Old 1st December 2021, 03:22 PM   #1
Rikkn
Default Garde Du Corps Helmet
This was brought to me by a German acquaintance who is too old to be interested in his stuff....... He brought several uniform pieces , baners, and this.... It is very cool, and I believe it to be a Prussian Garde Du Corps Helmet. He claimed it was an officers helmet (?). Overall looks to be complete, other than having only residue of what I think was supposed to be a felt like coating on the thin lining material. It could use a deep cleaning, what would be the recommended method ? What do you guys think of it ?
Rikkn is offline   Reply With Quote
Old 2nd December 2021, 06:37 AM   #2
Bob A
Impressive, but I'd not care to wear it; that wing-nut would definitely make an impression on the wearer. Far outside my area of expertise, though. While corrosion is worrisome, addressing it is not something I'd attempt without prior consultation with someone with expertise with these items.
Wonderful display item, definitely eye-catching.
Old 2nd December 2021, 07:10 AM   #3
corrado26
corrado26's Avatar
Not Garde du Corps but Garde-Kürassier-Regiment, 3. Eskadron
Old 3rd December 2021, 03:42 PM   #4
midelburgo
Now you have to grow a moustache.
Old 3rd December 2021, 07:04 PM   #5
Rikkn
Got that nailed !!
Old 3rd December 2021, 11:00 PM   #6
asomotif
asomotif's Avatar
Old 3rd December 2021, 11:19 PM   #7
asomotif
asomotif's Avatar
What an impressive piece. I wish I had such acquaintances
I would not do a "deep"cleaning. I sort of like the patina on the helmet bowl.
The helmet plate looks like it has some (white) residue of brass polish.
I would start to remove that with a toothbrush and some soft soap.
The side posts and kokarde have some oxidation that I would also start to try and remove with a toothbrush and some soap.
The liner is probably original. Officers helmets have these types of liners.
Willem
Old 4th December 2021, 08:56 AM   #8
Victrix
Victrix's Avatar
Originally Posted by Rikkn View Post
Got that nailed !!
Splendid! You may want to use some of this for added effect.
Old 4th December 2021, 09:06 AM   #9
Victrix
Victrix's Avatar
With regards to the green residue on the helmet, unless I am mistaken, it’s brass oxidation and best removed for preservation of the item. In the past I have used white spirit on topz to remove the oxidation, using softer materials like wooden tooth picks and plastic disposable spoon on the harder brass to avoid marks. Then I used Brasso to polish the area gently to remove any remains of oxidation. Finally I applied some renaissance wax on the afflicted areas in the hope that it would prevent re-oxidation by restricting contact with oxygen.
Old 4th December 2021, 03:22 PM   #10
Will M
Will M's Avatar
Got that nailed !!
Just sign on the dotted line and they'll get you kitted out in full attire.
Wonderful find and a nice original piece. I agree with doing as little as necessary to conserve it. Once things are polished bright people question authenticity.
Old 7th December 2021, 11:18 AM   #11
I hope that eagle top is replaced by something more practical in battle, like a spike (as in a picklhaube). I wondered about that wingnut & its stud too. It's an owie in waiting. Maybe you can wear a helmet under the helmet?
Old 8th December 2021, 12:22 AM   #12
AHorsa
AHorsa's Avatar
This is a wonderful parade helmet. Taking into account its value, I wouldn't do anything to it if I was not well known to conservation. I think the best option is to bring it to a good restorer. Would be a bit pitty if this fabolous piece of history got damaged by wrong treatment.
Kind regards and congrats to that piece
Andreas
AHorsa is online now   Reply With Quote
Old 8th December 2021, 02:11 AM   #13
Rikkn
A good restorer would be a good idea. Any suggestions for one in the states ?
