Old 22nd February 2023, 12:52 AM   #31
JoeCanada42
JoeCanada42's Avatar
Yes the cross section is convex on one side and concave on the other.
I tried to photo this earlier, and recently aswell, when in your hand you can definitely notice it, I tried taking photos looking at the blade from the point but it doesn't show much, I will work some more on a good photo later. in person looking from the point you can defenitly see these angles
and yes the angle of the blade has a slight curve sideways, upwards if your right handed, I show this in the recent photos I posted. i have a moroco nimcha and talwar also with small slight curve sideways like this near the point.
i beleive this was also to help with cutting, to avoid the shoulder when say taking a head,
schola gladiatora has a youtube video where he mentions this, and many other mandau sword I seen on youtube had that angle as well as the concave convex cross section. that sideways bend is the one i referred too having seen more pronounced on other mandaus.
JoeCanada42 is offline   Reply With Quote
Old 22nd February 2023, 01:05 AM   #32
JoeCanada42
the tjikeroeh swords do seem to be interesting and very similar...
I still need to research English Wilkinson blades sold in the area.
the tang does not seem to be welded, it is very corroded black but seems flush and solid except for that little bit of extra metal( and i was pretty shure it was metal), I did give it a second look when I noticed that before you mentioned it, and as far as I can tell it looks like one solid piece, not shure why that would be left there, thinking about it now ,..maybe someone tried to solder a replacement guard? I will also try to get better photos of that part.
and werecrow thank you very much for sharing that photo, maybe it will help solve the mystery. I'm guna look into the markings myself, hopefully though someone else has seen similar ,
Kai, how about the style of the Gagang ?
Old 22nd February 2023, 01:20 AM   #33
JoeCanada42
here it is again highlighting a previous photo
Old 22nd February 2023, 04:24 AM   #34
Joe, no matter how many times i look at the photos you posted i am afraid i am just not seeing a concave/convex cross-section on you blade. It should look something like this.
Old 22nd February 2023, 04:24 AM   #35
JoeCanada42
I want to share a though I had before I forget it...
ever play hockey as a kid,
with those cheap plastic hockey sticks,
and you almost instinctually bend blade,
so you can have a good slap shot
Old 22nd February 2023, 04:42 AM   #36
JoeCanada42
the cross section as i see it
in actuality the cross section doesn't come to the sharp point till past the dotted line
the concaveness starts really to show also at the end of the dotted line at as it becomes sharp
* here edited to have more proper picture
Old 23rd February 2023, 11:31 AM   #37
Hi Joe,
Interesting sword that you have shown in some detail. I agree with the comment that this hilt is made from antler rather than bone. The carved structures show a lovely amber color that seems to come from handling, sweat, dirt, and smoke (from indoor fires), a color distinctive of older Borneo hilts that have been used a lot. The angle of the carving that juts out from the hilt is not anatomically consistent with a primate bony structure.
As to age, it is very hard to judge from pictures. Your hilt certainly looks as though it could be a hundred years or more old. Again, I would base that on the patina of the hilt.
The blade is an odd one and very hard to assess with the substantial oxidation and grime on it. Whether or not it is a mandau is hard to say, but others have given you reasons why it may not be. If you want to know more about this blade, I would suggest cleaning it and taking it back to white if you can. That will give a much clearer idea of any marks that may be on it. If you want to darken the blade again, treatment with vinegar produces a nice grayness and will sometimes pick out laminated elements. Make sure then to oil it well or use a micro-silicone wax (e.g. Renaissance Wax) to limit rusting,
I would leave the hilt as it is. That patina is attractive IMHO and honestly come by over time.
Regards, Ian.
Old 23rd February 2023, 12:00 PM   #38
Joe, when I enlarged the letter "G" on your blade, it has a somewhat unusual appearance. The serif at the end of the top curve is entirely above the terminus of the curve. This is hinted at in a number of fonts (mostly old) but this example is about the most extreme I've seen. At the bottom end, there is another oddity. As the bottom end of the curve approaches the vertical leg of the G, it takes an abrupt dive to join the bottom of the leg. Again, I can't recall seeing that in another antique font.
I'm not an expert on fonts, but I have read a bit about them and I find the various styles interesting. Perhaps there is someone here who recognises this form of the letter G. I'm fairly sure it's not a British font and that the style probably predates 1900.
