This Sumba chopper was a recent Ebay purchase. Nice patina on the handle and scabbard, seems to have some age. The figurines are fun, cool to see a nod to their horse culture and the clever use of handle and the kabeala scabbard style to create the interlocking horse and rider. Would the forging flaw on the blade visible in the photo below indicate layered construction? Also, I was surprised that the spine does not taper until it almost reaches the point. This is much more common in blades made by stock removal.
Hello Jeff,
Yes, it's a Sumba knife, nice one but not very old. But it isn't a typical West Sumba knife, frankly said I never have seen a West Sumba knife. ![]() The swords from West Sumba have a very specific appearance, see this thread:http://www.vikingsword.com/vb/showth...ighlight=sumba, see #7. Regards, Detlef |
#3 | |
Hello Jeff,
The time frame the seller stated could be correct, the horn ferrule is today not very common anymore. Regards, Detlef |
#5 | |
The first, for example, is on chainsaw bar, the bar that frequently used for cut trees in the forest in some part of Indonesia valued more than a brand new bar because all of sap/resin/oil from the trees may give extra "power" to the blades that made from the chain saw bar. Second, bearing is known as one of the best scrap metals in rural areas, the notch usually won't be removed during the forging. I am not sure if the "forging flaw" in this blade is really a flaw or the material of the blade is from bearing. |
#6 | |
#7 | |
You may be correct but I've seen some apparently vintage blades without this horn ferrule.
#9 | |
they do sure make it clear there they prefer the horn for asthetic and cultural reasons.. but generally the type of parang with a horse rider on the handle have more oftern a metal furrel than the other "tusk" shaped handled blades |
