Looking for advice, directions or some of the best practices on how to maintain Keris; especially for owners who live outside of Indonesia such as myself. This includes how to care for the wilah, selut or mendak, hilt, and warangka. Thanks in advance!
I won't dissuade a new conversation from taking place here, but we have discussed this subject many times throughout the history of this board. You can try searching the archives with terms like "keris maintenance", "keris cleaning" "keris care", etc. and you should find what you are looking for.
Here is at least one thread that might address some of your questions. http://www.vikingsword.com/vb/showth...is+maintenance |
I may not know how to look up the archives. I did try 'keris maintenance' and 'keris cleaning' in the search bar with no clear results. However, thank you for pointing me in the right direction I appreciate it, David.
#4 | |
Here's a pretty comprehensive post on how to clean and maintain the blade:http://www.vikingsword.com/vb/showthread.php?t=23934 Something that has not been added to that, which I think is a wise step to include, is to apply a slurry of bicarb and water to the blade, with a soft brush, after the vinegar bath is complete. Then rinse it off under running water, using a brush. This is to deactivate any remaining acid on the blade. |
David - what do you think about stickying a post about blade cleaning? I Think it would be beneficial given that the question is often asked and the information is spread throughout various threads, often with variations.
Here's my attempt at consolidating the information: 1. the blade under cold water and use dish detergent with a soft toothbrush to loosen any surface debris or corrosion. Often this will be enough to spruce up how it looks. 2. Dry with a lint free cloth. 3. If you want to clean it further, immerse in white cooking vinegar in a long container (e.g. long plant pot tray, wallpaper trough, etc.). Check on it twice a day. A clean blade should almost be white, with no corrosion. This process could take a couple of days to over a week. 4. After the vinegar's done its job, take it out and apply a slurry of bicarb and water to deactivate acid. Brush it in thoroughly into all the gaps and cracks to ensure there isn't any remnant acid. Then run it under cold water with detergent again. 5. Dry with lint free cloth and hairdryer. 6. Once completely dry, drench it in WD40, let it drip dry by leaning it point-down against a wall. Let it dry completely, then repeat. 7. Once completely dry, apply a fragrant keris oil. Edited for additional step below 8. Wrap in plastic sleeve and keep out of direct sunlight. Last edited by jagabuwana; 25th January 2022 at 03:46 AM. |
Thank you @David and @jagabuwana. Thankfully, my Keris is still in great shape, it's not a Keris sepuh but a kamardikan. So my question is more on how to maintain its pristine condition.
My question also expands not just for the wilah. But also how to care for the warangka, selut and hilt of various types of woods or combination of wood and silver and/or gold. I agree with @jagabuwana. It'd be great to have one thread discussing this topic. This subject has been scattered all over. @David and @jagabuwana have provided me with two different urls, which proves @jagabuwana's point. I did type in 'keris maintenance' and 'keris cleaning' in the search box with no clear results before creating this thread. I may not know how to look up the archives. So where do you think is best to pose my question? |
#7 | |
Keep in mine that Shadejoy's question was about more than just cleaning/etching blades. He asked about maintenance of the entire keris, including hilt, wrongko and fittings. |
Use the "search" function. Green tab, sixth option from the left. There is an advanced search option also if you want to try to follow a particular members evolution of thought on a subject. Very interesting to watch ideas and knowledge bases develop.
Here is how you search the archives Shadejoy. As IP stated, you can use either a quick search or you can click on 'Advanced Search" in the dropdown menu for a more detailed and specific search.
Thanks Dave!
I most likely will do this after a good cleaning and oiling, airtight vacuum-sealed.
| Tags |
| keris, keris maintenance, oil, rust |