A blow up of the letter is attached.
Old 24th February 2023, 12:36 AM   #39
JoeCanada42
thanks Ian for the help
I am still having fun researching the various Tjikeroeh swords
still a lot to for me to read up on ,with what people have suggested, I unfortunately am researching way too many things at the moment... even got a library book for something else I'm research and its coming due.
I may have to devote more research to this one a bit later
( I also recently got a very different sword from Australia, I'm done with the research I can do on it for now , without it in my hands, I'm ready give some info with it when I get it. and I'm Sure my theories are just going to be loved)
anyways
so for my Dayak handle
Iban?
Old 24th February 2023, 10:10 PM   #40
JoeCanada42
the handle
Old 24th February 2023, 10:13 PM   #41
JoeCanada42
the blade and markings
still dangerously sharp
Old 24th February 2023, 10:21 PM   #42
JoeCanada42
I used a tooth brush and dish soap, then some small amount (all I had) nu finish silver polish , rubbed it on with my fingers,,,, I then scrubbed it with a S.O.S. sponge, the rust on the blade worked itself into a nice rouge paste, red the first time then brown, I washed it with soap after then water then dried it, i then repeated the process for good measure this time with a rag not the sos pad, dried it again, applied vinegar and dried it quickly, didn't treat it long at all with the vinegar, I didn't have any proper wax, I just rubbed it with a tea candle and polished it like a pair of boots.
I read about using vinegar, actually someone recommended it on my Moro sword,,, but I found it was drying up leaving stains
(as for the pommel, I don't even want to remove the cobwebs)
Old 25th February 2023, 11:21 AM   #43
The marking on the blade look to my eyes like it was a marking from the used steel, similar to the marking on one of my mandau blades: http://www.vikingsword.com/vb/showth...ghlight=mandau
Old 25th February 2023, 03:28 PM   #44
JoeCanada42
Thank Sajen for the link and info
now I got to research Long Glat Blades , among Jimpul and more...
any confirmation on my handle being Iban style or?
also I read this by Roland in another thread
A head hunting mandau is thick at the base, sharp, quite heavy, forward balanced, often "decorated" with nicks and has a concave/convex blade. The best head hunting mandau are made from clay tempered, laminated high quality steel with a beautiful hamon.
what nicks are being referred to?? , i got some nicks on surface of my blade...
mine has a similar handle to this one,,
I want to mention the art on this one , to me, looks like a view into an ant farm, like a view through windows into the ant tunnels, possibly depicting a pangolin tongue going through the tunnel. see Jim's Mandau Post recently if you havent for my ideas on these handles
Old 25th February 2023, 04:18 PM   #45
You're welcome! Long Glat was ruled out by my example, I was going by the handle from my example.
I am far away from being a Dayak specialist, I prefer to give it to others for the answer.
I think Roland referred to nicks in the edge by his example.
Old 25th February 2023, 04:42 PM   #46
Nice clean up Joe.
I am even more convinced that this blade has been adapted to this form from some other blade and has possibly been reshaped. And from the most recent photos you show i am still not seeing a concave/convex form of blade that is a key design element of the mandau blade.
What convinces me most that this may have started it's life as a different form of sword is the area on the edge side of the blade that remains flat and unsharpened and tapers distally for a fair bit of the length of the blade. I have never seen a mandau with this feature and wonder why they chose not to begin the edge of the blade for such a distance out from the hilt. Because of the way this sword is designed i can almost guarantee it was not used for headhunting and was probably more likely employed for the more common work of jungle clearing.
The letters still intrigue, but since a good part is lost to wear it is difficult to grab any useful information here. It is possible that you might be able to read a bit more of it if you did some kind of rubbing from the surface and then held it up to a mirror.
Old 25th February 2023, 09:39 PM   #47
JoeCanada42
Thanks Sajen , David,
I think its possible it could still have been owned by a head hunter at least? I heard they used many blades, and that when European steel became available it was used by choice.
Here is another thought I have been holding in the back of my mind
used as a , Pirate Sword?
Something I just staring researching...
