rust is to be avoided, corrosion is active and dangerous.
I have never seen one!
I personally would attach the guard, but not with a screw or nail I will have by hand. It should be something which fits with the style. I think that it is an adequate "restoration".
