Old 6th October 2021, 09:51 AM   #1
Evgeny_K
Evgeny_K's Avatar
Question Technical question (construction of the Walloon sword)
Dear colleagues,
I would be grateful for opinions on the following question: is this "nut" a separate element (threaded connection) or is it a riveted part of the tang?
I'm assessing the possibility of neatly detach the blade from the hilt.
PS certainly "design" not "construction"
Evgeny_K is offline   Reply With Quote
Old 6th October 2021, 07:11 PM   #2
Victrix
Victrix's Avatar
I’m not an expert on this but typically I believe these 17thC swords have pommels with a button, on top of which the tang is peened. You should then see a round flattened sphere at the top of the button (not shown in photo). I hope a more expert member can confirm…
Old 6th October 2021, 07:27 PM   #3
Merenti
hey Evgeny_K, that's mostly riveted and not screwed. Screw connections did not appear until around the 19th
Merenti is offline   Reply With Quote
Old 6th October 2021, 08:07 PM   #4
Evgeny_K
Evgeny_K's Avatar
Here it is
Old 7th October 2021, 12:49 PM   #5
midelburgo
Maybe if you use after removing rust and for a short period a weak acid like a drop of vinegar, it will etch the metal from the pommel differently from the metal from the tang and you will distinguish what is what.
Old 31st October 2021, 04:46 PM   #6
Triarii
Default Walloon Swords construction
Coming late to this, I have 9 C17th swords (all but one are English) and they all feature a tang 'bun' like this.
Triarii is offline   Reply With Quote