British officer swords circa 1800 carrying this same G mark
Old 26th February 2023, 02:15 AM   #48
JoeCanada42
the G. , stamped marks
?The S matches with Mandau, Werecow found
swords dating from 1796-1803
Old 26th February 2023, 06:38 PM   #49
JoeCanada42
coin
Old 27th February 2023, 05:21 AM   #50
JoeCanada42
I read about pre regulation Dutch klewang blades and found that interesting..
but with the scabbard, handle and more unique to mandau style blade i am thinking this is older then the Dutch klewangs. maybe this form was developed by the natives , using a British blade from earlier.
I heard the natives preferred trading with the British over the Dutch because the British gave things the natives wanted like knives whereas the Dutch brought like blankets to the jungle..
perhaps even maybe this form blade was made by British in Galle for trade to the natives.
Old 27th February 2023, 05:01 PM   #51
JoeCanada42
I just heard on an episode of forged in fire with Klewangs
"when the Dutch colonial government was in Malaysia , they encountered and found the klewang so deadly they outlawed it before developing their own"
Ian thank you for your post on Dutch klewangs I found it very interesting. and it lead me the the post that included the pre regulation klewangs, thanks also Amuk Murugul whom shared that one.
Old 27th February 2023, 06:26 PM   #52
Well, Joe, please take every factual statement you hear on FIF with a huge chunk of salt if you may...
Malaysia derives from the British colonial sphere of influence - the Dutch did not enter there.
The Dutch klewang was never based on any indigenous blade. During the Aceh war(s) and resistance periods, Indonesian conscripts (mainly from the Moluccas and Madura IIRC) found the performance of the issued Dutch swords wanting, especially in close quarters - no big surprise there. Them resorting to local Aceh swords and other traditional blades initiated the development of the Dutch-Indo klewang.
These are thin and slender blades - you'd need to join at least 2 klewang blades to obtain a mandau blade. Thus, klewang blades are an unlikely source.
Have you followed up on Wilkinson and other British suppliers?
Another possibility might be modern Sunda smiths moving to Borneo and setting up shop there (most likely after independence and possibly transmigrasi).
Old 27th February 2023, 06:54 PM   #53
JoeCanada42
Hi kai
concerning the FiF episode they did say it was a short lived Dutch venture.
Thanks again for the suggestion ,but I found it hard to find any info on British suppliers and on Wilkinson blades in the area. I will try researching again. I don't know about the other idea with the Sunda smiths.
Kai, can you say anything about the style handle? Iban or?
thanks
Old 27th February 2023, 10:14 PM   #54
JoeCanada42
I feel like people are holding out on me, or is it you want me to experience the fun of researching myself...lol... jk
anyways while researching Jian swords just now. I stumble upon a post with a anther ethno sword with a G.
and this sword has the notch like mine and the Tjikeroeh swords
Ian , whats the deal with dohon palay swords?
Thanks!
Old 28th February 2023, 07:50 PM   #55
I'm not sure the "G" on this other sword has much connection to yours as it appears to be stand alone. Same with the coin. Though we might have difficulty reading it, your sword definitely has other letters marked there.
As Kai has already insinuated, you can pretty much dismiss anything the Forged in Fire guys have to say about S.E.A. weapons. They don't know jack about this stuff. For that matter, its a very bad show for blacksmithing technique as well. LOL!
I don't think anyone who has participated in this thread so far is holding back on you, but if i am not mistaken, there are members on this forum who have yet to comment who know quite a bit more about Dayak weapons.
Old 1st March 2023, 06:00 AM   #56
JoeCanada42
Thanks David,
I take all info with a grain of salt, and ya some of the forging I have seen on FiF is very questionable, to say the least .
as for the marks on my Iban swords blade I feel maybe there was one initial or symbol before the G., the remaining marks I would guess was 4 digits, a date...
some how only the G remains visible, which makes me think the markings may have been applied at different times.
Old 1st March 2023, 08:36 AM   #57
Hi Joe,
That's a nice job you did in cleaning the blade. The letter G is clearly visible as well as parts of other letters (?) and numbers (?). One thing to consider is that the G does not seem to align with the numbers, which in turn do not align with themselves. This suggests to me that these were applied some time after the original blade was forged. They would have been added by using a separate die for each letter, with the die being struck into the cold steel. Thus, we may not be looking at a maker's mark but something else.
As for the dahong palay, that's a Filipino sword used by the Tagalog and Ilokano people of Luzon. Dahong palay means rice leaf, and the blade shape resembles a rice leaf. I don't think the "G" on the Filipino sword has any connection to your sword.
Ian.
